NI-SCOPE 19.1 Win32/64 Eng/Jpn NI示波器驱动程序SCOPE19.1
NI-SCOPE
NI-SCOPE为使用NI示波器产品的客户提供支持。
Win32/64Eng/Jpn
19.1.0
文件大小: 2608869376 字节 (2.43 GB)
修改日期: 2019-09-06 03:16
MD5: 62cb995cd553e7944c3dac4b709c8dc3(官方正确)
SHA1: ffe9eef7d27312c802abe68c0554ba642e6bc359
SHA256: 132cc79a9ae14b428343dc9263b20f6f1b700b677a857dd9864c550fb8fcb023
CRC32: 10242489
SCOPE19.1.0.txt
(612 Bytes, 下载次数: 0, 售价: 10 圆)
NI-SCOPE 19.1 ReadmeJune 2019 This file contains important information about the NI-SCOPE driver, including installation instructions, new features, and known issues. If you plan to use LabVIEW NXG, refer to LabVIEW NXG Support and Considerations.
Overview System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates New Features Supported Hardware Behavior Changes Known Issues Bug Fixes Accessing the Help Finding Examples LabVIEW NXG Support and Considerations Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 NI-SCOPE Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 Legal Information OverviewNI-SCOPE is an NI instrument driver that enables you to implement multirecord acquisition, continuous acquisition, multiboard synchronization, more than 50 measurement and analysis functions, and the functionality of traditional oscilloscopes. NI-SCOPE is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the oscilloscope and includes an interactive soft front panel and examples. System RequirementsNI-SCOPE 19.1 has the following requirements: - 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
- 1 GB RAM (32-bit) or 2 GB RAM (64-bit)
- If you are running your application on an RT target, at least 128 MB of memory
Supported Operating SystemsNI-SCOPE 19.1 supports the following operating systems: - Windows 10/8.11/7 SP12
- Windows Embedded Standard 7 SP12
- Windows Server 2012 R21
- Windows Server 2008 R2 SP12
- Linux
- Red Had Enterprise Linux Desktop + Workstation 6.x, 7.x
- CentOS 7.x
- OpenSUSE Leap 42.2, 42.3
Note In 2016, NI-SCOPE dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SCOPE will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SCOPE to an unsupported OS. Additionally, after installing NI-SCOPE 19.1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?. Note Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/r/PAESupport. 1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update. Application Software SupportNI-SCOPE supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support. | Application Software | Versions Supported by NI-SCOPE | | LabVIEW | 2016, 2017, 2018, 2019 | | LabVIEW Real-Time Module3 | 2016, 2017, 2018, 2019 | | LabVIEW NXG | 3.0, 3.1 | | LabWindows™/CVI™ | 2013 SP1 or later | | LabWindows/CVI Real-Time Module3 | 2013 SP1 or later |
3No support for the PXIe‑5110/5111/5113, the PXIe‑5163, or the PXIe-5164 and PXIe-517x reconfigurable oscilloscopes. Microsoft Visual Studio SupportIf you are using the NI-SCOPE .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-SCOPE .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5. To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-SCOPE installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to National Instruments .NET Driver Support. Installation InstructionsNI installs NI-SCOPE using NI Package Manager. If you do not already have NI software installed, NI-SCOPE installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. NI-SCOPE is available for download from ni.com/downloads/drivers. NI-SCOPE installs NI-DAQmx if it is not already installed or if an earlier version of NI-DAQmx is installed. NI-DAQmx support files will be installed if you have LabVIEW or LabWindows/CVI in your system. However, the only component that NI-SCOPE needs from NI-DAQmx is the device driver. Upgrading from a Previous Version of NI-SCOPE- From NI-SCOPE 1.0 and 1.1—NI-SCOPE does not install over NI-SCOPE 1.0 or 1.1. You must uninstall these versions of NI-SCOPE before installing a later version of NI-SCOPE.
- From NI-SCOPE 1.5 and later—NI-SCOPE automatically uninstalls any previous version that is greater or equal to 1.5. If you have modified any old examples, these will be overwritten by the new versions.
Uninstalling NI-SCOPEAs part of the NI-SCOPE installation, the following software is installed. To completely remove the NI-SCOPE installation from your system, you must also remove all of the following packages: - NI-DAQmx
- NI Measurement & Automation Explorer
- NI Hierarchical Waveform Storage
- NI I/O Trace
Notice Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. Visit ni.com/critical-updates for information about critical updates from NI. New Features- You now can create sessions that include multiple instruments of the same model and in the same chassis. This automatically synchronizes all channels of the included instruments, simplifying your test program development and maintenance. Refer to the Initialize or Initialize with Options API reference in the NI High-Speed Digitizers Help for more information.
- The PXIe-5172 now supports additional bandwidth-limiting filters (80 MHz, 40 MHz) and onboard clock rates (200 MS/s, 150 MS/s).
Supported HardwareThe following table details the hardware models supported in NI‑SCOPE 19.1. [tr][/tr]
[tr][/tr]
| Hardware Device | Supported Under Windows 10/Windows 8.1 (32-bit)/7 (32-bit)1 | Supported Under Windows 10/Windows 8.1 (64-bit)/7 (64-bit)1 | NI-DAQmx-Based Oscilloscopes | | PXI/PXIe/PCI-5105 | Yes | Yes | | PXI/PXIe/PCI-5114 | Yes | Yes | | PXI/PXIe/PCI-5122 | Yes | Yes | | PXI/PCI-5124 | Yes | Yes | | USB-5132/5133 | Yes | Yes | | PXI/PCI-5142 | Yes | Yes | | PXI/PCI-5152 | Yes | Yes | | PXI/PCI-5153 | Yes | Yes | | PXI/PCI-5154 | Yes | Yes | | PXIe-5160/5162 | Yes | Yes | | PXIe-5185/5186 | Yes | Yes | | PXIe-5622 | Yes | Yes | | PXI-5900 | Yes | Yes | | PXI/PCI-5922 | Yes | Yes | SDI-Based Oscilloscopes | | PXIe-5110 | Yes | Yes | | PXIe-5111 | Yes | Yes | | PXIe-5113 | Yes | Yes | 5164 Oscilloscopes | | PXIe-5163 | Yes | Yes | | PXIe-5164 | Yes | Yes | 517x Oscilloscopes | | PXIe-5170 | Yes | Yes | | PXIe-5171 | Yes | Yes | | PXIe-5172 | Yes | Yes | 1MXI Express and MXI-4 are supported on Windows 10/8.1/7.
Device-specific information about these modules is included in the NI High-Speed Digitizers Help. Behavior ChangesNI‑SCOPE 19.1 introduces the following behavior changes between 19.0 and 19.1: - The NI-SCOPE Initialize and Initialize with Options resource name parameters now accept a comma-delimited list of instruments. When you list more than one instrument in resource name, NI-SCOPE creates a single multi-instrument session and synchronizes all channels of the listed instruments. Refer to the NI High-Speed Digitizers Help for more information.
Known IssuesYou can access the software and documentation known issues list online. Visit NI-SCOPE 19.1 Known Issues for an up-to-date list of known issues. Bug FixesThe following items are the IDs, versions, and descriptions of a subset of issues fixed in NI-SCOPE releases. This is not an exhaustive list of issues fixed in the current version of NI-SCOPE. If you have a CAR ID, you can search this list to validate that the issue has been fixed. | ID | Fixed Version | Fixed Issue | | 716977 | 18.7 | Implemented various fetch performance improvements for the PXIe‑5110/5111/5113, PXIe‑5164, PXIe‑5170, PXIe‑5171, and PXIe‑5172. | | 639493 | 17.2 | Fixed an issue in which committing a new clocking configuration for the PXIe-5164 without previously phase locking the clock and resetting the device caused LabVIEW to crash. | | 546023 | 16.1 | Fixed an issue in which C examples failed to compile in Visual Studio 2015. |
Accessing the Help- For help with the NI-SCOPE driver, refer to the NI High-Speed Digitizers Help, accessible by selecting Help»NI High-Speed Digitzers Help.
- For help with the NI-SCOPE Soft Front Panel, refer to the NI-SCOPE Soft Front Panel Help, accessible by selecting Help»Online Help.
Finding ExamplesNI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start» Programs»National Instruments»NI-SCOPE»Examples. For LabVIEW examples, select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SCOPE are located in the labview\examples\instr\niScope directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. LabVIEW NXG Support and ConsiderationsThe following sections detail considerations for using LabVIEW NXG with NI-SCOPE. LabVIEW NXG Operating Systems and System RequirementsSoftware support for LabVIEW NXG differs in the following ways: - System requirements—Only 64-bit (x64) processors are supported.
- Operating system—Only 64-bit operating systems are supported. Refer to the Supported Operating Systems section for more information.
LabVIEW NXG Hardware SupportThe following table details the hardware models supported in NI-SCOPE with LabVIEW NXG. [tr][/tr]
[tr][/tr]
[tr][/tr]
| Hardware Module | Supported Under Windows 10/Windows 8.1 (64-bit)/7 (64-bit)1 | NI-DAQmx-Based Oscilloscopes | | PXI/PXIe/PCI-5105 | Yes | | PXI/PXIe/PCI-5114 | Yes | | PXI/PXIe/PCI-5122 | Yes | | PXI/PCI-5124 | Yes | | USB-5132/5133 | Yes | | PXI/PCI-5142 | Yes | | PXI/PCI-5152 | Yes | | PXI/PCI-5153 | Yes | | PXI/PCI-5154 | Yes | | PXIe-5160/5162 | Yes | | PXIe-5185/5186 | Yes | | PXIe-5622 | Yes | | PXI-5900 | Yes | | PXI/PCI-5922 | Yes | SDI-Based Oscilloscopes | | PXIe-51102 | Yes | | PXIe-51112 | Yes | | PXIe-51132 | Yes | 5164 Oscilloscopes | | PXIe-51632 | Yes | | PXIe-51642 | Yes | 517x Oscilloscopes | | PXIe-51702 | Yes | | PXIe-51712 | Yes | | PXIe-51722 | Yes | 1MXI Express and MXI-4 are supported on Windows 10/8.1/7.
2External calibration of this module is not supported in LabVIEW NXG. | LabVIEW NXG HelpView context help in LabVIEW by pressing and hovering over an object. Search for items using the search bar in the upper right corner of the LabVIEW window. You can also view context help for the search results. Additional documentation is available online at ni.com/manuals. LabVIEW NXG ExamplesLaunch LabVIEW and click the Learning tab. LabVIEW lessons are located in the Lessons tab, and LabVIEW Examples are located in the Examples tab. Follow the instructions in the lessons and examples. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer.
- To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. NI-SCOPE Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021NI-SCOPE will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: | Product | Info Code | | LabVIEW | lifecycle | | LabWindows/CVI | cvi_lifecycle | | Measurement Studio | mstudiolifecycle | | TestStand | tslcp | | DIAdem | ddlcp | | SignalExpress | selcp | | VeriStand | nivslifecycle |
Legal InformationCopyright © 1999–2019 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 375360U-01 |
