查看: 3004|回复: 0
[MVTEC] MVTEC Halcon 20.11.1.2 Steady Full Version X64 Mac-OS HALCON20.11.1.2稳定完整版 64位苹果系统版
    6 小时前
  • 签到天数: 3730 天
    连续签到: 57 天
    发表于 2021-3-24 23:04:46 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.1.2-macos.pkg
    文件大小: 2618681770 字节 (2.44 GB)
    修改日期: 2021-03-03 23:18
    MD5: f068218296c7a77cf4b76941297bb123
    SHA1: 15b67c441677f5ed312d6dfce159b556dc632146
    SHA256: 6e388795287a1c0d1b2235040122bd74f4b95c76ab72a683d169ebdffbe5968c
    CRC32: 3fbe018a
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    链接:
    提取码:oitq
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.1.2 STEADYHOTFIX FOR HALCON 20.11.1.1 STEADY
    This document provides the release notes for MVTec HALCON 20.11.1.2 Steady, as released in January 2021, which is a Hotfix for HALCON 20.11.1.1 Steady. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.1.0 Steady.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.1.2 Steady (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
      • HALCON/PYTHON
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.1.2 STEADY (HOTFIX)
    The changes in HALCON 20.11.1.2 Steady are described with respect to HALCON 20.11.1.1 Steady.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    HALCON/PYTHON
    • The Python examples for HALCON Steady incorrectly required the Python language interface for HALCON Progress. This problem has been fixed.
    GMT+8, 2025-12-2 15:11
