查看: 3014|回复: 0
[NI驱动程序] NI-SWITCH 3.5 Win32/64Eng NI开关产品驱动程序3.5下载
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-7-27 22:46:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    NI-SWITCH是用于控制和配置NI开关的NI仪器驱动程序。NI-SWITCH一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,并包含了交互式软件前面板和示例。
    Win32/64Eng
    3.5
    文件大小: 714810958 字节 (681.70 MB)
    修改日期: 2010-04-25 03:24
    MD5: d6e900f635758687e5ac7e24b0f068a9(官方正确)
    SHA1: dd6a2e63cd7331e2fc8e89c7ece28f39c51b9314
    SHA256: 29b272a555194711a701c9dc5898a4d472d13ab08b52e5ff61082a823bb464b7
    CRC32: 07590739
    Switch3.5.txt (514 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SWITCH Readme File
    Version 3.5
    January 2007
    Thank you for using NI-SWITCH for Windows Vista/XP/2000.
    This file contains important information about NI-SWITCH and is organized into the following sections:
    • New Features in Version 3.5
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
      • Examples
    • Uninstalling/Modifying NI-SWITCH
    • Obsolete VIs and Functions
    • Known Issues
    • Changes by Release
    • Support for Windows Vista. For more information about Microsoft Windows Vista and NI products, refer to ni.com/vista.
    NI-SWITCH 3.5 and later supports the following switch modules:
    • NI PXI-2501
    • NI PXI-2503
    • NI PXI-2527
    • NI PXI-2529
    • NI PXI-2530
    • NI PXI-2532
    • NI PXI-2545
    • NI PXI-2546
    • NI PXI-2547
    • NI PXI-2548
    • NI PXI-2549
    • NI PXI-2554
    • NI PXI-2555
    • NI PXI-2556
    • NI PXI-2557
    • NI PXI-2558
    • NI PXI-2559
    • NI PXI-2564
    • NI PXI-2565
    • NI PXI-2566
    • NI PXI-2567
    • NI PXI-2568
    • NI PXI-2569
    • NI PXI-2570
    • NI PXI-2575
    • NI PXI-2576
    • NI PXI-2584
    • NI PXI-2585
    • NI PXI-2586
    • NI PXI-2590
    • NI PXI-2591
    • NI PXI-2593
    • NI PXI-2594
    • NI PXI-2595
    • NI PXI-2596
    • NI PXI-2597
    • NI PXI-2598
    • NI PXI-2599
    • NI SCXI-1127
    • NI SCXI-1128
    • NI SCXI-1129
    • NI SCXI-1130
    • NI SCXI-1160
    • NI SCXI-1161
    • NI SCXI-1163R
    • NI SCXI-1166
    • NI SCXI-1167
    • NI SCXI-1169
    • NI SCXI-1175
    • NI SCXI-1190
    • NI SCXI-1191
    • NI SCXI-1192
    • NI SCXI-1193
    • NI SCXI-1194
    • NI SCXI-1195
    NOTES:  NI-SWITCH does not support legacy resource descriptors (SCXI:: and PXI::) under Windows Vista.
    NI-SWITCH supports the NI USB-1359 under Windows 2000, Windows XP, and the 32-bit version of Windows Vista. NI-SWITCH does not support the NI USB-1359 under the 64-bit version of Windows Vista.
    If you are using a PXI product, notice that MXI-4 is supported under Windows Vista/XP/2000, but MXI-3 is supported under only Windows XP/2000.
    NI-SWITCH 3.5 and NI-DAQmx 8.5 support Windows Vista/XP/2000. It is recommended that you have the most recent service pack for your operating system installed. Earlier versions of NI-SWITCH/NI-DAQ support other operating systems. To find and download an earlier version of a driver that supports other operating systems, refer to ni.com/downloads.
    Minimum System
    • Processor—Pentium 200 MHz or equivalent
    • RAM—64 MB
    • A screen resolution of 800×600 with 256 colors
    • Windows XP/2000, with all available critical updates and service packs
    Recommended System
    • RAM—256 MB
    • A screen resolution of 1024×768
    • Windows Vista/XP/2000, with all available critical updates and service packs
    • LabVIEW 7.1, 8.0, and 8.2
    • LabVIEW Real-Time Module 7.1.1, 8.0, and 8.2
    • LabWindows™/CVI™ 7.0, 8.0, and 8.1
    • Microsoft Visual Basic 6.0
    Installed File Names and LocationsSoftware
    FilesInstallation Location on Windows XP/2000 and 32-Bit Version of Windows VistaInstallation Location on 64-Bit Version of Windows Vista
    NI-SWITCHProgram Files\IVI\Drivers\niSwitchProgram Files (x86)\IVI\Drivers\niSwitch
    DocumentationProgram Files\IVI\Drivers\niSwitch\DocumentationProgram Files (x86)\IVI\Drivers\niSwitch\Documentation
    LabVIEW support\instr.lib\niSwitch\instr.lib\niSwitch
    LabVIEW examplesProgram Files\IVI\Drivers\niSwitch\Examples\LabVIEWProgram Files (x86)\IVI\Drivers\niSwitch\Examples\LabVIEW
    CVI supportProgram Files\IVI\Drivers\niDCPowerProgram Files (x86)\IVI\Drivers\niDCPower
    CVI examplesProgram Files\IVI\Drivers\niSwitch\Examples\CVIProgram Files (x86)\IVI\Drivers\niSwitch\Examples\CVI
    C/C++ examplesProgram Files\IVI\Drivers\niSwitch\Examples\CProgram Files (x86)\IVI\Drivers\niSwitch\Examples\C
    VB examplesProgram Files\IVI\Drivers\niSwitch\Examples\VBProgram Files (x86)\IVI\Drivers\niSwitch\Examples\VB
    SWITCH Soft Front PanelProgram Files\IVI\Drivers\niSwitchProgram Files (x86)\IVI\Drivers\niSwitch
    LabVIEW Run-Time Engine 8.0Program Files\National Instruments\Shared\LabVIEW Run-Time\7.1Program Files (x86)\National Instruments\Shared\LabVIEW Run-Time\7.1
    NI-DAQmx 8.5Program Files\National Instruments\NI-DAQProgram Files (x86)\National Instruments\NI-DAQ
    IVI Compliance Package 3.0Program Files\National Instruments\IVIProgram Files (x86)\National Instruments\IVI
    NI-VISA 4.1WINDOWS\system32WINDOWS\sysWOW64
    Measurement & Automation Explorer 4.2Program Files\National Instruments\MAXProgram Files (x86)\National Instruments\MAX
    Documentation is available at Start»All Programs»National Instruments»NI-SWITCH»Documentation. The documentation set is composed of the following documents:
    • NI-SWITCH Readme File
    • Readme First: Safety and Radio-Frequency Interference
    Printed format. Includes safety instructions and information about the radio-frequency interference characteristics of the hardware it accompanies.
    • NI Switches Getting Started Guide
    Printed and PDF format. Includes hardware and software installation, MAX configuration, and signal connection information.
    • NI Switches Help
    HTML help format. Includes switching fundamentals, device specific information, programming information, tutorials, a LabVIEW VI reference, and LabWindows/CVI, C++, and Visual Basic function references.
    • NI-SWITCH Instrument Driver Quick Reference Guide
    Printed and PDF format. Lists the VIs/functions and their associated parameters and data types available with NI-SWITCH.
    • Switch Soft Front Panel Help
    HTML help format. Includes step-by-step information about how to use the Switch Soft Front Panel (SFP) to test the basic functionality of your switch module and troubleshoot your applications.
    • NI Switch Specifications
    Printed and PDF format. Lists specifications for each NI switch module.
    • NI Switch Accessory Installation Instructions (Optional)
    Printed and PDF format. Lists NI switch module accessory installation information.
    Examples
    Refer to Start»All Programs»National Instrument»NI-SWITCH»Examples for the examples for the supported ADEs. The examples cover immediate operations, synchronous scanning, handshaking, and software triggering. A complete example list is available in the NI Switches Help.
    Refer to the Installed File Names and Locations section for the installed locations of the example sets.
    For Windows 2000/XP, complete the following steps:
    • Double-click Add/Remove Programs.
    • Click Change/Remove.
    • Select NI-SWITCH 3.x from the dialog box that appears.
    For Windows Vista, complete the following steps:
    • Easy niSwitch CIN VI/function
    • Easy niSwitch Close VI/function
    • Easy niSwitch Open VI/function
    • niSwitch Connect and Wait VI/function
    • niSwitch Control a Single Switch VI/function
    • niSwitch Disconnect and Wait VI/function
    • niSwitch EasyIO Connect VI/function
    • niSwitch EasyIO Disconnect VI/function
    • niSwitch EasyIO Reset VI/function
    • niSwitch EasyIO Scan VI/function
    • niSwitch EasyIO Scanning Acquisition VI/function
    • niSwitch Query a Single Switch VI/function
    • niSwitch Scan VI/function
    • niSwitch Scanning Acquisition VI/function
    • niSwitch Error-Query VI/function
    • niSwitch Get Error Info VI/function
    • niSwitch Write Calibration Data VI/function
    • niSwitch Read Calibration Data VI/function
    The following are known issues for NI-SWITCH 3.5:
    • Reverting to NI-SWITCH 1.6 after installing NI-SWITCH 3.5
      If reverting back to NI-SWITCH 1.6 from NI-SWITCH 3.5, you must uninstall NI-SWITCH 3.5 and reinstall NI-SWITCH 1.6.
    • Various support files, such as .h and .lib files, are installed in \Program Files\IVI and \VXIpnp directories to support ADEs that only recognize the \VXIpnp directory.
    • SCXI-1127 (Rev D and earlier) continuously drives the TTL1 trigger line on the SCXI backplane. This does not allow bus sharing of TTL1 with other SCXI modules. NI-SWITCH returns an error if an SCXI-1127 is in the chassis and if TTL1 is being used for scanning. If using the NI-DAQmx driver for your SCXI system, you get a resource reservation error if you try to perform a switching or signal conditioning operation that requires use of TTL1.
    • There are known DLL collision issues with the Microsoft Visual Basic debugger and a National Instruments device driver using Traditional NI-DAQ (Legacy). A support DLL used by NI-SWITCH fails to load if Visual Basic has already loaded another DLL into the same address space. To change the default address that is used to load the driver DLL, create the following registry key:
      \\HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\NI-PAL\CurrentVersion\palConfig\Memory\
      sharedFixedAddress
      where the value is a DWORD (0x44000000 generally works). For the change to take effect, you must close and restart all applications after adding the registry key.
    • NI-DMM 2.2
      • NI-DMM 2.2 updated the niSwitch DMM Switch Handshaking example for LabVIEW. If you have an earlier version of NI-DMM installed, the VI is inoperable. To use the example with NI-DMM 2.1.2 or earlier, delete the AUX Trig 1 case from the case structure connected to Sample Trigger Source in the niDMM Configure Multi Point VI.
      • NI-DMM 2.2 introduces a new enumerated value, AUX Trig 1.
    • When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to the your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    • NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate, when using this product. These modes terminate any NI-SWITCH operation in progress. Notice that in Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    Changes by Release3.5 from 3.4
    3.4 from 3.3.1
    • Support for the NI PXI-2545/2546/2547/2548/2549/2554/2555/2556/2557/2558/2559 switch modules
    3.3.1 from 3.3
    • Fixed intermittent timeout errors on switch hardware after cold boot when using NI-SWITCH 3.1 or NI-SWITCH 3.3
    3.3 from 3.1
    • New NI PXI-2584 example for interleaved scanning
    • NI PXI-2584 independent topology schematic in the Switch Soft Front Panel
    • New Behavior—For NI-DAQmx devices, initializing a session now closes any other existing sessions open to the same device in the same process. Calling niSwitch_init, niSwitch_InitWithTopology, or niSwitch_InitWithOptions therefore always results in the creation of a new session rather than returning an existing session. This new behavior does not apply to sessions to Traditional NI-DAQ (Legacy) devices and NI-VISA based devices.
    © 1998–2007 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2025-12-12 19:30
