查看: 3258|回复: 0
[NI驱动程序] NI-RFSG Playback Library 20.7 x64Win10 32/64bitEng NI-RFSG回放库20.7完整版下载
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2021-6-2 12:16:05 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG Playback Library扩展了NI-RFSG驱动软件的功能,可简化NI信号发生器的波形管理和回放。
    NI-RFSG Playback Library是一款驱动附件,可利用NI-RFSG简化波形管理和回放。该软件可以从文件中读取波形,将波形下载到仪器存储器,并管理采样率、峰均功率比(PAPR)、运行时缩放等波形特性。NI-RFSG Playback Library可根据存储的波形特性自动配置仪器设置,使您可以使用NI信号发生器轻松地回放波形。
    20.7 32/64
    文件大小: 490862592 字节 (468.12 MB)
    修改日期: 2021-04-20 12:47
    MD5: 644e1a5e8d8f44d10431e303a5bb4603(官方正确)
    SHA1: 7c0037fd5ed1996137d204174feb366bfb7289be
    SHA256: 6e84b5accaa0795f7e9846336f5bb326b31b2ffdd1645cc8f805a4b1c145026f
    CRC32: 72b3c666
    NIRFSGPL20.7.txt (567 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG Playback Library 20.7 Readme
    April 2021
    This file contains important information about the NI-RFSG Playback Library, including system requirements, and installation instructions.
    Installed Software
    NI-RFSG Playback Library allows users to generate waveforms saved in the technical data management streaming (TDMS) file using the NI-RFSG driver. These TDMS files can be created from the NI RFmx Waveform Creator. You can use the NI-RFSG Playback Library to download multiple waveforms to the NI-RFSG vector signal generator memory. You can then generate all these waveforms using either a single script or multiple scripts. The playback library internally retrieves waveform properties from database to calculate and apply appropriate settings on the NI-RFSG driver.
    NI-RFSG Playback Library 20.6 includes the following new features:
    • Support for PXIe-5832
    NI-RFSG Playback Library 20.0 includes the following new features:
    NI-RFSG Playback Library 19.1 includes the following new features:
    • Support for PXIe-5841, PXIe-5831, and PXIe-5830
    • Performance improvements to store and retrieve waveform properties and Set Script to Generate APIs.
    Vector Signal Generators
    • PXIe-5673
    • PXIe-5673E
    Device-specific information about these modules is included in the NI RF Vector Signal Generators Help.
    Vector Signal Transceivers
    • PXIe-5644
    • PXIe-5645
    • PXIe-5646
    • PXIe-5820
    • PXIe-5830
    • PXIe-5831
    • PXIe-5832
    • PXIe-5840
    • PXIe-5841
    • PXIe-5841 with PXIe-5655
    NI-RFSG Playback Library has the following requirements:
    NI-RFSG Playback Library 20.7 supports the following 64-bit operating systems:
    Note    NI-RFSG Playback Library no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. NI-RFSG Playback Library 20.7 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG Playback Library 20.7 to an unsupported OS. Additionally, after installing NI-RFSG Playback Library 20.7, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-RFSG Playback Library supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing NI-RFSG Playback Library. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-RFSG Playback Library
    LabVIEW2017, 2018, 2019 SP1, 2020 SP1
    Required Software
    • NI-RFSG 14.5 or later
    • NI-RFSG .NET Class Library 14.5 or later *
    * NI-RFSG .NET Class Library is required only for .NET support.
    If you are using the NI-RFSG Playback Library .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSG Playback Library .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0.
    Download the NI-RFSG Playback Library installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Installed Software
      • Windows\SysWOW64 for 32-bit programs and Windows\System32 for 64-bit programs
    ItemInstalled Location
    Import Library files
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.ModularInstruments.NIRfsgPlayback.Fx40.dll
    NI-RFSG Playback Library palette VIs are available from the Functions » Measurement I/O » NI-RFSG Playback Library palette.
    Documentation for NI-RFSG Playback Library is located at Start » All Programs » National Instruments » NI-RFSG Playback Library » NI-RFSG Playback Library Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI-RFSG Playback Library HelpHTML/Windows HelpContains primary help content for NI-RFSG Playback Library. This help file is an HTML version of a traditional user manual that includes the following information:
    • An introduction to NI-RFSG Playback Library
    • A complete reference for all NI-RFSG Playback Library programming functions and VIs
    NI-RFSG Playback Library 20.7 ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    You can access all the installed NI-RFSG Playback Library examples at Start » All Programs » National Instruments » NI-RFSG Playback Library » NI-RFSG Playback Library Examples.
    You can access the NI-RFSG Playback Library known issues list online at NI-RFSG Playback Library 20.7 Known Issues.
    You can access the NI-RFSG Playback Library bug fix list online at NI-RFSG Playback Library 20.7 Bug Fixes. This list describes a subset of issues fixed in the NI-RFSG Playback Library. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    © 2015–2021 National Instruments Corporation. All rights reserved.
    375556P-01
    GMT+8, 2025-10-29 12:29
