查看: 3167|回复: 0
[NI软件产品] NI SystemLink Server 19.0.0 Win64Eng 系统连接服务器SLS19.0.0下载
    昨天 21:26
  • 签到天数: 3790 天
    连续签到: 41 天
    发表于 2021-6-29 17:31:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SystemLink Server
    SystemLink Server提供了启用所有SystemLink应用程序的数据、安全性和通信服务。
    SystemLink Server是安装所有SystemLink应用程序的核心,提供了数据、安全性和通信服务,确保每个SystemLink应用程序都能发挥最大作用。大部分工程实验室和制造环境要求工具必须符合所有IT和业务标准,而SystemLink Server正好可以满足企业对安全性、访问控制权限、容错、备份和远程管理的要求。
    受支持的操作系统
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    19.0
    文件大小: 914839552 字节 (872.46 MB)
    修改日期: 2019-04-19 04:47
    MD5: 120c5208d3ff9d4bef434cbe3673cbf8(重复一致)
    SHA1: 43ced2ab2ef1c6ce0a27b5c740a6a0dda831e18b
    SHA256: 1fd02df576b45f864e35c976106e6daecca160dddae060c22c710d2b2ea8f4f9
    CRC32: 7ff4c477
    系统连接服务器19.0.0.txt (547 Bytes, 下载次数: 0, 售价: 10 圆)
    NI SystemLink 19.0 Readme
    April 2019
    This file contains important information about NI SystemLink, including system requirements and known issues.
    Licensing Information for SystemLink Clients
    Use NI SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage SystemLink data services to visualize data, trigger alarms, monitor tests, manage assets, and transfer files to a server.
    NI SystemLink has the following minimum system requirements:
    Server Requirements
    Windows, less than 50 nodes
    Windows, 50+ nodes
    OS
    Windows Server 2016
    Windows Server 2012 R2 (64-bit)
    Windows 7 SP1 (64-bit) or higher
    Windows Server 2016
    Processor
    2-core recommended or higher
    8-core recommended or higher
    RAM
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    Disk
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    Target Requirements (Managed Nodes)
    NI PXI (Windows) or Windows PC
    NI CompactRIO
    OS
    Windows 7 SP1 (32-bit) or higher
    NI Linux Real-Time 2019
    Processor
    Pentium 4 G1 (or equivalent) or later
    All Intel and ARM models supported
    RAM
    2 GB minimum
    4 GB recommended
    512 MB minimum
    1+ GB recommended
    Note: NI SystemLink does not support targets with less than 512 MB of RAM.
    Disk
    1 GB minimum
    2+ GB recommended
    512 MB
    Note: VxWorks and Phar Lap OS are not supported.
    Additional Requirements for Servers and Targets
    • .NET Framework 4.6.2
    • One of the following browsers:
      • Chrome
      • Firefox
      • Edge
      • Safari
    Note: NI SystemLink 19.0 web applications do not support Internet Explorer.
    LabVIEW Requirements
    NI SystemLink 19.0 supports the following LabVIEW versions:
    • LabVIEW 2015, 2016, 2017, 2018, 2019
    • LabVIEW RT 2017, 2018, 2019
    SystemLink uses Volume License Manager to license clients. Download NI Volume License Manager from ni.com and refer to the NI Volume License Manager help for more information on licensing.
    If you evaluate NI SystemLink Server before activating, any clients you connect will initially appear as Not Activated in Systems Manager. Use NI SystemLink Web Application to activate the client after you activate the server.
    Installing SystemLink onto a machine with TDM Server 2017 already installed will break TDM Server 2017. NI recommends you install SystemLink on a different machine or uninstall TDM Server 2017 prior to installing SystemLink.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in SystemLink.
    The following items are the IDs and titles of a subset of issues fixed in SystemLink. This is not an exhaustive list of issues fixed in the current version of SystemLink 19.0. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    727392SystemLink Server Configuration Technical Support Report does not collect Salt logs
    724295Command prompt windows generated during installation can be closed by the user leading to a failed installation
    716702WebVI hosted on SystemLink cannot use touch screen gestures to zoom in or out
    704197Users with only tag read access do not have permission to read tag history
    Refer to the NI SystemLink Help, accessible from ni.com, for more information about NI SystemLink.
    Refer to the SystemLink GitHub repository for examples and HTTP API documentation.
    © 2017-2019 National Instruments. All rights reserved.
    377243H-01
    GMT+8, 2026-2-2 06:24
