查看: 2992|回复: 0
[NI驱动程序] NI-SWITCH 2.3.1 Win32Eng NI开关产品驱动程序2.3.1下载
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-7-27 22:35:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SWITCH
    NI-SWITCH为使用NI开关产品的客户提供支持。
    NI-SWITCH是用于控制和配置NI开关的NI仪器驱动程序。NI-SWITCH一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,并包含了交互式软件前面板和示例。
    Win32Eng
    2.3.1
    文件大小: 700326976 字节 (667.88 MB)
    修改日期: 2007-08-24 01:01
    MD5: bf8f6fb49fa73b365301141b837c6431(官方正确)
    SHA1: 9569a3c219c3fa2ee35ad7d8f64c724c0df39415
    SHA256: f46414d5394e878df63732b08f71efb16f9138b93471abf0ebecbbc1d474aa26
    CRC32: 22493d36
    Switch2.3.1.txt (519 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SWITCH 2.3.1 Readme File
    (c) Copyright 1998–2004 National Instruments Corporation. All rights reserved.
    Trademarks: CVI, LabVIEW, Measurement Studio, National Instruments, ni.com, NI-DAQ, NI-VISA, and SCXI are trademarks of National Instruments Corporation. Product and company names mentioned herein are trademarks or trade names of their respective companies.
    This file contains the following information:
    • New Features in NI-SWITCH 2.3.1
    • Supported Switch Modules
    • Switch Modules and NI-DAQ
    • System Requirements
    • Installed Software Components and Locations
    • Installed Examples and Locations
    • Installed Documentation
    • Known Issues
    • Uninstalling NI-SWITCH 2.3.1
    • Changes/Fixes to NI-SWITCH
    • Support for the NI SCXI-1169/1175 and NI PXI-2532/2564/2575/2585/2586 switch modules.
    • Support for the LabVIEW Real-Time Module
    • Added a new topology for the NI PXI-2530 (1-wire dual 64×1 multiplexer)
    NI-SWITCH 2.3.1 now supports the following switch modules:
    • NI SCXI-1127/1128/1129/1130/1160/1161/1163R/1166/1167/1169/1175/1190/1191/1192/1193
    • NI PXI-2501/2503/2529/2530/2532/2564/2565/2566/2567/2568/2569/2570/2575/2585/2586/2590/2591/2593
    Switch Modules and NI-DAQSystem Requirements
    NI-DAQmx, Traditional NI-DAQ, and NI-SWITCH 2.3.1 support Windows XP/2000/NT. It is recommended that you have the most recent service pack for your operating system installed. Windows NT requires Service Pack 6 or later. If you are using Windows NT, make sure that you have installed Internet Explorer 5.0 on your computer. Internet Explorer 5.0 or later is required for your help applications to work correctly. Earlier versions of NI-DAQ support other operating systems. To find and download an earlier version of a driver that supports other operating systems, refer to ni.com/downloads. For operating system-specific installation instructions, use the DAQ Configuration Wizard at ni.com/support/install.
    Recommended ADEs:
    • LabVIEW 7.x or later
    • LabWindows/CVI 7.x or later
    Minimum ProcessorPentium 200 MHz or equivalent
    RAM64 MB
    Screen Resolution800×600 pixels or no screen
    Operating SystemWindows XP/2000 or later
    Recommended ProcessorPentium III/Celeron 600 MHz or equivalent
    RAM256 MB
    Screen Resolution1024×768 pixels or no screen
    The following components are installed for NI-SWITCH 2.3.1:
    ItemInstalled Location
    NI-SWITCHProgram Files\IVI\Drivers\niSwitch
    DocumentationProgram Files\IVI\Drivers\niSwitch\Documentation
    NI-SWITCH LabVIEW 6.1 supportProgram Files\National Instruments\LabVIEW 6.1\instr.lib\niSwitch
    NI-SWITCH LabVIEW 7.x supportProgram Files\National Instruments\LabVIEW 7.x\instr.lib\niSwitch
    NI-SWITCH LabVIEW ExamplesProgram Files\IVI\Drivers\niSwitch\Examples\LabVIEW
    NI-SWITCH CVI supportProgram Files\IVI\Drivers\niSwitch
    NI-SWITCH CVI ExamplesProgram Files\IVI\Drivers\niSwitch\Examples\CVI
    NI-SWITCH Measurement Studio ExamplesProgram Files\IVI\Drivers\niSwitch\Examples\Measurement Studio
    NI-SWITCH VB ExamplesProgram Files\IVI\Drivers\niSwitch\Examples\VB
    SWITCH-SFP (Soft Front Panel)Program Files\IVI\Drivers\niSwitch
    NOTE  NI-SWITCH also requires installation of NI-DAQ 7.3.1, NI-VISA 3.1, Measurement & Automation Explorer 3.1, and the IVI Compliance Package 2.1.2, which are included in the NI-DAQ 7.3.1 installation distribution.
    The example set covers immediate operations, synchronous scanning, handshaking, and software triggering.
    ADELocation
    LabVIEW\examples\intr\niSwitch
    LabWindows/CVIProgram Files\IVI\Drivers\niSwitch\Examples\CVI
    Measurement StudioProgram Files\IVI\Drivers\niSwitch\Examples\Measurement Studio
    CProgram Files\IVI\Drivers\niSwitch\Examples\C
    Visual BasicProgram Files\IVI\Drivers\niSwitch\Examples\VB
    A complete example list is available in the NI Switches Help.
    All documentation is available at Start» Programs»National Instruments»NI-SWITCH»Documentation. The documentation set is composed of the following documents:
    • NI-SWITCH 2.x Readme File
    • NI Switches Getting Started Guide
    Printed and PDF format. Includes safety, hardware & software installation, configuration in Measurement & Automation Explorer (MAX), and connection information.
    • NI Switches Help
    HTML help format. Includes switching fundamentals, device specific information, programming information, tutorials, a LabVIEW VI reference, and LabWindows/CVI, C++, and Visual Basic function references.
    • NI-SWITCH Instrument Driver Quick Reference Guide
    Printed and PDF format. Lists the VIs/functions and their associated parameters and data types available with NI-SWITCH.
    • A Specifications document for each switch module
    • Terminal block installation guides
    The following are known issues for NI-SWITCH 2.3.1:
    • If reverting back to NI-SWITCH 1.6 from NI-SWITCH 2.3.1, you must uninstall NI-SWITCH 2.3.1 and reinstall NI-SWITCH 1.6.
    • Various support files, such as .h and .lib files, are installed in \Program Files\IVI and \VXIpnp directories to support ADEs that only recognize the \VXIpnp directory.
    • SCXI-1127 (Rev D and earlier) continuously drives the TTL1 trigger line on the SCXI backplane. This does not allow bus sharing of TTL1 with other SCXI modules. NI-SWITCH returns an error if an SCXI-1127 is in the chassis and if TTL1 is being used for scanning. If using the NI-DAQmx driver for your SCXI system, you get a resource reservation error if you try to perform a switching or signal conditioning operation that requires use of TTL1.
    • There are known DLL collision issues with the Microsoft Visual Basic debugger and a National Instruments device driver using Traditional NI-DAQ. A support DLL used by NI-SWITCH fails to load if Visual Basic has already loaded another DLL into the same address space. To change the default address that is used to load the driver DLL, create the following registry key:
      \\HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\NI-PAL\CurrentVersion\palConfig\Memory\sharedFixedAddress
      where the value is a DWORD (0x44000000 generally works).
      For the change to take effect, you must close and restart all applications after adding the registry key.
    • The niSwitch DMM Switch Handshaking example for LabVIEW was updated with NI-DMM 2.2. If you have an earlier version of NI-DMM installed, the VI is inoperable.
      To use the example with NI-DMM 2.1.2 or earlier, delete the AUX Trig 1 case from the case structure connected to Sample Trigger Source in the niDMM Configure Multi Point VI.
      NI-DMM 2.2 introduces a new enumerated value, AUX Trig 1.
    For Windows XP/2000/NT, complete the following:
    • Open the Control Panel from the Start»Settings»Control Panel Menu and select Add or Remove Programs.
    • Select National Instruments Software and click Change.
    • Select NI-SWITCH 2.3.1 from the list provided and click Uninstall.
    Changes/Fixes to NI-SWITCH2.3.1 from 2.2
    • Support for the SCXI-1169/1175 and PXI-2532/2564/2575/2585/2586 switch modules
    • Added a new topology for the PXI-2530 (1-wire dual 64×1 multiplexer)
    2.2 from 2.1
    • Support for the PXI-2568/2569/2570 switch modules
    • Added Measurement Studio support
    2.1 from 2.0
    • Support for the SCXI-1130/1167 and PXI-2529/2530/2567 switch modules
    • Added terminated topologies for the SCXI-1193 (quad 4×1 mux, dual 8×1 mux, 16×1 mux)
    • Added terminated topologies for the PXI-2593 (dual 4×1 mux, 8×1 mux)
    2.0 from 1.6
    • New initialization, scanning, trigger routing, and relay control functions
    • Support for the SCXI-1166/1193 and PXI-2566/2593 switch modules
    • Simplified example set
    • Improved switch configuration in MAX
    • Improved documentation set
    • NI-SWITCH 2.x requires installation of NI-DAQmx. Traditional NI-DAQ is required for existing applications that use NI-SWITCH
    • Added niSwitch Initialize With Topology VI/function
    • Added niSwitch Commit VI/function
    • Added niSwitch Route Scan Advanced Output VI/function
    • Added niSwitch Route Trigger Input VI/function
    • Added niSwitch Get Relay Count VI/function
    • Added niSwitch Get Relay Names VI/function
    • Added niSwitch Relay Control VI/function
    • Added niSwitch Get Relay Position VI/function
    • Additional functions and VIs added to support the IVI-4.6: IviSwtch Class Specification. Refer to the latest IviSwtch specification at ivifoundation.org
    • Obsoleted Easy niSwitch CIN VI/function
    • Obsoleted Easy niSwitch Close VI/function
    • Obsoleted Easy niSwitch Open VI/function
    • Obsoleted niSwitch Connect and Wait VI/function
    • Obsoleted niSwitch Control a Single Switch VI/function
    • Obsoleted niSwitch Disconnect and Wait VI/function
    • Obsoleted niSwitch EasyIO Connect VI/function
    • Obsoleted niSwitch EasyIO Disconnect VI/function
    • Obsoleted niSwitch EasyIO Reset VI/function
    • Obsoleted niSwitch EasyIO Scan VI/function
    • Obsoleted niSwitch EasyIO Scanning Acquisition VI/function
    • Obsoleted niSwitch Query a Single Switch VI/function
    • Obsoleted niSwitch Scan VI/function
    • Obsoleted niSwitch Scanning Acquisition VI/function
    • Obsoleted niSwitch Error-Query VI/function
    • Obsoleted niSwitch Get Error Info VI/function
    • Obsoleted niSwitch Write Calibration Data VI/function
    • Obsoleted niSwitch Read Calibration Data VI/function
    GMT+8, 2025-12-12 19:30
