查看: 17153|回复: 23
[MVTEC] MVTEC Halcon 20.11.1.2 Steady Full Version Win64 HALCON20.11.1.2稳定完整版
    6 小时前
  • 签到天数: 3730 天
    连续签到: 57 天
    发表于 2021-3-24 22:56:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    HALCON 20.11.1.0 Full Version (x64-win64):
    文件名: halcon-20.11.1.2-windows.exe
    文件大小: 2029465864 字节 (1.89 GB)
    修改日期: 2021-03-03 22:58
    版本: 20.11.1.2
    MD5: ffc47f98e45128fcdab68b794bc27c83
    SHA1: 88f6ff5592b94e5a3b43e77fb9c0208aa5d4bbfd
    SHA256: 178f0ead05c986aa743f868f3c82ecd5af88b27279bf9a5c3a333a1b0031e6e4
    CRC32: efecd633
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    链接:
    提取码:8pf5
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.1.2 STEADYHOTFIX FOR HALCON 20.11.1.1 STEADY
    This document provides the release notes for MVTec HALCON 20.11.1.2 Steady, as released in January 2021, which is a Hotfix for HALCON 20.11.1.1 Steady. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.1.0 Steady.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.1.2 Steady (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
      • HALCON/PYTHON
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.1.2 STEADY (HOTFIX)
    The changes in HALCON 20.11.1.2 Steady are described with respect to HALCON 20.11.1.1 Steady.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    HALCON/PYTHON
    • The Python examples for HALCON Steady incorrectly required the Python language interface for HALCON Progress. This problem has been fixed.
  • 签到天数: 8 天
    发表于 2021-5-10 10:39:34 | 显示全部楼层 来自:河北省廊坊市三河市燕郊开发区 电信
    石鑫华视觉网,工业相机、工业镜头、机器视觉光源、光源控制器、图像处理、系统集成服务商
    发表于 2023-5-7 13:02:03 | 显示全部楼层 来自:广东省东莞市 移动
    发表于 2021-7-27 21:45:39 | 显示全部楼层 来自:江苏省常州市 电信
    发表于 2021-4-28 19:05:46 | 显示全部楼层 来自:福建省泉州市石狮市 电信
  • 签到天数: 2 天
    发表于 2021-5-2 17:18:05 | 显示全部楼层 来自:湖北省武汉市 移动
  • 签到天数: 11 天
    发表于 2021-5-2 19:34:27 | 显示全部楼层 来自:美国 加利福尼亚州弗里蒙特市Hurricane Electric公司
    发表于 2021-5-22 21:25:36 | 显示全部楼层 来自:浙江省宁波市 移动
    发表于 2021-5-23 00:19:46 | 显示全部楼层 来自:广东省深圳市 移动
    发表于 2021-5-26 15:31:28 | 显示全部楼层 来自:江苏省镇江市 联通
    发表于 2021-7-2 11:51:07 | 显示全部楼层 来自:湖北省武汉市 联通
  • 签到天数: 1 天
    发表于 2021-7-7 11:43:05 | 显示全部楼层 来自:广东省深圳市 电信
    GMT+8, 2025-12-2 15:11
