查看: 3571|回复: 0
[NI软件产品] BIOS Secure Delivery CD 2021 Win32/64Eng BIOS安全供应光盘2021
    4 小时前
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-6-29 10:57:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    BIOS Secure Delivery CD 2021 Win32/64Eng BIOS安全供应光盘2021BIOS安全供应光盘是NI控制器的BIOS固件升级光盘。支持的控制器,请参考后面的自述文件。
    2021
    文件名: BIOS Secure Delivery CD安全供应光盘\502170F-01M_v1.5.0f2.iso
    文件大小: 719220736 字节 (685.90 MB)
    修改日期: 2021-04-22 09:18
    MD5: e2fdd8a98c601c199ffc16ca6a25b929(官方正确)
    SHA1: 7684a455aac8467e8b35df77b36a3372f860a88a
    SHA256: bfd405f8a1d2fe0c4eb5c45d5e2c039290bbc6d876a3d9bed18b52f6aa48e001
    CRC32: 8fc2ee34
    BISIO SDCD2021.txt (557 Bytes, 下载次数: 0, 售价: 5 圆)
    BIOS Update CD Readme
    April 2021
    This file contains important information about the BIOS Update CD, including instructions to update the BIOS.
    BIOS Versions
    Intel® AMT Firmware Patch
    This CD includes the latest BIOS for supported controllers. Refer to the BIOS Versions table below for the supported controller models.
    Caution: Flashing this BIOS will reset your CMOS default settings. Record changes you have made to them prior to flashing this BIOS.
    BIOS Patch supports the following platforms. For the most up-to-date BIOS, visit ni.com.
    • Windows 10 (32-bit and 64-bit)
    • Windows 8.1 (32-bit and 64-bit)
    • Windows 7 with SP1 or later (32-bit and 64-bit)
    • Windows Vista with SP2 or later (32-bit)
    • Windows XP with SP3 or later (32-bit)
    • Windows Server 2008 R2 with SP2 or later (64-bit)
    Note: Some hardware may not support all operating systems listed above. Consult your hardware documentation for more information.
    Updating to the Latest BIOSInstallation Instructions
    The BIOS for this controller is larger than the storage available on a single floppy. You need a USB flash drive to boot the controller and flash the BIOS from DOS.
    Complete the following steps to install the update:
    • Obtain a USB flash drive that may be overwritten if necessary.
    • Convert the USB flash drive to a bootable device that can boot DOS or EFI Shell by running CreateUSBUtilityDisk.exe.
    • Insert the USB flash drive into your controller. Complete the following steps to set up your controller to boot first from the USB flash drive:
      • While the controller boots, press to enter the BIOS Setup Utility. (Note all changes made. You may need to reset them after completing the BIOS update.)
      • Navigate to LabVIEW RT»Boot Configuration and ensure that Windows/Other OS is set. If you changed anything, press to save and reboot.
      • If needed, while rebooting press to enter the BIOS Setup Utility again.
      • Navigate to Advanced»SATA Configuration»SATA Mode Selection and select IDE.
      • Navigate to Advanced»USB Configuration and enable Legacy USB Support.
        • This setting is not required for BIOS update via EFI Shell
      • Navigate to Advanced»USB Configuration»Mass Storage Devices and select Auto.
      • Navigate to Boot»Hard Drive BBS Priorities and move USB to the top of the list (Boot Option #1).
      • Navigate to Boot»Boot Option #1 and make sure USB is at the top of the list.
      • Press to save and reboot.
    • Once the controller boots into DOS or EFI Shell, follow the onscreen instructions to flash your BIOS.
    • Once the system starts the BIOS update process, be sure to let the program complete. Failure to do so will corrupt the system, and it will not boot.
    • Once the program finishes, remove the USB flash drive and reboot the controller.
    • If a problem occurs during the flash, contact National Instruments technical support for assistance.
    Update BIOS using PXI Controller Firmware PackageInstallation Instructions
    Complete the following steps to update PXI Controller Firmware Package:
    • Download and save the firmware image for your PXI controller to the system containing the controller that needs updating. If the system containing the controller is running RT OS, download and save the firmware image to the host machine instead.
    • On the host system, use NI Measurement & Automation Explorer (MAX) to upgrade the firmware. You must run MAX with administrator privileges.
      • For Windows Systems: Open MAX and expand Devices and Interfaces under the My System tab.
      • For RT systems: From the host machine, open MAX and expand Remote Systems. Expand the target system and expand Devices and Interfaces.
    • For the controller to be updated:
      • Expand the Chassis tab and select the controller needing the firmware update.
      • Click the Update Firmware button in the right pane.
      • Navigate to and select the firmware image file saved in step 1, then click the Open button.
        • A dialog box should open containing information about the firmware image selected.
      • Click Begin Update to confirm and start the update.
    • Follow any additional instructions provided when the update is complete.
      • If the dialog says an issue occurred, record the error number/message and contact National Instruments.
    Visit ni.com/support/security to view and subscribe to receive security notifications about NI products. Visit ni.com/product-documentation/13503/en/ for information about critical updates from NI.
    BIOS Versions
    The following table lists the BIOS versions this CD contains and the supported controllers.
    BIOSVersionSupported Model
    PXI-81082.0.5f0PXI-8108
    PXIe-81082.0.5f0PXIe-8108
    cRIO-903x1.3.5f1cRIO-9030, cRIO-9031, cRIO-9033, cRIO-9034, cRIO-9035, cRIO-9036, cRIO-9038, cRIO-9039
    cRIO-903x_WiFi1.3.3f0cRIO-9032, cRIO-9037
    cDAQ-913x1.3.2f0cDAQ-9132, cDAQ-9133, cDAQ-9134, cDAQ-9135, cDAQ-9136, cDAQ-9137
    CVS-1459RT1.3.3f1CVS-1458RT, CVS-1459RT
    CVS-14591.3.5f100CVS-1458, CVS-1459
    IC-3121RT1.3.4f0IC-3120RT, IC-3121RT
    IC-31211.3.4f100IC-3120, IC-3121
    cRIO-905x2.1.2f0cRIO-9053, cRIO-9054, cRIO-9055, cRIO-9056, cRIO-9057, cRIO-9058
    sbRIO-96x82.1.2f0sbRIO-9603, sbRIO-9608, sbRIO-9609, sbRIO-9628, sbRIO-9629, sbRIO-9638
    cRIO-904x2.0.0f0cRIO-9041, cRIO-9040, cRIO-9042, cRIO-9043, cRIO-9045, cRIO-9046, cRIO-9047, cRIO-9048, cRIO-9049
    PXIe-8840QC2.1.11f0PXIe-8840QC, PXIe-8821
    PXI-8840QC2.0.2f0PXI-8840QC
    IC-31731.1.3f0IC-3173, IC-3172, IC-3171
    PXIe-81331.2.4f2PXIe-8133
    PXI-81091.2.4f2PXI-8109
    cRIO-908x1.2.4f2cRIO-9081, cRIO-9082
    cDAQ-91391.2.4f2cDAQ-9138, cDAQ-9139
    PXIe-81351.2.10f0PXIe-8135, PXIe-8860
    PXI-81191.9.1f0PXI-8119
    PXI-88201.0.2f0PXI-8820
    PXIe-88201.2.2f0PXIe-8820
    PXIe-88802.1.10f0PXIe-8880
    PXIe-81001.0.1f4PXIe-8100
    CVS-1451RT1.0.1f4CVS-1451RT
    CVS-1457RT1.0.1f4CVS-1457RT
    PXIe-81151.0.2f0PXIe-8115
    PXI-81151.0.2f0PXI-8115
    PXIe-88402.1.5f0PXIe-8840
    PXI-88402.0.4f0PXI-8840
    PXIe-8830mc1.0.1f0PXIe-8830mc
    USRP-29741.0.4f0USRP-2974
    PXIe-886120.5.0f0PXIe-8861 (Firmware Package)
    PXIe-888120.5.1f0PXIe-8881 (Firmware Package)
    Applying Intel AMT FixesIntel AMT Firmware Patch
    Refer to ni.com/product-documentation/53841/en for more information about the Intel AMT firmware patch.
    © 2021 National Instruments. All rights reserved.
    378302A-01
    GMT+8, 2025-11-19 12:45
