查看: 3758|回复: 0
[LV工具模块] LabVIEW SystemLink Toolkit 2021R1.1 x64Win10 32/64bitEng LabVIEW系统连接工具包SLT21.0.1下载
    昨天 16:26
  • 签到天数: 3674 天
    发表于 2021-6-29 15:31:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW SystemLink工具包提供了LabVIEW或LabVIEW NXG与SystemLink Server或SystemLink Cloud账户进行通信的工具。
    LabVIEW SystemLink工具包是一个软件附件,包含用于LabVIEW的SystemLink API。该附件可通过编程方式访问SystemLink数据服务,这样就可在SystemLink Web应用程序之外集成SystemLink和LabVIEW。您可以使用LabVIEW SystemLink工具包为测试和测量系统创建VI或WebVI。
    2021R1.1V21.0.1
    文件大小: 358692864 字节 (342.08 MB)
    修改日期: 2021-05-13 03:15
    MD5: 56112bad351552edc5235bae38e92c52(官方正确)
    SHA1: 0d45f53a9bd1275180685796f937df85a11c559f
    SHA256: 2924deae4db0c3d03dfefc1310bc865c1dccfb0bbe3571b475c6d1397c190734
    CRC32: 33d79632
    系统连接LV支持工具包21.0.1.txt (587 Bytes, 下载次数: 0, 售价: 10 圆)
    NI SystemLink 2021 R1 Readme
    April 2021
    This file contains installation instructions and compatibility information for SystemLink.
    • SystemLink Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • SystemLink Manual: New features, behavior changes, and other documentation
    Use SystemLink to discover and manage systems on a server. Create and deploy packages to all your managed systems. Leverage SystemLink data services to visualize data, trigger alarms, monitor tests, manage assets, and transfer files to a server. SystemLink TDM is a Big Analog Data™ solution for automated preparation and analysis of large amounts of data in various formats and structures from different geographic locations.
    SystemLink has the following minimum system requirements:
    Server Requirements
    Windows, less than 50 nodes
    Windows, 50+ nodes, SystemLink TDM
    OS (64-bit only)
    Windows Server 2019 R2
    Windows Server 2016
    Windows 10 or higher
    Windows Server 2016
    Processor
    4-core recommended or higher
    8-core recommended or higher
    RAM
    16 GB minimum
    32+ GB recommended
    32 GB minimum
    64+ GB recommended
    Disk
    6 GB minimum
    8+ GB recommended
    16+ GB recommended
    Note:  SystemLink TDM does not support server versions from the Microsoft Semi-Annual Channel. In addition, SystemLink TDM does not support Windows Server Core mode.
    Target Requirements (Managed Nodes)
    NI Linux Real-Time
    OS
    Windows 7 SP1 (64-bit) or higher
    Windows 7 SP1 (32-bit) or higher
    NI Linux Real-Time 2019, 2020
    (Supports LabVIEW RT 2019, 2020, and NXG 5.0 and later)
    Processor
    Pentium 4 G1 (or equivalent) or later
    All Intel and ARM models supported
    RAM
    2 GB minimum
    4 GB recommended
    512 MB minimum
    1+ GB recommended
    Disk
    1 GB minimum
    2+ GB recommended
    512 MB
    Note: VxWorks and Phar Lap OS are not supported.
    Additional Requirements for Servers and Targets
    • .NET Framework 4.6.2
    • Latest version of one of the following browsers:
      • Chrome
      • Firefox
      • Edge (Chromium)
      • Safari
    Note: SystemLink 2021 R1 does not support Microsoft Edge Legacy versions (version 44 and below).
    Note:  Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    For more information about the changes to our OS support, visit http://www.ni.com/r/win32bitsupport.
    SystemLink 2021 R1 supports the following application software versions, including service packs.
    Versions Supported by SystemLink
    LabVIEW2017 and later
    LabVIEW RT2017 and later
    LabVIEW NXG5.0 and later
    TestStand2014 and later
    DIAdem2015 and later (2020 recommended)
    NI SystemLink Python SDK3.7 and 3.8
    Note: SystemLink TDM Analysis Automation does not support NI SystemLink Python 3.8 SDK. To use Python scripts in Analysis Automation, select NI SystemLink Python 3.7 SDK under “Additional items you may wish to install” when installing SystemLink Suite.
    Download the SystemLink 2021 R1 installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate SystemLink. For more information on SystemLink activation, refer to NI Software Activation.
    Refer to the SystemLink Help, accessible from ni.com, for information about SystemLink.
    Refer to the following SystemLink repositories on GitHub for SystemLink code examples:
    • SystemLink Server Examples
    • SystemLink Client Docs
    The following sections detail considerations for using LabVIEW NXG 5.0 and later with SystemLink 2021 R1.
    • Operating system—Only 64-bit operating systems are supported.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    SystemLink no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit http://www.ni.com/r/win32bitsupport.
    © 2021 National Instruments Corporation. All rights reserved.
    377243T-01
    GMT+8, 2025-10-8 00:16
