TA的每日心情 | 怒 2 小时前 |
签到天数: 3696 天 连续签到: 23 天 [LV.Master]2000FPS
发表于 2021-3-18 23:11:20
来自:广东省东莞市 联通
NI System Configuration 15.0 Linux32/64 中文/德语/日语/法语/英文/韩语 NI系统配置nisycfg15.0
System Configuration系统配置
Linux32/64中文, 德语, 日语, 法语, 英文, 韩语
15.0
文件大小: 16748544 字节 (15.97 MB)
修改日期: 2015-10-24 04:35
MD5: 701654c8fb0ed44ed7b1634cbd305496(官方正确)
SHA1: d4cd88760686e7cadf9135f501f7cc6859cd6386
SHA256: 2c7256fc32d4abf0a1dc5cfdf510dc417da2253dbf263ec28fdeb3d00813763d
CRC32: 5066bf99
SYSCFG Linux 15.0.txt
(629 Bytes, 下载次数: 0, 售价: 10 圆)
NI System Configuration for Linux x86 32-bit/x64 64-bit, Version 15.0
January 2015
This file contains late breaking news about NI System Configuration and
supersedes any information found in other documentation included in the
distribution. Refer to ni.com/linux for the most recent information about Linux
support at National Instruments.
Installation
Uninstallation
FAQs
Examples
Linux Limitations
NI System Configuration for Linux software for the Intel x86 32-bit and x64
64-bit architectures has been tested on the following distributions:
* Red Hat Enterprise Linux 6
* Scientific Linux 6
* OpenSUSE 12.3 and 13.1
For more information about supported Linux versions and distributions supported
by National Instruments, refer to ni.com/linux.
NI System Configuration for Linux requires at least 35 MB of disk space.
Installation
The installation process compiles a small amount of code to customize
the software to your installation. Before running the installer, you must have
the following compiler facilities installed from your Linux distribution CD
or other Linux distribution medium:
* The kernel source files that exactly correspond to the kernel version
you are running
* The GCC compiler and C++ support
* The make utility
Use the software-install facility of your Linux distribution to verify that the
above-listed packages are present. You can then begin installation.
Complete the following steps to install NI System Configuration:
Run the INSTALL script from this directory as root. The INSTALL script
ensures that all requirements are met and installs the NI System Configuration
software. The script installs the software into /usr/local and uses rpm to
install the package on the system.
FAQs
Q1: What action needs to be taken if I upgrade/change my kernel?
A1: Some action is required to make the existing NI System Configuration
installation work for the new kernel. After upgrading your kernel,
run updateNIDrivers utility as root. The utility is located in
/usr/local/bin. Be sure to have sources for your new kernel properly
installed on your system before running the utility. The utility
rebuilds the driver using the new kernel sources and copies it to
the appropriate location for the new kernel. For the changes
to take place, you will be asked to reboot your machine after the
utility completes.
Q2: During installation I get a message similar to the following one:
"Kernel source does not appear to be configured for the running kernel.
Configuration of kernel source is required to continue installation."
I do have kernel sources installed; is there anything else that needs to
be done?
A2: This problem has been seen on SUSE LINUX Professional 9.1 running the 2.6.5
kernel or newer versions of SUSE LINUX Professional. However, it is possible
that other distributions will require similar steps to resolve this problem.
On SUSE LINUX Professional complete the following steps:
1. Ensure you have installed kernel-source and kernel-syms packages
corresponding to the version of the currently running kernel. The version
of the currently running kernel can be determined by issuing the command
`uname -r`.
2. Change the directory to the /usr/src/linux- directory, where
corresponds to the currently running kernel version.
3. Run "make cloneconfig" as root to configure the sources for the
4. Run "make modules_prepare" as root to prepare the headers for
compilation.
5. THIS STEP IS STRICTLY OPTIONAL. Completing this step removes the
warning:
WARNING: Symbol version dump /usr/src/linux/Module.symvers is missing,
modules will have CONFIG_MODVERSIONS disabled.
Run "make modules" as root to compile all modules and generate
Module.symvers; this step may take 30 minutes or more to complete.
6. Run the INSTALL script for the NI System Configuration software for Linux
from this directory.
Examples
This release includes examples showing the use of NI System Configuration in
LabVIEW. The LabVIEW examples are located in the LabVIEW examples directory.
Use a web browser to view the NI System Configuration help at
labview/help/nisyscfg.chm.
Linux Limitations
Some features discussed in the NI System Configuration documentation and help
are unavailable on Linux.
- NI System Configuration supports two application development environments:
* LabVIEW 2012 or later
* C and C++ (gcc)
NI System Configuration does not support LabWindows/CVI for Linux.
- When using NI System Configuration in a PXI system, several restrictions
apply:
* Control through MXI-4 is supported, but MXI-3 is not.
* Certain embedded controllers may be recommended over others for use in
Linux.
* There may be some restrictions related to routing triggers, events, and
clocks over the PXI backplane on some PXI chassis models.
- External calibration functions are not supported. Refer to your hardware
documentation for information about external calibration, and refer to
ni.com/calibration. If your hardware requires external
calibration, either perform the calibration on a Windows system, or hire
National Instruments or an independent calibration laboratory to perform the
calibration.
For a listing of Known Issues of NI System Configuration 15.0,
visit ni.com/info and enter the Info Code SysCfgKnownIssues.
COPYRIGHT
(c) 2013-2015 National Instruments.
All rights reserved.
Under the copyright laws, this publication may not be reproduced or transmitted
in any form, electronic or mechanical, including photocopying, recording,
storing in an information retrieval system, or translating, in whole or in part,
without the prior written consent of National Instruments Corporation.
National Instruments respects the intellectual property of others, and we ask
our users to do the same. NI software is protected by copyright and other
intellectual property laws. Where NI software may be used to reproduce software
or other materials belonging to others, you may use NI software only to
reproduce materials that you may reproduce in accordance with the terms of any
applicable license or other legal restriction.
For end-user license agreements (EULAs) and copyright notices, conditions, and
disclaimers, including information regarding certain third-party components
used in LabVIEW, refer to the Copyright topic of the LabVIEW Help.
If you are an agency, department, or other entity of the United States
Government ("Government"), the use, duplication, reproduction, release,
modification, disclosure or transfer of the technical data included in this
manual is governed by the Restricted Rights provisions under Federal
Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal
Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for
military agencies.
Content from the IVI specifications reproduced with permission from the IVI
Foundation.
The IVI Foundation and its member companies make no warranty of any kind with
regard to this material, including, but not limited to, the implied warranties
of merchantability and fitness for a particular purpose. The IVI Foundation and
its member companies shall not be liable for errors contained herein or for
incidental or consequential damages in connection with the furnishing,
performance, or use of this material.
TRADEMARKS
Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for
information on National Instruments trademarks. Other product and company names
mentioned herein are trademarks or trade names of their respective companies.
PATENTS
For patents covering the National Instruments products/technology, refer to the
appropriate location: Help籔atents in your software, the patents.txt file on
your media, or the National Instruments Patent Notice at ni.com/patents.
375038B-01 |
