查看: 3219|回复: 0
[NI软件套件] NI System Driver Suite 2010.02 Win32/64Eng NI系统驱动套件SDS-Feb10
    7 小时前
  • 签到天数: 3555 天
    连续签到: 7 天
    发表于 2021-7-5 15:39:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    System Driver Suite
    System Driver Suite在单个软件包中提供了常见的NI驱动程序软件,以帮助您开发PXI、CompactRIO或CompactDAQ系统。
    System Driver Suite提供了一系列经验证可兼容的NI驱动程序软件集,可用于配置PXI、CompactRIO或CompactDAQ系统。这些驱动程序集可帮助您在整个应用程序生命周期中保持确保对于的驱动程序软件的标准化。使用System Driver Suite,您可以安装一些常见的驱动程序,例如NI-FlexRIO、NI-Motion、NI-DAQmx、NI-VISA、NI-Serial、NI-488.2、NI-CAN、NI-IMAQ、NI-IMAQdx、NI-DMM、NI-SCOPE、NI-Sync、NI-Switch、NI-RFSA、NI-RFSG、NI-DCPower、NI-RIO、NI-DNET和NI-VXI等,具体参考后面的发行说明或自述文档。
    文件大小: 3660414678 字节 (3.41 GB)
    修改日期: 2010-02-26 06:50
    版本: 4.65.0.0
    MD5: af63989d50ac0ff2b977065af5b25ce4(官方正确)
    SHA1: 9d6bb78dee4da3f9e3372e0811fb34d0bbb62874
    SHA256: 4c6a16451036d92bf0e93428a9262ea194c684b9bcfd8d6a4f42efad9063d1f3
    CRC32: 5771e8e6
    请注册登录论坛会员,购买附件查看下载地址
    SDS2010.02.txt (471 Bytes, 下载次数: 0, 售价: 30 元)
    National Instruments System Driver Set ReadmeFebruary 2010 Release
    © 2003-2010 National Instruments. All rights reserved.
    Windows 7 Issues
    National Instruments is committed to maintaining compatibility with Microsoft Windows technology changes. While most NI products work with Windows 7, NI has become aware of some compatibility issues regarding Windows 7.  To learn more about Windows 7 and NI products, visit ni.com/info and enter the Info Code windows7.
    For patents covering National Instruments products, refer to the appropriate location: Help»Patents in your software, the patents.txt file in this folder, or ni.com/patents.
    System Driver Set Contents
    • Data Acquisition
      • NI-DAQmx 9.0.2f4
      • Traditional NI-DAQ 7.4.4 (Legacy)
      • NI-435x 2.5.2
    • Instrument Control
      • NI-488.2 2.7.3
      • NI-VISA 4.6.1
      • NI-Serial 3.5.1
      • IVI Compliance Package 4.1
      • PXI Platform Services 2.5.3
      • NI System Monitor 1.1.1
      • NI-VXI 3.6
    • Modular Instruments
      • NI-Switch 4.0.1
      • NI-DMM 3.0.2
      • NI-Scope 3.6
      • NI-RFSA 2.3.1
      • NI-PXI-5660 Support
      • NI-FGEN 2.7.2
      • NI-DCPower 1.4
      • NI-RFSG 1.6.2
      • NI-HSDIO 1.7.1
      • NI-5690 1.1
      • NI-5460R 1.3
    • Timing & Synchronization
      • NI-Sync 3.1.0
    • Reconfigurable IO
      • NI-RIO 3.3.1
      • CompactRIO 3.3.0
      • NI-FlexRIO 1.3
    • Motion
      • NI-Motion 8.1
    • Vision Acquisition Software
      • NI-IMAQ 4.3.1
      • NI-IMAQdx 3.5
      • NI-IMAQ I/O 2.3.1
    • Distributed I/O
      • NI-FieldPoint 6.0.5
    • Real-Time and Embedded
      • NI-488.2 2.7.3
      • NI-Serial 3.3.4
      • NI-Watchdog 4.0
    • Communication Buses and Protocols
      • NI-XNET 1.0
      • NI-CAN 2.7
      • NI-DNET 1.6.4
      • NI-Industrial Communications for DeviceNet 2.0
    • NI LabVIEW SignalExpress 2009
    • NI Spy 2.7.1
    • NI Measurement & Automation Explorer 4.6.2
    This installation requires one of the following Microsoft operating systems:
    • Windows XP
    • Windows 2000
    • Windows Vista x86
    • Windows Vista x64
    • Windows 7 x86
    • Windows 7 x64
    • Windows Server 2008 R2
    This installation requires that version 3.1 of the MSI (Windows Installer) Engine is installed on your computer. If you do not have MSI 3.1 or later, the installer updates the engine automatically and might require you to restart your computer.
    Additional Requirements for Specific Features
    Certain features in this installation have additional requirements.
    FeatureAdditional System RequirementsNI Software Requirements
    Visual C++ 2005 support for:
    • NI-DAQmx
    • NI-488.2
    • NI-VISA
    NoneNational Instruments Measurement Studio VC++ 2005
    Visual C++ 2003 support for:
    • NI-DAQmx
    • NI-488.2
    • NI-VISA
    NoneNational Instruments Measurement Studio VC++ 2003
    .NET Framework 1.1 and 2.0 support for:
    • NI-DAQmx
    • NI-488.2
    • NI-VISA
    Microsoft .NET Framework 1.1
    or
    Microsoft .NET Framework 2.0
    LabWindowsTM/CVITM Support for:
    • NI-DAQmx
    • NI-CAN
    • NI-DNET
    NoneLabWindows/CVI 7.0 or later
    LabVIEWTM Support for:
    • NI-435x
    NoneNational Instruments LabVIEW 7.1 or later
    Uninstallation Instructions
    You can uninstall software that you installed from this DVD by selecting National Instruments Software in the Windows Add/Remove Programs application.
    © 2003–2010 National Instruments Corporation. All rights reserved.
    CVI, National Instruments, NI, ni.com, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.
    GMT+8, 2025-5-31 17:37
