查看: 3646|回复: 0
[NI软件产品] NI InstrumentStudio 2021 Win64Eng NI仪器套件InstrumentStudio21.0.0
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-6-29 11:11:50 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    InstrumentStudio
    InstrumentStudio是一款免费的应用程序软件,提供了集成的交互式PXI测量方法。
    InstrumentStudio可帮助您统一显示数据,将仪器配置导出到代码,并监测和调试您的自动测试系统。 您可以使用大型高分辨率显示器在统一显示界面上查看数据,然后捕获多仪器屏幕截图和测量结果。 您还可保存项目级配置,以便针对特定的待测设备更轻松地重复进行测试,或将仪器配置导出到编程环境,以简化代码并保证测量相关性。您还可以同时使用代码和InstrumentStudio来监测和调试正在运行的测试应用程序。
    2021
    21.0.0
    文件大小: 1608472576 字节 (1.50 GB)
    修改日期: 2021-04-22 21:46
    MD5: ebd25b08862d2e9c0b4ccdf643af057a
    SHA1: e46e5c893684f593c4ca3238868baa8fcbef7708
    SHA256: be71c068578faa0ebbc4f2f19fb9b266c97b297b6b829490de0692b98005fc52
    CRC32: f9249668
    仪器套件2021.txt (548 Bytes, 下载次数: 0, 售价: 10 圆)
    InstrumentStudio 2021 Readme
    April 2021
    This file contains important information about InstrumentStudio 2021, including supported hardware and operating systems, a partial list of bugs fixed, and known issues.
    InstrumentStudio allows you to generate and acquire measurements from multiple devices within a single application. You can also use InstrumentStudio to monitor and control devices being used in external applications, capture data files, export device configuration to other applications, and more.
    InstrumentStudio 2021 has the following requirements:
    • Pentium 4 G1 equivalent or later (Intel i5 equivalent or higher recommended)
    • 4 GB RAM
    • 10 GB disk space
    • 1024 x 768 screen resolution (1366 x 768 or higher recommended)
    InstrumentStudio 2021 supports the following operating systems:
    • Windows 10 64-bit
    • Windows Server 2016 64-bit
    InstrumentStudio 2021 supports the creation of soft front panels with the following device drivers:
    Device Driver
    Minimum Version Supported by InstrumentStudio 2021
    NI-SCOPE20.7
    NI-FGEN19.1
    NI-DMM18.1
    NI-DCPOWER20.6
    NI-RFSG20.7
    Installing Instructions
    Download the Instrument Studio 2020 installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    New FeaturesInstrumentStudio 2021
    • Added new RFSG Signal Generator panel supporting interactive use and debugging using PXIe-5820, PXIe-5830, PXIe-5831, PXIe-5832, PXIe-5840, and PXIe-5841.
    • Added support for the PXIe-4135(35W) and PXIe-4137(35W) source measure unit, newly supported in NI-DCPOWER 20.7.
    InstrumentStudio 2020
    • Added support for the PXIe-4139(40W) source measure unit, newly supported in NI-DCPower 20.5.
    • Added support for multichannel session in the SMU/Power Supply panel, newly supported in NI-DCPower 20.6. Initializing an NI-DCPower session with independent channels allows you to use multiple instruments in the same session. With independent channels, you can configure multiple channels of the same instrument, or of multiple instruments independent of one another within the same session.
    • Added support for monitoring merged channels in debug mode on the PXIe-4147. Merged channels are newly supported in NI-DCPower 20.6. Merging channels of an NI SMU allows you to use multiple channels in unison to increase the current you can source beyond the normal maximum for a single SMU channel.
    InstrumentStudio 2019 SP1
    • Added support for the PXIe-4147 source measure unit, newly supported in NI-DCPower 20.0.
    • Added power spectral density measurements to oscilloscope FFT channels.
    • Multiple NI-SCOPE devices of the same model can now be synchronized in the same oscilloscope panel.
    • Added support for selecting trigger sources and events from other NI devices in your system.
    • Added waveform graphing, pulse current, pulse voltage, voltage sequence, and current sequence modes to SMU panels, including automatic hardware synchronization across multiple devices.
    • Added asymmetric limits and software-protected ranges to SMU/Power Supply panels.
    • Added NI-DCPower SourceAdapt configuration to SMU panels, useful for transient measurements.
    • Added channel views to hide idle channels, show power calculations, and condense channel views to the SMU/Power Supply panels.
    • Added inductance and capacitance measurements along with open and short cable compensation to digital multimeter (DMM) panels.
    • Added the ability to generate waveforms from binary files to the waveform generator panel.
    • Added debugging and monitoring support to the waveform generator panel.
    • Added exporting configuration files from the waveform generator panel for use with the NI-FGEN driver.
    • Added capability to export device configurations to TestStand for use in test step configuration.
    • Added ability to use pin maps created in Digital Pattern Editor to group devices and channels by site and use pin names for channel aliases.
    InstrumentStudio 2018 SP2
    • Added support for the PXIe-5163 oscilloscope, newly supported in NI-SCOPE 18.7.
    • Added CSV file format for data capture.
    • Added support for exporting instrument events to PXI chassis trigger lines.
    • Added support for arbitrary waveform generation mode to the Waveform Generator panels.
    • Added support for frequency list and sweep modes to the Waveform Generator panels.
    • Added FFT channels, frequency markers, and FFT channel measurements to the Oscilloscope panels.
    • Added additional 2-channel measurements to the Oscilloscope panels.
    InstrumentStudio 2018 SP1
    Added support for the PXIe-5110, PXIe-5111, and PXIe-5113 oscilloscopes, newly supported in NI-SCOPE 18.6
    The following hardware models are supported in InstrumentStudio 2021:
    NI-DCPOWER Devices
    • PXIe-4112
    • PXIe-4113
    • PXIe-4135
    • PXIe-4135(35W)
    • PXIe-4136
    • PXIe-4137
    • PXIe-4137(35W)
    • PXIe-4138
    • PXIe-4139
    • PXIe-4139(40W)
    • PXIe-4140
    • PXIe-4141
    • PXIe-4142
    • PXIe-4143
    • PXIe-4144
    • PXIe-4145
    • PXIe-4147
    • PXIe-4154
    • PXIe-4162
    • PXIe-4163
    • PXI-4110
    • PXI-4130
    • PXI-4132
    NI-DMM Devices
    • PXIe-4080
    • PXIe-4081
    • PXIe-4082
    • PXI-4065
    • PXI-4070
    • PXI-4071
    • PXI-4072
    • PCI-4065
    • PCIe-4065
    • USB-4065
    • PCI-4070
    NI-FGEN Devices
    • PXIe-5413 (1-channel)
    • PXIe-5413 (2-channel)
    • PXIe-5423 (1-channel)
    • PXIe-5423 (2-channel)
    • PXIe-5433 (1-channel)
    • PXIe-5433 (2-channel)
    • PXIe-5442
    • PXIe-5450
    • PXIe-5451
    • PXI-5402
    • PXI-5404
    • PXI-5406
    • PXI-5412
    • PXI-5421
    • PXI-5422
    • PXI-5441
    • PCI-5402
    • PCI-5406
    • PCI-5412
    • PCI-5421
    NI-SCOPE Devices
    • PXIe-5105
    • PXIe-5110
    • PXIe-5111
    • PXIe-5113
    • PXIe-5114
    • PXIe-5122
    • PXIe-5160 (2-channel)
    • PXIe-5160 (4-channel)
    • PXIe-5162 (2-channel)
    • PXIe-5162 (4-channel)
    • PXIe-5163
    • PXIe-5164
    • PXIe-5170 (4-channel)
    • PXIe-5170 (8-channel)
    • PXIe-5171 (8-channel)
    • PXIe-5172 (4-channel)
    • PXIe-5172 (8-channel, 325T)
    • PXIe-5172 (8-channel, 410T)
    • PXIe-5185
    • PXIe-5185 (1MΩ)
    • PXIe-5186
    • PXIe-5186 (1MΩ)
    • PXIe-5622
    • PXIe-5622 (DD)
    • PXI-5105
    • PXI-5114
    • PXI-5122
    • PXI-5124
    • PXI-5142
    • PXI-5152
    • PXI-5153
    • PXI-5154
    • PXI-5922
    • PCI-5105
    • PCI-5114
    • PCI-5122
    • PCI-5124
    • PCI-5142
    • PCI-5152
    • PCI-5153
    • PCI-5154
    • PCI-5922
    • PCIe-5155
    • USB-5132
    • USB-5133
    NI-RFSG Devices
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5840
    • PXIe-5841
    You can access the software and documentation known issues list online. Refer to InstrumentStudio 2021 Known Issues on ni.com for an up-to-date list of known issues in InstrumentStudio.
    You can access a list of issues fixed in InstrumentStudio 2021 online. Visit InstrumentStudio 2021 Bug Fixes for an up-to-date list of fixed issues. This is not an exhaustive list of issues fixed in the current version of InstrumentStudio. If you have a Bug ID, you can search this list to validate that the issue has been fixed. .
    © 2021 National Instruments. All rights reserved.
    377562G-01
    GMT+8, 2025-11-19 12:45
