查看: 3163|回复: 0
[NI软件产品] Semiconductor Device Control Add-On 2020 for InstrumentStudio Win64Eng 用于NI InstrumentStudio的半导体设备控制附加软件2020下载ni-semi-device-control_20.0.0
    6 小时前
  • 签到天数: 3808 天
    发表于 2021-6-29 11:33:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    InstrumentStudio的半导体设备控制附加软件提供了交互式的设备控制功能,可通过快速缩放来实现自动验证。
    InstrumentStudio半导体设备控制附加软件是一个软件附加软件,可帮助您使用I2C、SPI或RFFE等标准数字协议或自定义协议来执行交互式寄存器读/写操作。您可以保存InstrumentStudio项目或导出设置,以便在LabVIEW、Python、.NET或TestStand中进行自动验证。InstrumentStudio可以与自动化应用程序并行使用,来实时监测和调试设备控制任务。InstrumentStudio的半导体设备控制附加软件也可与I2C/ SPI接口设备和PXI数字码型仪器配合使用,帮助您在执行交互式和自动化半导体验证时轻松完成常见的任务。
    2020
    语言
    English
    发布日期
    2021/3/25
    Windows 7 (SP1) 64-bit
    Windows 8.1 64-bit
    Windows Server 2012 R2 64-bit
    程序位数
    64位
    校验和
    文件大小: 329779200 字节 (314.50 MB)
    修改日期: 2021-03-25 05:00
    MD5: e93c386cc47adbaf39d738eb88f6b774(官方正确)
    SHA1: 9ec0f92675a6c27a09d08d4c01153c8830829b01
    SHA256: b88a9ea23ed06e33fb0caf59c02288fc74ba86b422d9559831d5ba1771e7ccb7
    CRC32: 81f38ce6
    仪器套件附加软件2020.txt (1.34 KB, 下载次数: 0, 售价: 10 圆)
    Semiconductor Device Control Add-On for InstrumentStudio 2020 Readme
    March 2021
    This file contains installation instructions and compatibility information for Semiconductor Device Control Add-On for InstrumentStudio.
    • Semiconductor Device Control Add-On for InstrumentStudio Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • Semiconductor Device Control Add-On for InstrumentStudio Manuals: New features, behavior changes, and other documentation
    Supported Hardware & Protocols
    Semiconductor Device Control Add-On Drops Support for Windows 7 (64-Bit) Operating Systems in 2021
    The Semiconductor Device Control Add-On for InstrumentStudio is a software add-on that helps you perform interactive register read/write operations using common or custom digital protocols. This InstrumentStudio add-on supports general hardware control tasks using static I/O and can be used in parallel with automated applications to monitor and debug device control tasks in real time.
    The Semiconductor Device Control Add-On has the following requirements:
    • Pentium 4 G1 equivalent or later (Intel i5 equivalent or later recommended)
    • At least 10 GB of disk space
    • 4 GB RAM
    • 1024 x 768 screen resolution (1366 x 768 or higher recommended)
    The Semiconductor Device Control Add-On supports the following operating systems:
    • Windows 10 (64-bit only)
    • Windows 8.11 (64-bit only)
    • Windows 7 SP1 (64-bit only)
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require pdates to support SHA-256. Refer to Microsoft KB3033929 and KB3125574 for more information about how to install these updates.
    Note  Refer to Semiconductor Device Control Add-On Drops Support for Windows 7 (64-Bit) Operating Systems in 2021 for information about future OS support.
    Semiconductor Device Control Add-On supports the following application software versions, including service packs.
    Versions Supported by Semiconductor Device Control Add-On
    InstrumentStudio2019 SP1, 2020 ( all 64-bit only)
    LabVIEW2017 SP1, 2017 SP1 Patch, 2018 SP1, 2018 SP1 Patch, 2019, 2019 SP1, 2020 (all 64-bit only)
    NI TestStand2019, 2020 (all 64-bit only)
    Python3.6 or above (all 64-bit only)
    .NET framework4.6.2 or higher (all 64-bit only)
    Device Drivers
    NI-Digital Pattern Driver19.0.1, 20.6 (all 64-bit only)
    NI-845x Driver Support20.0 (64-bit only)
    If you are using the Semiconductor Device Control Add-On .NET Class Library, .NET Framework 4.6.2 (minimum) is required. The Semiconductor Device Control Add-On .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.6.2 or higher.
    To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to NI .NET Support.
    Installing Semiconductor Device Control Add-On with NI Package Manager
    NI installs the Semiconductor Device Control Add-On using NI Package Manager. If you do not already have NI software installed, the Semiconductor Device Control Add-On installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate the Semiconductor Device Control Add-On. For more information on Semiconductor Device Control Add-On activation, refer to NI Software Activation.
    Supported Hardware & Functions
    The following list details the hardware models & functions supported in Semiconductor Device Control Add-On.
    Hardware Models
    Protocols
    Channels
    Custom Timings
    PXIe-6570, PXIe-6571I2C, 3-wire SPI, 4-wire SPI, RFFEDIO, PPMUdEVM RFFE, dEVM SPI
    USB-8451, USB-8452I2C, 4-wire SPI, DIODIO
    Refer to the Semiconductor Device Control Add-On for InstrumentStudio Manual, accessible from ni.com/manuals, for information about the Semiconductor Device Control Add-On.
    The Semiconductor Device Control Add-On includes several example projects that you can use to learn key concepts or use as a starting point for applications you create.
    Navigate to %Public%\Documents\National Instruments\Semi Device Control (64-bit)\Examples in File Explorer to view the example projects that are installed with the Semiconductor Device Control Add-On.
    LabVIEW API Examples
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Semiconductor Device Control Add-On are located in the labview\examples\Semi Device Control directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Semiconductor Device Control Add-On will drop support for Windows 7 (64-bit) operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2020–2021 National Instruments Corporation. All rights reserved.
    377565B-01
    GMT+8, 2026-2-25 16:50
