查看: 1823|回复: 0
[MVTEC] MVTEC Halcon 20.11.0.2 Progress Full Version Win64 HALCON20.11.0.2演进完整版 64位Windows版
  • 签到天数: 3586 天
    连续签到: 6 天
    发表于 2021-3-23 23:32:26 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    文件名: halcon-20.11.0.2-windows.exe
    文件大小: 2028916440 字节 (1.89 GB)
    修改日期: 2021-03-03 22:26
    版本: 20.11.0.2
    MD5: 85a6bb7ec8882bc869887c2c0e429258
    SHA1: 04bfecfc693e6c1201523ad83c625a6f5eb0e648
    SHA256: 2a35e4b7b54b2674b2da9de32b29e1eb891a7fb53e4aa57ec61cfcda1d1aa48b
    CRC32: f1bf5289
    MVTEC官方下载(需要注册、国外IP地址可能被墙)
    www.mvtec.com
    链接:
    提取码:i5g9
    大恒提供下载:
    RELEASE NOTES FOR HALCON 20.11.0.2 PROGRESSHOTFIX FOR HALCON 20.11.0.1 PROGRESS
    This document provides the release notes for MVTec HALCON 20.11.0.2 Progress, as released in January 2021, which is a Hotfix for HALCON 20.11.0.1 Progress. For general information like licensing or supported operating systems, see the release notes of HALCON 20.11.0.0 Progress.
    CONTENTS
    • Detailed Description of Changes in HALCON 20.11.0.2 Progress (Hotfix)
      • Licensing
      • HDevelop
      • Code Export
    DETAILED DESCRIPTION OF CHANGES IN HALCON 20.11.0.2 PROGRESS (HOTFIX)
    The changes in HALCON 20.11.0.2 Progress are described with respect to HALCON 20.11.0.1 Progress.
    LICENSING
    • On some computers, HALCON could not start after 2021-01-01 and showed the error 2021 (“System clock has been set back”). This problem has been fixed.
    HDEVELOP
    • HDevelop's variable inspection windows did not use the selected 'Values and Parameters' font when opened. This problem has been fixed.
    • If a procedure interface dialog had been added to the docking environment during the previous session, and then this dialog was used in the new session, HDevelop could crash during a restart. This problem has been fixed.
    • On some platforms, the program editor did not have the input focus on startup. This problem has been fixed.
    CODE EXPORT
    GMT+8, 2025-7-6 22:03
