查看: 3442|回复: 0
[NI软件产品] NI DataFinder Server Edition 2015 SP2 Win32Eng 数据查找服务器版DFSE2015SP2英语版下载
    发表于 2021-7-1 15:58:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    DataFinder Server
    DataFinder Server是一款应用软件,无论文件格式和网络位置如何,都可以搜索数据,而无需复杂的IT系统。
    DataFinder Server是一款集中式数据管理软件,可自动发现、标准化和管理工程数据,方便多个用户进行搜索。 与传统解决方案不同的是,DataFinder Server可直接索引计算机或网络上指定文件夹中的数据文件,而不需要构建数据库。 当文件发生更改时,DataFinder Server会自动重新组织,而无需让服务器脱机即可进行维护。 随着需求的增加,DataFinder Server可通过联合架构升级为部门级和企业级规模。
    DFSE2015
    文件大小: 240205824 字节 (229.08 MB)
    修改日期: 2021-05-10 11:26
    MD5: fe412a905cc06cb812bc9a7c8e7e57ca
    SHA1: 8fa2855c339f8b0cea3edf5782269817449e1f32
    SHA256: a326ecf0e3bc7788292c5010c3b3713d30bff448ea08643764dd36710c70f0cb
    CRC32: a0208aa0
    请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服
    DFSE2015SP2Eng.txt (733 Bytes, 下载次数: 1, 售价: 10 圆)
    DataFinder Server Edition 2015 SP2 Release Notes
    2015
    Version 15.0.2
    July 2016
    This file contains basic information on the DataFinder Server Edition 2015. The file contains the following information:
    Clients
    Corrected Errors and Incompatibilities
    Known Issues with the Microsoft SQL Adaptor
    Automatic_Installation_of_NI_Products
    How to Use NI Software with Microsoft Windows Server 2012
    NI DataFinder Server Edition Drops Support for Microsoft Windows Vista, Windows XP, Windows Server 2003, Windows Server 2003 R2, and Windows Server 2008 in 2016
    The following system requirements are estimated system requirements for DataFinder Server Edition. If your computer has less than the minimum system requirements, you cannot install the product correctly. The system requirements vary depending on your system configuration, the number of clients which access the server, and the number of data to be indexed.
    Minimum system requirements
    CPU2 Processor cores, clock frequency 1.4 GHz
    Memory2 GB
    Operating SystemsWindows Server 2008 R2 SP1, Windows Server 2012 including R2
    Recommended system requirements
    CPU4 to 8 processor kernels or more, clock frequency 2.5 GHz or more
    Memory16 GB or more
    Hard disks for operating system and index15.000 rpm SAS drives or SSD drives; National Instruments recommends storing the DataFinder index on a separate drive.
    Miscellaneous
    • Internet Explorer Version 6.0 Service Pack 1 or later
    • If you do not install DIAdem, you need the Windows Scripting Host if you use VBS-DataPlugins.
    Note  DataFinder Server Edition, LabVIEW DataFinder Toolkit, and DIAdem Version 10.0 and later versions install and use a common software component (DataFinder client), which is refreshed by the installation of the DataFinder Server Edition. When you uninstall DataFinder Server Edition, the current version of the shared component remains. This is intentional and has been tested extensively.
    DataFinder Server Edition 1.0, LabVIEW DataFinder Toolkit 2009, DIAdem 9.0, LabWindows/CVI 8.1, and LabVIEW 7.1 and later versions install and use a common software component (USI), which is refreshed by the installation of the DataFinder Server Edition. When you uninstall DataFinder Server Edition, the current version of the shared component remains. This is intentional and has been tested extensively.
    Note  DataFinder Server Edition does not support the volume license manager from National Instruments.
    Clients of DataFinder Server Edition 2015
    Some of the new features and improvements of DataFinder Server Edition can only be used with the respective National Instruments DataFinder clients.
    National Instruments recommends the use of the following products for the implementation of DataFinder Server Edition 2015.
    • DIAdem 2015
    • LabVIEW DataFinder Toolkit 2015
    If you are a member of a federation you can use DataFinder Server Edition 2014 or higher. Every program that supports the ASAM ODS CORBA interface, can connect to the DataFinder ASAM ODS server.
    New FeaturesNew Features in DataFinder Server Edition 2015
    • Backup and Restore DataFinder Servers
    • Improved search performance through column-oriented search
    • Continuous scan for new and changed files which are then indexed.
    • Display of extended statistical information about the indexed data
    • Automation interface for creating DataFinder servers and configuring the most important DataFinder server settings
    New Features in DataFinder Server Edition 2014
    • DataFinder Server Edition 2014 is a 64-bit application.
    • With the DataFinder federation server you can access up to 100 DataFinder servers simultaneously through a common interface.
    • You can configure the system storage, which the DataFinder index uses, in detail.
    • If you use DataFinder Server Edition 2014 as an ASAM ODS server or create a DataFinder federation, you can use the new dialog box in the DataFinder manager in order to create a user-defined navigation hierarchy. To do so, you use optimized custom properties from the file level or group level of the TDM data model without changing the data.
    • You can synchronize DataPlugins between DIAdem or LabVIEW clients and a DataFinder server.
    New Features in DataFinder Server Edition 2013
    • The security settings for DataFinder server has been revised. The permissions for the clients will continue to be set in the Windows permission dialog boxes, but the DataFinder saves all security settings with the program. You also can define individual security settings for individual search areas.
    • The DataFinder compresses the data to be transferred in order to increase throughput, especially in network environments with a low transfer rate.
    • Sort your indexed data stores,for example, according to year and month to get a different view. You can also filter the views.
    • You can now use the DataFinder Server Edition as ASAM ODS server:
      - Read-only ASAM ODS CORBA interface
      - Application model which can be extended during runtime (compatible with ASAM ODS version 5.3) with a user-defined test hierarchy and units catalog.
      - Windows Active Directory based security settings
      - UNICODE support
      - Generic ATF/XML support
    • You can now add search areas to a DataFinder server which the DataFinder Manager cannot access. This covers the case in which the DataFinder Manager is executed by a different user than the actual DataFinder server.
    • In the DataFinder Manager you can now search for updates of existing DataPlugins and install these DataPlugins by pressing a button.
    New Features in DataFinder Server Edition 2012
    • You can now enable automatic indexing of data in the search areas. You can specify whether the DataFinder indexes new or changed files immediately or whether a job file regularly executes the indexing tasks.
    • The DataFinder Server Edition can now refresh the content of the index more quickly because it uses several parallel indexing processes when indexing new and changed files.
    • You can use a scheduler to regularly optimize the index in order to process search queries more quickly.
    New Features in DataFinder Server Edition 2011
    Use the Microsoft SQL Server Index Adaptor to integrate the DataFinder Server Edition in companies with existing Microsoft SQL Server database systems. DataFinder Server Edition in this case uses the features of the Microsoft SQL Server for sophisticated, business critical applications, and can also be integrated into existing maintenance processes, for example backup/restore or optimization. To use the SQL Server index-adaptor, you need Microsoft SQL Server 2005, SQL Server 2008, or SQL Server 2008 R2.
    The following section lists some of the issues fixed in DataFinder Server Edition. This is not an exhaustive list of issues fixed in the current DIAdem version. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    Fixed Issues in DataFinder Server Edition 2015 SP2
    CAR IDDescription
    572307If in DataFinder Server Edition custom properties are excluded from optimization, DIAdem as a client does not display suggestion lists for optimized custom properties in versions prior to version 15.
    Fixed Issues in DataFinder Server Edition 2015 SP 1
    CAR IDDescription
    539169DataFinder Federations do not support an upgrade to the current version.
    537300Configuration files with filenames containing Unicode characters, for example, through the use of custom properties with Unicode characters in ASAM configurations, lead to storage and restore problems.
    535726Navigating from the last configured level of the ASAM tree to the file level might be slow.
    539165The automation interface for the configuration of DataFinder servers does not support the creation of backup copies of DataFinder Server versions before 2015.
    539167The specified backup interval for an active DataFinder server is not correctly displayed in the DataFinder manager or in the automation interface.
    560138When writing TDMS files in a search area of the DataFinder, LabVIEW sometimes creates invalid TDMS files.
    CAR IDDescription
    490875DataFinder does not allow you to specify a "Fully Qualified Server Name".
    434889DataFinder does not allow you to copy and paste the security settings of search areas.
    Incompatibilities of DataFinder Server Edition Version 2015 with Previous Versions
    • Indexing TDM files may lead to timeouts.
    • File information from disabled DataPlugins is no longer indexed.
    • Navigating in the tree view of the DataFinder manager no longer triggers automatic indexing. You can use the indexing function in the context menu instead.
    • Due to performance optimizations, the number of indexed groups and channels can no longer be determined from DIAdem or DataFinder Toolkit. Alternatively, you can use the statistics information of the DataFinder manager.
    Fixed Issues in DataFinder Server Edition 2014
    CAR IDDescription
    436239You can access an ASAM server without a password even if the the security settings are enabled.
    444626Famos cannot read any bulk data from National Instruments ASAM servers.
    475693The security settings of a search area cannot be exported or duplicated.
    Incompatibilities of DataFinder Server Edition Version 2014 with Previous Versions
    • You can no longer install DataFinder Server Edition on a 32-bit operating system.
    • You can no longer delete earlier DataFinder server versions in the DataFinder manager.
    • By default DataFinder Server Edition 2014 enables only TDM and TDMS DataPlugins when a new DataFinder server is created. If an ASAM ODS server is being created, the ATFX_TDM DataPlugin is also enabled. All further DataPlugins you need, you must enable manually.
    • DataFinder Server Edition 2014 searches for a search term with umlauts in the same way as for a search term without umlauts. Searching for a search term containing the letter Ä, for example, returns the results of a search for a search term with the letter A. The same applies for sorting search results with Order By.
    Fixed Issues in DataFinder Server Edition 2013
    If you install the DataFinder Server Edition on Windows Server 2008 R2, authentication may not be possible in some network environments. If the security settings of the DataFinder are active in such a network environment, DataFinder clients, such as DIAdem or DataFinder Toolkit, cannot establish a connection with a DataFinder server, even if they have the necessary access rights.
    Incompatibilities of DataFinder Server Edition Version 2013 with Previous Versions
    • Since version 2013, the DataFinder Server Edition has been using its own security settings instead of the Windows security settings.
    • When creating a new DataFinder index, the DataFinder no longer adds the register properties to the individual levels.
    • Earlier DataFinder servers can only be upgraded to version 2010.
    • From version 2013 the DataFinder Server Edition will show in the DataFinder manager only DataFinder servers up to and including 2010. If you want to use DataFinders from earlier versions, you can upgrade the DataFinder with an earlier version of the DataFinder manager to a version which supports the DataFinder Server Edition 2013. You can also create a new DataFinder server in the current version.
    • From Version 2013, the DataFinder Server Edition does not index the file, group, and channel properties with the names registertxt1 ... registertxt3, and the channel properties with the names registerint1 ... registerint6, and registerval1 ... registerval6. This means that these properties are no longer available for search queries.
    Fixed Issues in DataFinder Server Edition 2012
    The following list contains the CAR IDs and the descriptions of the problems solved between DataFinder Server Edition 2011 and DataFinder Server Edition 2012. Use the CAR ID to check the list whether the issue has been fixed.
    CAR IDDescription
    333333On Windows Server 2008 R2 or Windows 7, mapped network drives may not be displayed in the browser.
    You cannot use the DataFinder with a Microsoft SQL adaptor if the DataFinder is running on a computer with Microsoft Windows Server 2008 R2, or an earlier version. Install Microsoft Windows Server 2008 R2 Service Pack 1 to solve this error. Microsoft describes this problem on the Microsoft website in the KnowledgeBase entry 2640696. A hotfix for this issue is on the Microsoft website in the KnowledgeBase entry 983246.
    • Refer to KB 4CJDP38M, Automating the Installation of a Single Installer for more information on automatic installations of individual NI products.
    • Refer to KB 4CJDR18M, How Can I Determine the Type and Version of My National Instruments Installer? for a description of the version of the NI Installer your product contains.
    When you install National Instruments software on Microsoft Windows Server 2012, you will notice a few additional tiles on the Start screen, including shortcuts to NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher.
    Using NI Launcher
    Note  Unlike previous versions of Microsoft Windows Server 2012, MAX does not appear as a desktop shortcut. You can launch MAX either from the Start screen or from within NI Launcher.
    Current ApplicationProgram LocationPin to Action
    Windows Server 2012 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows Server 2012 DesktopStart screenRight-click application and select Pin to Start
    Windows Server 2012 Start PageDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    National Instruments DataFinder Server Edition Drops Support for Microsoft Windows Vista, Windows XP, Windows Server 2003, Windows Server 2003 R2, and Windows Server 2008 as of July 1, 2016. Versions of DataFinder Server Edition that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, Windows Server 2003, Windows Server 2003 R2, and Windows Server 2008. Windows Server 2008 R2 will continue to be supported after July 1, 2016.
    You can no longer install DataFinder Server Edition version 2014 and later on a 32-bit operating system.
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2006—2016 National Instruments Ireland Resources Limited. All rights reserved.
    Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, This includes photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation.
    • Legal notice: Notices are located in the \_Legal Information and directories.
    • EULAs: EULAs are located in the \Shared\MDF\Legal\license directory.
    • Information on including legal information in installers built with NI products: \_Legal Information.txt
    GMT+8, 2026-1-13 14:23
