查看: 3259|回复: 0
[NI驱动程序] NI System Configuration 16.0 Linux32/64 中文/德语/日语/法语/英文/韩语 NI系统配置nisycfg16.0
    2 小时前
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2021-3-18 23:14:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    System Configuration系统配置
    Linux32/64中文, 德语, 日语, 法语, 英文, 韩语
    16.0
    文件大小: 19159040 字节 (18.27 MB)
    修改日期: 2016-08-09 22:20
    MD5: 77c81312e1bc3efa20c0d94f54883620(官方正确)
    SHA1: ce4a425a37e4a8eb97bfb12ec4aeaae2ba40c389
    SHA256: 0fc0c5412e5c3c0b2a924c4b5e76c283babcb7b4874fcf901cf24bd1ad5fb21e
    CRC32: d0c22bd1
    SYSCFG Linux 16.0.txt (625 Bytes, 下载次数: 0, 售价: 10 圆)
    NI System Configuration 16.0 for Linux x86 32-bit/x64 64-bit
    August 2016
    This file contains late-breaking news about NI System Configuration and
    supersedes any information found in other documentation included in the
    distribution. Refer to ni.com/linux for the most recent information about Linux
    support at National Instruments.
    Installation
    FAQs
    Examples
    Linux Limitations
    System Configuration for Linux software for the Intel x86 32-bit and x64
    64-bit architectures has been tested on the following distributions:
            Red Hat Enterprise Linux 6
            Red Hat Enterprise Linux 7
            Scientific Linux 6.x
            OpenSUSE 13.2
            OpenSUSE LEAP 42.1
    For more information about supported Linux versions and distributions supported
    by National Instruments, refer to ni.com/linux.
    System Configuration for Linux requires at least 35 MB of disk space.
    Installation
    The installation process compiles a small amount of code to customize
    the software to your installation.  Before running the installer, you must have
    the following compiler facilities installed from your Linux distribution CD
    or other Linux distribution medium:
    * The kernel source files that exactly correspond to the kernel version
      you are running
    * The GCC compiler and C++ support
    * The make utility
    Use the software-install facility of your Linux distribution to verify that the
    above-listed packages are present. You can then begin installation.
    Complete the following steps to install System Configuration:
    Run the INSTALL script from this directory as root. The INSTALL script
    ensures that all requirements are met and installs the System Configuration
    software. The script installs the software into /usr/local and uses rpm to
    install the package on the system.
    FAQs
    Q1: What action needs to be taken if I upgrade/change my kernel?
    A1: Some action is required to make the existing NI System Configuration
        installation work for the new kernel. After upgrading your kernel,
        run updateNIDrivers utility as root. The utility is located in
        /usr/local/bin. Be sure to have sources for your new kernel properly
        installed on your system before running the utility. The utility
        rebuilds the driver using the new kernel sources and copies it to
        the appropriate location for the new kernel. For the changes
        to take place, you will be asked to reboot your machine after the
        utility completes.
    Q2: During installation I get a message similar to the following one:
        "Kernel source does not appear to be configured for the running kernel.
        Configuration of kernel source is required to continue installation."
        I do have kernel sources installed; is there anything else that needs to
        be done?
    A2: This problem has been seen on SUSE LINUX Professional 9.1 running the 2.6.5
    kernel or newer versions of SUSE LINUX Professional. However, it is possible
    that other distributions will require similar steps to resolve this problem.
        On SUSE LINUX Professional complete the following steps:
        1. Ensure you have installed kernel-source and kernel-syms packages
           corresponding to the version of the currently running kernel. The version
           of the currently running kernel can be determined by issuing the command
           `uname -r`.
        2. Change the directory to the /usr/src/linux- directory, where
           corresponds to the currently running kernel version.
        3. Run "make cloneconfig" as root to configure the sources for the
        4. Run "make modules_prepare" as root to prepare the headers for
           compilation.
        5. THIS STEP IS STRICTLY OPTIONAL. Completing this step removes the
           warning:
           WARNING: Symbol version dump /usr/src/linux/Module.symvers is missing,
                    modules will have CONFIG_MODVERSIONS disabled.
           Run "make modules" as root to compile all modules and generate
           Module.symvers; this step may take 30 minutes or more to complete.
        6. Run the INSTALL script for System Configuration for Linux
           from this directory.
    Examples
    This release includes examples showing the use of System Configuration in
    LabVIEW. The LabVIEW examples are located in the LabVIEW examples directory.
    Use a web browser to view the System Configuration help at
    labview/help/nisyscfg.chm.
    Linux Limitations
    Some features discussed in the System Configuration documentation and help
    are unavailable on Linux.
    - System Configuration supports two application development environments:
      * LabVIEW 2013 or later
      * C and C++ (gcc)
      System Configuration does not support LabWindows/CVI for Linux.
    - When using System Configuration in a PXI system, several restrictions
      apply:
      * Control through MXI-4 is supported, but MXI-3 is not.
      * Certain embedded controllers may be recommended over others for use in
        Linux.
      * There may be some restrictions related to routing triggers, events, and
        clocks over the PXI backplane on some PXI chassis models.
    - External calibration functions are not supported.  Refer to your hardware
      documentation for information about external calibration, and refer to
      ni.com/calibration.  If your hardware requires external
      calibration, either perform the calibration on a Windows system, or hire
      National Instruments or an independent calibration laboratory to perform the
      calibration.
    To access a list of Known Issues for System Configuration 16.0,
    visit ni.com/info and enter the Info Code SysCfgKnownIssues.
    COPYRIGHT
    (c) 2013-2016 National Instruments.
    All rights reserved.
    Under the copyright laws, this publication may not be reproduced or transmitted
    in any form, electronic or mechanical, including photocopying, recording,
    storing in an information retrieval system, or translating, in whole or in
    part, without the prior written consent of National Instruments Corporation.
    NI respects the intellectual property of others, and we ask
    our users to do the same. NI software is protected by copyright and other
    intellectual property laws. Where NI software may be used to reproduce
    softwaren or other materials belonging to others, you may use NI software
    only to reproduce materials that you may reproduce in accordance with the
    terms of any applicable license or other legal restriction.
    For end-user license agreements (EULAs) and copyright notices, conditions, and
    disclaimers, including information regarding certain third-party components
    used in LabVIEW, refer to the Copyright topic of the LabVIEW Help.
    If you are an agency, department, or other entity of the United States
    Government ("Government"), the use, duplication, reproduction, release,
    modification, disclosure or transfer of the technical data included in this
    manual is governed by the Restricted Rights provisions under Federal
    Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal
    Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for
    military agencies.
    Content from the IVI specifications reproduced with permission from the IVI
    Foundation.
    The IVI Foundation and its member companies make no warranty of any kind with
    regard to this material, including, but not limited to, the implied warranties
    of merchantability and fitness for a particular purpose. The IVI Foundation and
    its member companies shall not be liable for errors contained herein or for
    incidental or consequential damages in connection with the furnishing,
    performance, or use of this material.
    TRADEMARKS
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for
    information on NI trademarks. Other product and company names
    mentioned herein are trademarks or trade names of their respective companies.
    PATENTS
    For patents covering the NI products/technology, refer to the
    appropriate location: Help籔atents in your software, the patents.txt file on
    your media, or the NI Patent Notice at ni.com/patents.
    375038C-01
    GMT+8, 2025-10-29 12:35
