查看: 7453|回复: 11
[MVTEC] MVTEC Halcon 20.11.1.2 Steady Deep Learning x64-linux/aarch64-linux/armv7a-linux(32bit) HALCON20.11.1.2稳定版深度学习
    6 小时前
  • 签到天数: 3730 天
    连续签到: 57 天
    发表于 2021-3-24 23:09:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.1.2-linux-deep-learning.tar.gz
    文件大小: 3700159277 字节 (3.45 GB)
    修改日期: 2021-03-03 23:09
    MD5: e75488551ccd3a33a84593f3b02fd982
    SHA1: 37fe5c9947f577f9947ad377917167aa4793adeb
    SHA256: 5da3ec16117095a72075e989bb152eb22a1f8ec10b442322385f05c455e32e0b
    CRC32: 694c61a4
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    链接:
    提取码:8o6c
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.1.2 STEADYHOTFIX FOR HALCON 20.11.1.1 STEADY
    This document provides the release notes for MVTec HALCON 20.11.1.2 Steady, as released in January 2021, which is a Hotfix for HALCON 20.11.1.1 Steady. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.1.0 Steady.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.1.2 Steady (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
      • HALCON/PYTHON
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.1.2 STEADY (HOTFIX)
    The changes in HALCON 20.11.1.2 Steady are described with respect to HALCON 20.11.1.1 Steady.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    HALCON/PYTHON
    • The Python examples for HALCON Steady incorrectly required the Python language interface for HALCON Progress. This problem has been fixed.
  • 签到天数: 2 天
    连续签到: 2 天
    发表于 2021-10-8 11:37:21 | 显示全部楼层 来自:江苏省南京市 电信
    看看
    发表于 2021-6-29 16:35:18 | 显示全部楼层 来自:广东省深圳市 移动
    发表于 2023-11-22 14:26:13 | 显示全部楼层 来自:上海市 电信
  • 签到天数: 2 天
    发表于 2021-3-26 11:55:39 | 显示全部楼层 来自:广西桂林市 联通
    连续签到: 2 天
    发表于 2021-6-25 16:22:20 | 显示全部楼层 来自:江苏省南京市 电信
  • 签到天数: 7 天
    发表于 2021-9-15 10:19:34 | 显示全部楼层 来自:山东省济南市 电信
    发表于 2021-9-16 11:21:51 | 显示全部楼层 来自:江苏省苏州市吴江市 电信
    发表于 2021-10-6 13:48:06 | 显示全部楼层 来自:河南省郑州市 联通
    发表于 2021-10-6 17:25:43 | 显示全部楼层 来自:上海市 电信
    GMT+8, 2025-12-2 15:11
