查看: 2193|回复: 0
[MVTEC] MVTEC Halcon 20.11.0.2 Progress Full Version X64-MAC OS HALCON20.11.0.2演进完整版 64位苹果系统版
  • 签到天数: 3586 天
    连续签到: 6 天
    发表于 2021-3-23 23:42:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.0.2-macos.pkg
    文件大小: 2618141254 字节 (2.44 GB)
    修改日期: 2021-03-03 23:27
    MD5: b5366f03743477f6ee3d93185a94cf31
    SHA1: b86c497d891c0ea99ea9520c3cd61b1edb92e158
    SHA256: d633b30651e0e3bf2e8bea072fe83e2fd32bda95077826dc813d11c3d6c6da82
    CRC32: 2da9f877
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    链接:
    提取码:8ghw
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.0.2 PROGRESSHOTFIX FOR HALCON 20.11.0.1 PROGRESS
    This document provides the release notes for MVTec HALCON 20.11.0.2 Progress, as released in January 2021, which is a Hotfix for HALCON 20.11.0.1 Progress. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.0.0 Progress.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.0.2 Progress (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.0.2 PROGRESS (HOTFIX)
    The changes in HALCON 20.11.0.2 Progress are described with respect to HALCON 20.11.0.1 Progress.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    GMT+8, 2025-7-6 22:08
