查看: 1998|回复: 1
[MVTEC] MVTEC Halcon 20.11.0.2 Progress Runtime Version x64-linux HALCON20.11.0.2进阶版运行版 x64-Linux系统
    昨天 09:32
  • 签到天数: 3585 天
    发表于 2021-3-23 23:53:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.0.2-linux-runtime.tar.gz
    文件大小: 169765140 字节 (161.90 MB)
    修改日期: 2021-03-03 22:44
    MD5: c32f4cdca64bd43657217331818e4654
    SHA1: 52d12e3dc4f8db6788ebb729419938edc7f800c6
    SHA256: b7be4050b3315442ac56cb7854c9ead78c1f14353f123d4023196c95a375545e
    CRC32: c7b52321
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    链接:
    提取码:4wnn
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.0.2 PROGRESSHOTFIX FOR HALCON 20.11.0.1 PROGRESS
    This document provides the release notes for MVTec HALCON 20.11.0.2 Progress, as released in January 2021, which is a Hotfix for HALCON 20.11.0.1 Progress. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.0.0 Progress.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.0.2 Progress (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.0.2 PROGRESS (HOTFIX)
    The changes in HALCON 20.11.0.2 Progress are described with respect to HALCON 20.11.0.1 Progress.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
  • 签到天数: 6 天
    发表于 2023-4-24 14:50:37 | 显示全部楼层 来自:香港 特别行政区
    东莞市华动智能科技有限公司visionbbs.com,专注机器视觉方案与高性价比机器视觉软硬件
    GMT+8, 2025-7-6 10:44
