查看: 2707|回复: 0
[NI驱动程序] NI-SCOPE 19.5 Win32/64 Eng/Jpn NI示波器驱动程序SCOPE19.5
    2 小时前
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2021-3-17 00:25:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SCOPE
    NI-SCOPE为使用NI示波器产品的客户提供支持。
    Win32/64Eng/Jpn
    19.5
    文件大小: 2585939968 字节 (2.41 GB)
    修改日期: 2019-10-25 22:51
    MD5: 06a810945ec1064571222e9ab2fe47eb(官方正确)
    SHA1: 6db5fcd75baad8d155d100aa5dfe45b1fae0ce6e
    SHA256: 75a25e8f9f3b1f9583297f65456f56f107f592f76b5fab7d65fbe54128c2244b
    CRC32: f60e181b
    SCOPE19.5.0.txt (610 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SCOPE 19.5 Readme
    September 2019
    This file contains important information about the NI-SCOPE driver, including installation instructions, new features, and known issues.
    NI-SCOPE Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    NI-SCOPE is an NI instrument driver that enables you to implement multirecord acquisition, continuous acquisition, multiboard synchronization, more than 50 measurement and analysis functions, and the functionality of traditional oscilloscopes. NI-SCOPE is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the oscilloscope and includes an interactive soft front panel and examples.
    NI-SCOPE 19.5 has the following requirements:
    • 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
    • 1 GB RAM (32-bit) or 2 GB RAM (64-bit)
    • If you are running your application on an RT target, at least 128 MB of memory
    NI-SCOPE 19.5 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    • Linux
      • Red Had Enterprise Linux Desktop + Workstation 7.x, 8.x
      • CentOS 7.x, 8.x
      • OpenSUSE Leap 42.3, 15
    Note  In 2016, NI-SCOPE dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SCOPE will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SCOPE to an unsupported OS. Additionally, after installing NI-SCOPE 19.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-SCOPE supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-SCOPE
    LabVIEW2016, 2017, 2018, 2019
    LabVIEW Real-Time Module32016, 2017, 2018, 2019
    LabVIEW NXG3.0, 3.1, 4.0
    LabWindows™/CVI™2013 SP1 or later
    LabWindows/CVI Real-Time Module32013 SP1 or later
    3No support for the PXIe‑5110/5111/5113, the PXIe‑5163, or the PXIe-5164 and PXIe-517x reconfigurable oscilloscopes.
    If you are using the NI-SCOPE .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-SCOPE .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-SCOPE installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support.
    NI installs NI-SCOPE using NI Package Manager. If you do not already have NI software installed, NI-SCOPE installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    NI-SCOPE is available for download from ni.com/downloads/drivers. NI-SCOPE installs NI-DAQmx if it is not already installed or if an earlier version of NI-DAQmx is installed. NI-DAQmx support files will be installed if you have LabVIEW or LabWindows/CVI in your system. However, the only component that NI-SCOPE needs from NI-DAQmx is the device driver.
    Upgrading from a Previous Version of NI-SCOPE
    • From NI-SCOPE 1.0 and 1.1—NI-SCOPE does not install over NI-SCOPE 1.0 or 1.1. You must uninstall these versions of NI-SCOPE before installing a later version of NI-SCOPE.
    • From NI-SCOPE 1.5 and later—NI-SCOPE automatically uninstalls any previous version that is greater or equal to 1.5. If you have modified any old examples, these will be overwritten by the new versions.
    Uninstalling NI-SCOPE
    As part of the NI-SCOPE installation, the following software is installed. To completely remove the NI-SCOPE installation from your system, you must also remove all of the following packages:
    • NI-DAQmx
    • NI Hierarchical Waveform Storage
    • NI I/O Trace
    Notice  Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    • You now can create sessions that include multiple instruments of the same model and in the same chassis. This automatically synchronizes all channels of the included instruments, simplifying your test program development and maintenance. Refer to the Initialize or Initialize with Options API reference in the NI High-Speed Digitizers Help for more information.
    • The PXIe-5172 now supports additional bandwidth-limiting filters (80 MHz, 40 MHz) and onboard clock rates (200 MS/s, 150 MS/s).
    The following table details the hardware models supported in NI‑SCOPE 19.5.
    [tr][/tr]
    [tr][/tr]
    Hardware DeviceSupported Under Windows 10 (32-bit)/Windows 8.1 (32-bit)/7 (32-bit)Supported Under Windows 10 (64-bit)1/Windows 8.1 (64-bit)1/7 (64-bit)1
    NI-DAQmx-Based Oscilloscopes
    PXI/PXIe/PCI-5105
    Yes
    Yes
    PXI/PXIe/PCI-5114
    Yes
    Yes
    PXI/PXIe/PCI-5122
    Yes
    Yes
    PXI/PCI-5124
    Yes
    Yes
    USB-5132/5133
    Yes
    Yes
    PXI/PCI-5142
    Yes
    Yes
    PXI/PCI-5152
    Yes
    Yes
    PXI/PCI-5153
    Yes
    Yes
    PXI/PCI-5154
    Yes
    Yes
    PXIe-5160/5162
    Yes
    Yes
    PXIe-5185/5186
    Yes
    Yes
    PXIe-5622
    Yes
    Yes
    PXI-5900
    Yes
    Yes
    PXI/PCI-5922
    Yes
    Yes
    SDI-Based Oscilloscopes
    PXIe-5110
    Yes
    Yes
    PXIe-5111
    Yes
    Yes
    PXIe-5113
    Yes
    Yes
    516x Oscilloscopes
    PXIe-5163
    Yes
    Yes
    PXIe-5164
    Yes
    Yes
    517x Oscilloscopes
    PXIe-5170
    Yes
    Yes
    PXIe-5171
    Yes
    Yes
    PXIe-5172
    Yes
    Yes
    1When you install NI-SCOPE on a 64-bit installation of Windows, InstrumentStudio is installed instead of the SCOPE soft front panel. Use InstrumentStudio to monitor and control your oscilloscope.
    Device-specific information about these modules is included in the NI High-Speed Digitizers Help.
    NI‑SCOPE 19.1 introduces the following behavior changes between 19.0 and 19.1:
    • The NI-SCOPE Initialize and Initialize with Options resource name parameters now accept a comma-delimited list of instruments. When you list more than one instrument in resource name, NI-SCOPE creates a single multi-instrument session and synchronizes all channels of the listed instruments. Refer to the NI High-Speed Digitizers Help for more information.
    You can access the software and documentation known issues list online. Visit NI-SCOPE 19.5 Known Issues for an up-to-date list of known issues.
    The following items are the IDs, versions, and descriptions of a subset of issues fixed in NI-SCOPE releases. This is not an exhaustive list of issues fixed in the current version of NI-SCOPE. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    IDFixed VersionFixed Issue
    71697718.7Implemented various fetch performance improvements for the PXIe‑5110/5111/5113, PXIe‑5164, PXIe‑5170, PXIe‑5171, and PXIe‑5172.
    63949317.2Fixed an issue in which committing a new clocking configuration for the PXIe-5164 without previously phase locking the clock and resetting the device caused LabVIEW to crash.
    54602316.1Fixed an issue in which C examples failed to compile in Visual Studio 2015.
    • For help with the NI-SCOPE driver, refer to the NI High-Speed Digitizers Help, accessible by selecting Help»NI High-Speed Digitzers Help.
    • For help with the NI-SCOPE Soft Front Panel, refer to the NI-SCOPE Soft Front Panel Help, accessible by selecting Help»Online Help. The NI-SCOPE Soft Front Panel is only supported on 32-bit installations of Windows.
    • For help with InstrumentStudio, used to configure and monitor NI-SCOPE devices in 64-bit installations of Windows, refer to the InstrumentStudio help at ni.com.
    NI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start» Programs»National Instruments»NI-SCOPE»Examples.
    For LabVIEW examples, select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SCOPE are located in the labview\examples\instr\niScope directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The following sections detail considerations for using LabVIEW NXG with NI-SCOPE.
    LabVIEW NXG Hardware Support
    The following table details the hardware models supported in NI-SCOPE with LabVIEW NXG.
    [tr][/tr]
    [tr][/tr]
    [tr][/tr]
    Hardware ModuleSupported Under Windows 10/Windows 8.1 (64-bit)/7 (64-bit)
    PXI/PXIe/PCI-5105
    Yes
    PXI/PXIe/PCI-5114
    Yes
    PXI/PXIe/PCI-5122
    Yes
    PXI/PCI-5124
    Yes
    USB-5132/5133
    Yes
    PXI/PCI-5142
    Yes
    PXI/PCI-5152
    Yes
    PXI/PCI-5153
    Yes
    PXI/PCI-5154
    Yes
    PXIe-5160/5162
    Yes
    PXIe-5185/5186
    Yes
    PXIe-5622
    Yes
    PXI-5900
    Yes
    PXI/PCI-5922
    Yes
    PXIe-51101
    Yes
    PXIe-51111
    Yes
    PXIe-51131
    Yes
    516x Oscilloscopes
    PXIe-51631
    Yes
    PXIe-51641
    Yes
    517x Oscilloscopes
    PXIe-51701
    Yes
    PXIe-51711
    Yes
    PXIe-51721
    Yes
    1External calibration of this module is not supported in LabVIEW NXG.
    LabVIEW NXG Help
    LabVIEW NXG Examples
    NI-SCOPE will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 1999–2019 National Instruments. All rights reserved.
    375360V-01
    GMT+8, 2025-10-29 12:35
