查看: 3406|回复: 0
[NI软件产品] NI DataFinder Server Edition 2011 Win32Eng 数据查找服务器版DFSE2011英语版下载
    发表于 2021-7-1 16:17:00 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    DataFinder Server
    DataFinder Server是一款应用软件,无论文件格式和网络位置如何,都可以搜索数据,而无需复杂的IT系统。
    DataFinder Server是一款集中式数据管理软件,可自动发现、标准化和管理工程数据,方便多个用户进行搜索。 与传统解决方案不同的是,DataFinder Server可直接索引计算机或网络上指定文件夹中的数据文件,而不需要构建数据库。 当文件发生更改时,DataFinder Server会自动重新组织,而无需让服务器脱机即可进行维护。 随着需求的增加,DataFinder Server可通过联合架构升级为部门级和企业级规模。
    DFSE2011
    文件大小: 392485472 字节 (374.30 MB)
    修改日期: 2011-06-30 22:26
    MD5: 70cee161194c54997def522f1afdfd75
    SHA1: 32c0722c564b48e3b68b6fa8766fa9caa5175131
    SHA256: dc02f642686e2a23971bc04f7db448c594d9d652c9160cd0a0172407b10fbfd8
    CRC32: 3ff1ee1f
    请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服
    DFSE2011Eng.txt (591 Bytes, 下载次数: 0, 售价: 10 圆)
    DataFinder Server Edition 2011 Release Notes
    Version 3.0
    July 2011
    This file contains basic information on the DataFinder Server Edition 2011. The file contains the following information:
    For correct DataFinder Server Edition performance, the following minimum requirements must be met:
    Hardware
    CPU2 processor cores, clock frequency 1 GHz
    Amount of memory2 GB
    Hard disk memoryAt least 500 MB free memory space
    Graphics boardColor depth at least 16 bit (High Color), recommended 24 or 32 bit (True Color)
    Screen resolution800x600 or higher
    Operating Systems
    • Windows Server 2003 32 Bit
    • Windows Server 2003 R2 32 Bit
    • Windows Server 2008 32 Bit
    • Windows Server 2008 R2 64 Bit (as 32 bit application)
    Miscellaneous
    • Internet Explorer Version 6.0 Service Pack 1 or later
    • If you do not install DIAdem, you need the Windows Scripting Host if you use VBS-DataPlugins.
    Note  DataFinder Server Edition, LabVIEW DataFinder Toolkit, and DIAdem Version 10.0 and later versions install and use a common software component (DataFinder client), which is refreshed by the installation of the DataFinder Server Edition. When you uninstall DataFinder Server Edition, the current version of the shared component remains. This is intentional and has been tested extensively.
    DataFinder Server Edition 1.0, LabVIEW DataFinder Toolkit 2009, DIAdem 9.0, LabWindows/CVI 8.1, and LabVIEW 7.1 and later versions install and use a common software component (USI), which is refreshed by the installation of the DataFinder Server Edition. When you uninstall DataFinder Server Edition, the current version of the shared component remains. This is intentional and has been tested extensively.
    New FeaturesNew Features in DataFinder Server Edition 2011
    Use the SQL Server Index Adaptor to integrate the DataFinder Server Edition in companies with existing Microsoft SQL server-database systems. DataFinder Server Edition in this case uses the features of the Microsoft SQL server for sophisticated, business critical applications, and can also be integrated into existing maintenance processes, for example backup/restore or optimization. To use the SQL server index-adaptor, you need Microsoft SQL Server 2005, SQL Server 2008, or SQL Server 2008 R2.
    New Features in DataFinder Server Edition 2010
    • You can now index individual files or folders in the browser view of a DataFinder Server.
    • You now can index files without filename extensions so that clients can search for and load these files.
    • You can specify a sorting order for the results before you start a query.
    Note  Specifying the sorting criteria with OrderBy might change the order of the search results compared to previous versions.
    Note  The new file property Folder speeds up queries for a file path. This means that you can no longer can use an existing custom property called Folder on the file level for queries.
    New Features in DataFinder Server Edition 2.1
    • Additionally to DIAdem you can now also use the LabVIEW DataFinder Toolkit as the client of the DataFinder Server Edition.
    • You can now create a separate indexer scheduler for each search area.
    • The performance of the index has been improved considerably.
    New Features in DataFinder Server Edition 2.0
    • In the advanced search of your client, connect several values for one search condition, or use OR to connect various search conditions, for example, to search for several filenames.
    • Use the security settings in DFSE to enable clients to search and browse only in the search areas you specify for sharing. The security settings are based on the rights that you configure in the standard Windows dialog boxes for sharing and security.
    • In co-operation with the S.E.R. company, DFSE has been linked to the DOXiS archiving system. This enables you to handle large amounts of technical data comfortably and inexpensively.
    • DFSE 2.0 supports the Windows Server 2008 operating system as well as Windows Server 2003.
    Known Issues in the DataFinder Server Edition 2011
    • If you install the DataFinder Server Edition 2011 on Windows Server 2008 R2, authentication may not be possible in some network environments. If the security settings of the DataFinder are active in such a network environment, DataFinder clients, such as DIAdem or DataFinder Toolkit, cannot establish a connection with a DataFinder server, even if they have the necessary access rights.
    © 2011 National Instruments Ireland Resources Limited. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2026-1-13 14:23
