查看: 7164|回复: 15
[MVTEC] MVTEC Halcon 20.11.1.2 Steady Runtime Version aarch64 Linux HALCON20.11.1.2稳定运行版 aarch64 Linux系统版
    5 小时前
  • 签到天数: 3730 天
    连续签到: 57 天
    发表于 2021-3-24 23:14:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.1.2-aarch64-linux-runtime.tar.gz
    文件大小: 74115699 字节 (70.68 MB)
    修改日期: 2021-03-03 23:00
    MD5: a6a21fe4f00374272efa0d8c3f5a2d70
    SHA1: c182cdf30987327283656ad7b44c27c40fd577ef
    SHA256: 2173a0ed9f186af057ea9a8ce002793e1f7167b0651855dd0c4ce92ecfe804b2
    CRC32: aa07c623
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    链接:
    提取码:bbvl
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.1.2 STEADYHOTFIX FOR HALCON 20.11.1.1 STEADY
    This document provides the release notes for MVTec HALCON 20.11.1.2 Steady, as released in January 2021, which is a Hotfix for HALCON 20.11.1.1 Steady. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.1.0 Steady.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.1.2 Steady (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
      • HALCON/PYTHON
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.1.2 STEADY (HOTFIX)
    The changes in HALCON 20.11.1.2 Steady are described with respect to HALCON 20.11.1.1 Steady.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    HALCON/PYTHON
    • The Python examples for HALCON Steady incorrectly required the Python language interface for HALCON Progress. This problem has been fixed.
    发表于 2024-3-23 14:15:29 | 显示全部楼层 来自:广东省深圳市 电信
    发表于 2023-4-1 14:45:23 | 显示全部楼层 来自:四川省成都市 移动
    视觉论坛,中国大流量的专业机器视觉论坛
    发表于 2021-11-23 21:02:17 | 显示全部楼层 来自:广东省潮州市 电信
    发表于 2021-12-1 16:37:10 | 显示全部楼层 来自:浙江省温州市 电信
  • 签到天数: 1 天
    发表于 2023-4-29 17:16:03 | 显示全部楼层 来自:上海市 电信
    发表于 2023-7-3 17:56:14 | 显示全部楼层 来自:广东省广州市 电信
  • 签到天数: 1 天
    发表于 2023-8-3 13:47:06 | 显示全部楼层 来自:泰国
    GMT+8, 2025-12-2 14:20
