查看: 3232|回复: 0
[NI软件产品] NI SystemLink Server 19.5.1 Win64Eng 系统连接服务器SLS19.5.1下载
    昨天 21:26
  • 签到天数: 3790 天
    连续签到: 41 天
    发表于 2021-6-29 17:36:28 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SystemLink Server
    SystemLink Server提供了启用所有SystemLink应用程序的数据、安全性和通信服务。
    SystemLink Server是安装所有SystemLink应用程序的核心,提供了数据、安全性和通信服务,确保每个SystemLink应用程序都能发挥最大作用。大部分工程实验室和制造环境要求工具必须符合所有IT和业务标准,而SystemLink Server正好可以满足企业对安全性、访问控制权限、容错、备份和远程管理的要求。
    受支持的操作系统
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    19.5.1
    文件大小: 1008648192 字节 (961.92 MB)
    修改日期: 2019-11-15 09:50
    MD5: e59c35ea587a697ee88ceb847c4772b1(重复一致,可秒传)
    SHA1: 05d67344d7cdfd955296947abda0ae54f85076ef
    SHA256: e230d51105b5fb8d28c6eadd9ea98fa82597d225f99cb0dd42b27793fca8bbdc
    CRC32: c545a62e
    系统连接服务器19.5.1.txt (558 Bytes, 下载次数: 0, 售价: 10 圆)
    NI SystemLink 19.5.1 Readme
    November 2019
    This file contains important information about NI SystemLink, including system requirements and known issues.
    Licensing Information for SystemLink Clients
    Use NI SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage SystemLink data services to visualize data, trigger alarms, monitor tests, manage assets, and transfer files to a server. SystemLink TDM is a Big Analog Data™ solution for automated preparation and analysis of large amounts of data in various formats and structures from different geographic locations.
    NI SystemLink has the following minimum system requirements:
    Server Requirements
    Windows, less than 50 nodes
    Windows, 50+ nodes, SystemLink TDM
    OS
    Windows Server 2016
    Windows Server 2012 R2 (64-bit)1
    Windows 7 SP1 (64-bit) or higher
    Windows Server 2016
    Processor
    4-core recommended or higher
    8-core recommended or higher
    RAM
    6 GB minimum
    16+ GB recommended
    16 GB minimum
    32+ GB recommended
    Disk
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    1 NI software installs VC2015 runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2, require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    Note  SystemLink TDM does not support server versions from the Microsoft Semi-Annual Channel. In addition, SystemLink TDM does not support Windows Server Core mode.
    Target Requirements (Managed Nodes)
    NI PXI (Windows) or Windows PC
    NI CompactRIO
    OS
    Windows 7 SP1 (32-bit) or higher
    NI Linux Real-Time 2019
    Processor
    Pentium 4 G1 (or equivalent) or later
    All Intel and ARM models supported
    RAM
    2 GB minimum
    4 GB recommended
    512 MB minimum
    1+ GB recommended
    Note: NI SystemLink does not support targets with less than 512 MB of RAM.
    Disk
    1 GB minimum
    2+ GB recommended
    512 MB
    Note: VxWorks and Phar Lap OS are not supported.
    Additional Requirements for Servers and Targets
    • .NET Framework 4.6.2
    • One of the following browsers:
      • Chrome
      • Firefox
      • Edge
      • Safari
    Note: NI SystemLink 19.5.1 web applications do not support Internet Explorer.
    Supported Software
    NI SystemLink 19.5.1 supports the following LabVIEW versions:
    • LabVIEW 2016, 2017, 2018, 2019
    • LabVIEW RT 2017, 2018, 2019
    SystemLink TDM supports the following DIAdem versions as clients:
    • DIAdem 2015, 2017, 2018, 2019 (recommended)
    SystemLink uses Volume License Manager to license server modules and add-ons as well as clients. Download NI Volume License Manager from ni.com and refer to the NI Volume License Manager help for more information on licensing.
    If you evaluate NI SystemLink Server before activating, any clients you connect will initially appear as Not Activated in Systems Manager. Use NI SystemLink Web Application to activate the client after you activate the server.
    Known IssuesYou can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in SystemLink.
    The following items are the IDs and titles of a subset of issues fixed in SystemLink. This is not an exhaustive list of issues fixed in the current version of SystemLink 19.5.1. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    591185Compare availability does not work for assets that have a period, underscore, or hyphen in their ID
    591511Asset Management service does not store utilization entries for systems with times set ahead of the server's set time
    591525Cannot install software on NI Linux RT 18.x targets using SystemLink Server 19.5
    591578Groups migration does not work correctly when upgrading from 19.0 to 19.5
    591660Cannot post jobs to a target when sysapi.get_props information returns a large amount of data
    591741Jobs History UI crashes if migrated jobs do not contain configuration information or metadata
    591844SystemLink client fails to reconnect to the server after installing a state
    591883Cannot update a step due to exception "not a valid 24 digit hex string"
    591909Update Results VI creates a new result instead of updating an existing result
    Refer to the NI SystemLink Manual, accessible from ni.com, for more information about NI SystemLink and the services and APIs it offers.
    © 2017-2019 National Instruments. All rights reserved.
    377243K-01
    GMT+8, 2026-2-2 06:24
