查看: 3348|回复: 3
[MVTEC] MVTEC Halcon 20.11.1.2 Steady Deep Learning Data Win64 HALCON20.11.1.2稳定版深度学习数据
    6 小时前
  • 签到天数: 3730 天
    连续签到: 57 天
    发表于 2021-3-24 23:02:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.1.2-windows-deep-learning-data.exe
    文件大小: 1323759216 字节 (1.23 GB)
    修改日期: 2021-03-03 23:09
    版本: 20.11.1.2
    MD5: c4feac3dfbe18e42427fb3fd378c3a6e
    SHA1: 02ae2684e768e6086ea41df2edbdc37cee987905
    SHA256: 3df40e9f84c0d044e39da14b2fa4032176614cb50c0e34cdc298a0dca96686fa
    CRC32: 50d46157
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    链接:
    提取码:6cap
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.1.2 STEADYHOTFIX FOR HALCON 20.11.1.1 STEADY
    This document provides the release notes for MVTec HALCON 20.11.1.2 Steady, as released in January 2021, which is a Hotfix for HALCON 20.11.1.1 Steady. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.1.0 Steady.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.1.2 Steady (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
      • HALCON/PYTHON
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.1.2 STEADY (HOTFIX)
    The changes in HALCON 20.11.1.2 Steady are described with respect to HALCON 20.11.1.1 Steady.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    HALCON/PYTHON
    • The Python examples for HALCON Steady incorrectly required the Python language interface for HALCON Progress. This problem has been fixed.
  • 签到天数: 1 天
    发表于 2021-7-7 11:53:36 | 显示全部楼层 来自:广东省深圳市 电信
    发表于 2021-9-22 14:10:00 | 显示全部楼层 来自:湖南省长沙市 移动
  • 签到天数: 1 天
    发表于 2021-10-6 12:25:18 | 显示全部楼层 来自:天津市 电信
    GMT+8, 2025-12-2 15:11
