查看: 3509|回复: 0
[NI软件产品] NI SystemLink Server 18.1.1 Win64Eng 系统连接服务器SLS18.1.1下载
    昨天 21:26
  • 签到天数: 3790 天
    连续签到: 41 天
    发表于 2021-6-29 17:15:34 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SystemLink Server
    SystemLink Server提供了启用所有SystemLink应用程序的数据、安全性和通信服务。
    SystemLink Server是安装所有SystemLink应用程序的核心,提供了数据、安全性和通信服务,确保每个SystemLink应用程序都能发挥最大作用。大部分工程实验室和制造环境要求工具必须符合所有IT和业务标准,而SystemLink Server正好可以满足企业对安全性、访问控制权限、容错、备份和远程管理的要求。
    受支持的操作系统
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    18.1.1
    文件大小: 1014365608 字节 (967.37 MB)
    修改日期: 2018-10-05 22:47
    MD5: b9a6ee048639b7918fbeec8227699dae(重复一致)
    SHA1: 0e3ff1981d36d1fc7dc602303dc1bb4254efb24f
    SHA256: 8b5f8b12e906a1153a60faaa21805be974be733e942484711e0582923ebb9e53
    CRC32: 4f177889
    系统连接服务器18.1.1.txt (550 Bytes, 下载次数: 0, 售价: 10 圆)
    NI SystemLink 18.1 Readme
    July 2018
    This file contains important information about NI SystemLink, including system requirements and known issues.
    Licensing Information for SystemLink Clients
    Use NI SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage Skyline data services to visualize data, trigger alarms, monitor tests,and transfer files over a server.
    NI SystemLink has the following minimum system requirements:
    Server Requirements
    Windows, less than 50 nodes
    Windows, 50+ nodes
    OS
    Windows Server 2016
    Windows Server 2012 R2 (64-bit)
    Windows Server 2008 R2 (64-bit)
    Windows 7 SP1 (64-bit) or higher
    Windows Server 2016
    Processor
    2-core recommended or higher
    8-core recommended or higher
    RAM
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    Disk
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    Target Requirements (Managed Nodes)
    NI PXI (Windows) or Windows PC
    NI CompactRIO
    OS
    NI Linux Real-Time 2018
    Processor
    Pentium 4 G1 (or equivalent) or later
    All Intel and ARM models supported
    RAM
    2 GB minimum
    4 GB recommended
    512 MB minimum
    1+ GB recommended
    Note: NI SystemLink does not support targets with less than 512 MB of RAM.
    Disk
    1 GB minimum
    2+ GB recommended
    512 MB
    Note that VxWorks and Phar Lap OS are not supported.
    Additional Requirements for Servers and Targets
    • .NET Framework 4.6.2
    • One of the following browsers:
      • Chrome
      • Firefox
      • Edge
      • Internet Explorer
      • Safari
    LabVIEW Requirements
    NI SystemLink 18.1 supports the following LabVIEW versions:
    • LabVIEW 2015, 2016, 2017, 2018
    • LabVIEW RT 2017, 2018
    SystemLink uses Volume License Manager to license clients. Download NI Volume License Manager from ni.com and refer to the NI Volume License Manager help for more information on licensing.
    If you evaluate NI SystemLink Server before activating, any clients you connect will initially appear as Not Activated in Systems Manager. Use NI SystemLink Web Application to activate the client after you activate the server.
    Installing SystemLink onto a machine with TDM Server 2017 already installed will break TDM Server 2017. NI recommends you install SystemLink on a different machine or uninstall TDM Server 2017 prior to installing SystemLink.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in SystemLink.
    The following items are the IDs and titles of a subset of issues fixed in SystemLink 18.1. This is not an exhaustive list of issues fixed in the current version of SystemLink. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    699210High CPU usage on Linux RT Salt Minions
    702585Uninstall button enabled for target's essential software
    700688Cannot install the Skyline Test Monitor Support for TestStand on machines without the TestStand Development Environment
    702587Available Feeds tab times out while trying to load the available feeds for a managed system
    698874Dashboard Builder does not update in web browser if you have used a previous version
    The following items are the IDs and titles of additional issues fixed in SystemLink 18.1.1.
    ID
    Fixed Issue
    706519Periods in device names cause managed systems to appear disconnected
    707573Missing dependency on startup can cause services crash loop
    Refer to the NI SystemLink Help, accessible from ni.com, for more information about NI SystemLink.
    © 2017-2018 National Instruments. All rights reserved.
    377243D-01
    GMT+8, 2026-2-2 06:24
