查看: 1863|回复: 0
[MVTEC] MVTEC Halcon 20.11.0.2 Progress Deep Learning (aarch64-linux, armv7a-linux) HALCON20.11.0.2进阶版深度学习 aarch64-linux/armv7a-linux系统
    昨天 09:32
  • 签到天数: 3585 天
    发表于 2021-3-23 23:48:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.0.2-linux-deep-learning.tar.gz
    文件大小: 3700159266 字节 (3.45 GB)
    修改日期: 2021-03-03 22:54
    MD5: 22377b984a94cd3aed15e076704cf92c
    SHA1: 8a8c9fe9c5ba328131b5edbd99586028f0e99c5e
    SHA256: 2736947b0ebc7f00a170972a639a33e818d822647f117ee93d274c4499cadfb9
    CRC32: 929c83ec
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    链接:
    提取码:517o
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.0.2 PROGRESSHOTFIX FOR HALCON 20.11.0.1 PROGRESS
    This document provides the release notes for MVTec HALCON 20.11.0.2 Progress, as released in January 2021, which is a Hotfix for HALCON 20.11.0.1 Progress. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.0.0 Progress.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.0.2 Progress (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.0.2 PROGRESS (HOTFIX)
    The changes in HALCON 20.11.0.2 Progress are described with respect to HALCON 20.11.0.1 Progress.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    GMT+8, 2025-7-6 10:39
