查看: 4157|回复: 0
[NI软件产品] NI License Manager 3.7.0 Win32Eng NI许可证管理器NILM3.7.0
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-7-1 11:41:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI License Manager 3.7.2 Win32Eng NI许可证管理器NILM3.7.2
    License Manager可帮助您管理许可的NI软件资产。
    许可证管理器是实用程序软件,您可以使用它来激活、停用和传输带有许可证激活代码或许可证文件的软件许可证。许可证管理员可以使用许可证管理器自动激活产品并添加批量许可证服务器。
    License Manager helps you manage licensed NI software assets.
    License Manager is utility software that you can use to activate, deactivate, and transfer software licenses with license activation codes or license files. License administrators can use License Manager to automate product activation and add volume license servers.
    Win32Eng
    3.7
    文件大小: 77704590 字节 (74.10 MB)
    修改日期: 2019-06-25 03:01
    MD5: 5e08976d1d836a8c0d9906ff09715c21(官方正确)
    SHA1: 7b7b0df01faae4188c8b6477b075b28e03804da5
    SHA256: f3cbeb062ccfe2d939976b252eef6fdee3325ea776ea77e835a12315b5389504
    CRC32: aadc08fe
    注册登录视觉论坛会员购买附件查看下载地址
    LM3.7.2.txt (456 Bytes, 下载次数: 0, 售价: 10 圆)
    NI License Manager Readme
    Use the National Instruments License Manager to activate and manage your licenses or configure NI products on your system to obtain licenses from volume license servers.
    The following table contains a list of known issues in NI License Manager 3.7 and any available workarounds.
    IDKnown Issue
    136355, 136356Computers using older versions of NI software, such as NI TestStand 3.0, NI LabVIEW 7.1, or NI LabWindows™/CVI™ 7.0 cannot check out a license from a volume license server.
    Workaround: Contact NI technical support at support@ni.com for assistance in resolving this issue. Refer to KnowledgeBase article 475FE2QA for more information.
    The following table contains the IDs and titles of a subset of issues fixed in NI License Manager 3.7. This table is not an exhaustive list of issues fixed.
    220216Fixed an issue where disconnected licenses were not accounted for in NI License Manager in-use count.
    Note:  Requires NI Volume License Manager 3.0 or later.
    306393Fixed an issue where a Try Again/Continue/Cancel Media prompt appeared during activation if the media is changed.
    300220Fixed an issue where a bad network adapter caused activation to fail.
    129588Fixed an issue with enforcing the End User License Agreement (EULA) properly with temporary named-user licenses obtained from a volume license server.
    Important Information
    ©2004–2012 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-11-19 12:47
