查看: 2852|回复: 0
[NI驱动程序] NI-SWITCH 3.3 Win32Eng NI开关产品驱动程序3.3下载
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-7-27 22:43:01 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    NI-SWITCH是用于控制和配置NI开关的NI仪器驱动程序。NI-SWITCH一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,并包含了交互式软件前面板和示例。
    Win32Eng
    3.3
    文件大小: 600706174 字节 (572.88 MB)
    修改日期: 2010-04-25 03:27
    MD5: 2ed87fa25e17c5b38f39a5a4f084afe1(官方正确)
    SHA1: 4e36f7f0e05293de412bce27b7f8962d7428c201
    SHA256: 318e52ca9894891cb1a504c733f1bf500c56ec66b3b85dc3d500345e9f9b0912
    CRC32: f28c1b89
    Switch3.3.txt (514 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SWITCH Readme File
    National Instruments™, NI™, ni.com™ and LabVIEW™ are trademarks of National Instruments Corporation. Product and company names mentioned herein are trademarks or trade names of their respective companies.
    © Copyright 1998–2006 National Instruments Corporation. All rights reserved.
    Version 3.3
    Thank you for using NI-SWITCH.
    This file contains important information about NI-SWITCH, and is organized into the following sections:
    • New Features in NI-SWITCH 3.3
    • Supported Hardware
    • System Requirements
      • Software
      • Documentation
      • Examples
    • Uninstalling/Modifying NI-SWITCH
    • Obsolete VIs and Functions
    • Known Issues
    • Changes by Release
    • New NI PXI-2584 example for interleaved scanning
    • NI PXI-2584 independent topology schematic in the Switch Soft Front Panel
    • New Behavior—For NI-DAQmx devices, initializing a session now closes any other existing sessions open to the same device in the same process. Calling niSwitch_init, niSwitch_InitWithTopology, or niSwitch_InitWithOptions therefore always results in the creation of a new session rather than returning an existing session. This new behavior does not apply to sessions to Traditional NI-DAQ (Legacy) devices and NI-VISA based devices.
    NI-SWITCH 3.3 now supports the following switch modules:
    • NI SCXI-1127/1128/1129/1130/1160/1161/1163R/1166/1167/1169/1175/1190/1191/1192/1193/1194/1195
    • NI PXI-2501/2503/2527/2529/2530/2532/2564/2565/2566/2567/2568/2569/2570/2575/2576/2584/2585/2586/2590/
      2591/2593/2594/2595/2596/2597/2598/2599
    NI-DAQmx, Traditional NI-DAQ (Legacy), and NI-SWITCH 3.3 support Windows XP/2000. It is recommended that you have the most recent service pack for your operating system installed. Earlier versions of NI-SWITCH/NI-DAQ support other operating systems. To find and download an earlier version of a driver that supports other operating systems, refer to ni.com/downloads.
    Minimum System
    • Processor—Pentium 200 MHz or equivalent
    • RAM—64 MB
    • A screen resolution of 800×600 with 256 colors
    • Windows 2000/XP, with all available critical updates and service packs
    Recommended System
    • RAM—256 MB
    • A screen resolution of 1024×768
    • Windows 2000/XP or later, with all available critical updates and service packs
    • LabVIEW 7.1 or later
    • LabVIEW Real-Time Module 7.1.1 or later
    • LabWindows™/CVI™ 7.0 or later
    Installed File Names and LocationsSoftware
    ItemInstalled Location
    NI-SWITCHProgram Files\IVI\Drivers\niSwitch
    DocumentationProgram Files\IVI\Drivers\niSwitch\Documentation
    NI-SWITCH LabVIEW 7.1 supportProgram Files\National Instruments\LabVIEW 7.1\instr.lib\niSwitch
    NI-SWITCH LabVIEW 8.x supportProgram Files\National Instruments\LabVIEW 8.x\instr.lib\niSwitch
    NI-SWITCH LabVIEW ExamplesProgram Files\IVI\Drivers\niSwitch\Examples\LabVIEW
    NI-SWITCH CVI supportProgram Files\IVI\Drivers\niSwitch
    NI-SWITCH CVI ExamplesProgram Files\IVI\Drivers\niSwitch\Examples\CVI
    NI-SWITCH VB ExamplesProgram Files\IVI\Drivers\niSwitch\Examples\VB
    SWITCH-SFP (Soft Front Panel)Program Files\IVI\Drivers\niSwitch
    NOTE  NI-SWITCH also requires installation of NI-DAQ 8.3, NI-VISA 4.0, Measurement & Automation Explorer 4.1, and the IVI Compliance Package 2.5, which are included in the NI-SWITCH 3.3 installation distribution.
    Most documentation is available at Start»All Programs»National Instruments»NI-SWITCH»Documentation. The documentation set is composed of the following documents:
    • NI-SWITCH Readme File
    Printed format. Includes safety instructions and information about the radio-frequency interference characteristics of the hardware it accompanies.
    • Readme First: Safety and Radio-Frequency Interference
    • NI Switches Getting Started Guide
    Printed and PDF format. Includes hardware and software installation, MAX configuration, and signal connection information.
    • NI Switches Help
    HTML help format. Includes switching fundamentals, device specific information, programming information, tutorials, a LabVIEW VI reference, and LabWindows/CVI, C++, and Visual Basic function references.
    • NI-SWITCH Instrument Driver Quick Reference Guide
    Printed and PDF format. Lists the VIs/functions and their associated parameters and data types available with NI-SWITCH.
    • Switch Soft Front Panel Help
    HTML help format. Includes step-by-step information about how to use the Switch Soft Front Panel (SFP) to test the basic functionality of your switch module and troubleshoot your applications.
    • NI Switch Module Specifications
    Printed and PDF format. Lists specifications for each NI switch module.
    • NI Accessory Installation Instructions (Optional)
    Printed and PDF format. Lists NI switch module accessory installation information.
    Examples
    The example set covers immediate operations, synchronous scanning, handshaking, and software triggering. A complete example list is available in the NI Switches Help.
    ADELocation
    LabVIEW\examples\intr\niSwitch
    LabWindows/CVIProgram Files\IVI\Drivers\niSwitch\Examples\CVI
    CProgram Files\IVI\Drivers\niSwitch\Examples\C
    Visual BasicProgram Files\IVI\Drivers\niSwitch\Examples\VB
    For Windows 2000/XP, complete the following steps to modify or uninstall NI-SWITCH:
    • Open the Control Panel from the Start»Control Panel Menu and select Add or Remove Programs.
    • Select National Instruments Software from the list provided and click Change or Remove.
    • Select NI-SWITCH 3.x from the list provided and choose Modify or Remove.
    • Easy niSwitch CIN VI/function
    • Easy niSwitch Close VI/function
    • Easy niSwitch Open VI/function
    • niSwitch Connect and Wait VI/function
    • niSwitch Control a Single Switch VI/function
    • niSwitch Disconnect and Wait VI/function
    • niSwitch EasyIO Connect VI/function
    • niSwitch EasyIO Disconnect VI/function
    • niSwitch EasyIO Reset VI/function
    • niSwitch EasyIO Scan VI/function
    • niSwitch EasyIO Scanning Acquisition VI/function
    • niSwitch Query a Single Switch VI/function
    • niSwitch Scan VI/function
    • niSwitch Scanning Acquisition VI/function
    • niSwitch Error-Query VI/function
    • niSwitch Get Error Info VI/function
    • niSwitch Write Calibration Data VI/function
    • niSwitch Read Calibration Data VI/function
    The following are known issues for NI-SWITCH 3.3:
    • If reverting back to NI-SWITCH 1.6 from NI-SWITCH 3.3, you must uninstall NI-SWITCH 3.3 and reinstall NI-SWITCH 1.6.
    • Various support files, such as .h and .lib files, are installed in \Program Files\IVI and \VXIpnp directories to support ADEs that only recognize the \VXIpnp directory.
    • SCXI-1127 (Rev D and earlier) continuously drives the TTL1 trigger line on the SCXI backplane. This does not allow bus sharing of TTL1 with other SCXI modules. NI-SWITCH returns an error if an SCXI-1127 is in the chassis and if TTL1 is being used for scanning. If using the NI-DAQmx driver for your SCXI system, you get a resource reservation error if you try to perform a switching or signal conditioning operation that requires use of TTL1.
    • There are known DLL collision issues with the Microsoft Visual Basic debugger and a National Instruments device driver using Traditional NI-DAQ (Legacy). A support DLL used by NI-SWITCH fails to load if Visual Basic has already loaded another DLL into the same address space. To change the default address that is used to load the driver DLL, create the following registry key:
      \\HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\NI-PAL\CurrentVersion\palConfig\Memory\
      sharedFixedAddress
      where the value is a DWORD (0x44000000 generally works).
      For the change to take effect, you must close and restart all applications after adding the registry key.
    • The niSwitch DMM Switch Handshaking example for LabVIEW was updated with NI-DMM 2.2. If you have an earlier version of NI-DMM installed, the VI is inoperable.
      To use the example with NI-DMM 2.1.2 or earlier, delete the AUX Trig 1 case from the case structure connected to Sample Trigger Source in the niDMM Configure Multi Point VI.
      NI-DMM 2.2 introduces a new enumerated value, AUX Trig 1.
    Changes by Release3.3 from 3.1
    3.1 from 3.0
    • Support for the NI PXI-2584 switch module
    3.0 from 2.5
    • Support for the NI PXI-2576/2584/2594/2595/2596/2597/2598/2599 and NI SCXI-1194/1195 switch modules
    GMT+8, 2025-12-12 19:30
