查看: 2845|回复: 0
[NI驱动程序] NI-SCOPE 17.5 Win32/64 Eng/Jpn NI示波器驱动程序SCOPE17.5
    2 小时前
  • 签到天数: 3696 天
    连续签到: 23 天
    发表于 2021-3-17 00:10:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SCOPE
    NI-SCOPE为使用NI示波器产品的客户提供支持。
    Win32/64Eng/Jpn
    17.5
    文件大小: 2396056279 字节 (2.23 GB)
    修改日期: 2018-01-22 14:13
    MD5: b7cd08991778d1bdc12a4ae4528e54b4(官方未提供,重复下载一致)
    SHA1: 144b23053882758ede2aea1406940d964e9d1b93
    SHA256: 9d7f3dff97fad23be50edc673c896cd1954ac8eb152ba15a28a26baed23f3d6d
    CRC32: b6159d02
    SCOPE17.5.0.txt (603 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SCOPE 17.5 Readme
    January 2018
    This file contains important information about the NI-SCOPE driver, including installation instructions, new features, and known issues.
    NI-SCOPE is an NI instrument driver that enables you to implement multirecord acquisition, continuous acquisition, multiboard synchronization, more than 50 measurement and analysis functions, and the functionality of traditional oscilloscopes. NI-SCOPE is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the oscilloscope and includes an interactive soft front panel and examples.
    NI-SCOPE 17.5 has the following requirements:
    • 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
    • 1 GB RAM (32-bit) or 2 GB RAM (64-bit)
    • If you are running your application on an RT target, at least 128 MB of memory
    NI-SCOPE 17.5 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016, NI-SCOPE dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-SCOPE will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-SCOPE to an unsupported OS. Additionally, after installing NI-SCOPE 17.5, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    NI-SCOPE supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by NI-SCOPE
    LabVIEW2014, 2015, 2016, 2017
    LabVIEW NXG2.0
    LabVIEW Real-Time Module32014 SP1 or later
    LabWindows™/CVI™2014 SP1 or later
    LabWindows™/CVI™ Real-Time Module2014 SP1 or later
    3No support for the PXIe-5164 and PXIe-517x reconfigurable oscilloscopes.
    If you are using the NI-SCOPE .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-SCOPE .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5.
    To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter the Info Code NETAPIdriversupport.
    NI-SCOPE installs NI-DAQ if it is not already installed or if an earlier version of NI-DAQ is installed. NI-DAQ support files will be installed if you have LabVIEW or LabWindows/CVI in your system. However, the only component that NI-SCOPE needs from NI-DAQ is the device driver.
    Upgrading from a Previous Version of NI-SCOPE
    • From NI-SCOPE 1.0 and 1.1—NI-SCOPE does not install over NI-SCOPE 1.0 or 1.1. You must uninstall these versions of NI-SCOPE before installing a later version of NI-SCOPE.
    • From NI-SCOPE 1.5 and later—NI-SCOPE automatically uninstalls any previous version that is greater or equal to 1.5. If you have modified any old examples, these will be overwritten by the new versions.
    Uninstalling NI-SCOPE
    As part of the NI-SCOPE installation, the following software is installed. To completely remove the NI-SCOPE installation from your system, you must also remove all of the following packages:
    • NI-DAQmx 17.0
    • Traditional NI-DAQ 7.4.4
    • NI Measurement & Automation Explorer 17.0
    • NI Hierarchical Waveform Storage 17.0
    • NI I/O Trace 17.0
    Installing NI-SCOPE for LabVIEW NXG
    • NI-SCOPE 17.5 adds support for LabVIEW NXG 2.0.
    • NI-SCOPE 17.1 adds support for the following PXIe-5172 devices:
      • PXIe-5172 (4 channel, 325T FPGA)
      • PXIe-5172 (8 channel, 325T FPGA)
      • PXIe-5172 (8 channel, 410T FPGA)
    • NI-SCOPE 17.0 adds support for LabVIEW 2017 and LabVIEW NXG 1.0 hardware and software.
    • NI-SCOPE 16.1 adds support for the PXIe-5164.
    • NI-SCOPE 16.0 adds support for LabVIEW 2016.
    The following table details the hardware models supported in NI-SCOPE.
    [tr][/tr]
    Hardware ProductSupported Under Windows 10/Windows 8.1 (32-bit)/7 (32-bit)1Supported Under Windows 10/Windows 8.1 (64-bit)/7 (64-bit)1
    NI-DAQmx-Based Oscilloscopes
    PXI/PCI-5102
    Yes
    No
    PCMCIA/USB/AT-51022
    No
    No
    PXI/PXIe/PCI-5105
    Yes
    Yes
    PXI/PCI-5112
    Yes
    No
    PXI/PXIe/PCI-5114
    Yes
    Yes
    PXI/PXIe/PCI-5122
    Yes
    Yes
    PXI/PCI-5124
    Yes
    Yes
    USB-5132/5133
    Yes
    Yes
    PXI/PCI-5142
    Yes
    Yes
    PXI/PCI-5152
    Yes
    Yes
    PXI/PCI-5153
    Yes
    Yes
    PXI/PCI-5154
    Yes
    Yes
    PXIe-5160/5162
    Yes
    Yes
    PXIe-5185/5186
    Yes
    Yes
    PXI-5620
    Yes
    No
    PXI-5621
    No
    No
    PXIe-5622
    Yes
    Yes
    PXI-5900
    Yes
    Yes
    PCI-59112
    No
    No
    PXI/PCI-5922
    Yes
    Yes
    5164 Oscilloscopes
    PXIe-5164
    Yes
    Yes
    517x Oscilloscopes
    PXIe-5170
    Yes
    Yes
    PXIe-5171
    Yes
    Yes
    PXIe-5172
    Yes
    Yes
    1MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    2PCMCIA/USB/AT-5102 and PCI-5911 are Legacy products.
    Device-specific information about these modules is included in the NI High-Speed Digitizers Help.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in NI-SCOPE 17.5.
    The following items are the IDs, versions, and descriptions of a subset of issues fixed in NI-SCOPE releases. This is not an exhaustive list of issues fixed in the current version of NI-SCOPE. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    IDFixed VersionFixed Issue
    63949317.2Fixed an issue in which committing a new clocking configuration for the PXIe-5164 without previously phase locking the clock and resetting the device caused LabVIEW to crash.
    64164017.2Fixed an issue causing Traditional NI-DAQ (Legacy) devices to be missing from the NI-SCOPE full installer.
    54602316.1Fixed an issue in which C examples failed to compile in Visual Studio 2015.
    • For help with the NI-SCOPE driver, refer to the NI High-Speed Digitizers Help, accessible by selecting Help»NI High-Speed Digitzers Help.
    • For help with the NI-SCOPE Soft Front Panel, refer to the NI-SCOPE Soft Front Panel Help, accessible by selecting Help»Online Help.
    NI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start» Programs»National Instruments»NI-SCOPE»Examples.
    For LabVIEW examples, select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SCOPE are located in the labview\examples\instr\niScope directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The following sections detail considerations for using LabVIEW NXG 2.0 with NI-SCOPE 17.5.
    LabVIEW NXG Hardware Support
    The following table details the hardware models supported in NI-SCOPE with LabVIEW NXG.
    [tr][/tr]
    PXI/PXIe/PCI-5105
    Yes
    Yes
    PXI/PXIe/PCI-5114
    Yes
    Yes
    PXI/PXIe/PCI-5122
    Yes
    Yes
    PXI/PCI-5124
    Yes
    Yes
    USB-5132/5133
    Yes
    Yes
    PXI/PCI-5142
    Yes
    Yes
    PXI/PCI-5152
    Yes
    Yes
    PXI/PCI-5153
    Yes
    Yes
    PXI/PCI-5154
    Yes
    Yes
    PXIe-5160/5162
    Yes
    Yes
    PXIe-5185/5186
    Yes
    Yes
    PXIe-5622
    Yes
    Yes
    PXI-5900
    Yes
    Yes
    PXI/PCI-5922
    Yes
    Yes
    5164 Oscilloscopes
    PXIe-5164
    Yes
    Yes
    517x Oscilloscopes
    PXIe-5170
    Yes
    Yes
    PXIe-5171
    Yes
    Yes
    PXIe-5172
    Yes
    Yes
    LabVIEW NXG Help
    LabVIEW NXG Examples
    © 1999–2018 National Instruments. All rights reserved.
    375360J-01
    GMT+8, 2025-10-29 12:35
