查看: 3293|回复: 0
[Patch补丁] NI-SCOPE 14.0 Patch Win32/64 Eng/Jpn NI示波器驱动程序SCOPE14.0补丁
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-3-16 23:53:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SCOPE
    NI-SCOPE为使用NI示波器产品的客户提供支持。
    Win32/64Eng/Jpn
    14.0Patch
    文件大小: 48201031 字节 (45.97 MB)
    修改日期: 2019-06-25 03:08
    MD5: 72ec78e27504045bd0ccef2b47194d04(官方正确)
    SHA1: 13f79b6b806509a169b64469a62e77a22cc1d59f
    SHA256: c9e4bb50b4a7ddf055c6d495d3f815502d3021c28ce0e2825c2cf4f1b8e6774f
    CRC32: 93596557
    SCOPE14.0.0f1Patch.txt (613 Bytes, 下载次数: 0, 售价: 1 圆)
    NI-SCOPE Readme
    Version 14.0
    Thank you for using NI-SCOPE. This file contains important information about NI-SCOPE and is organized into the following sections:
    Accessing VIs and Functions
    Driver Version Naming Changes
    Uninstalling/Modifying NI-SCOPE
    Programming in NI-SCOPE
    NI-SCOPE Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-SCOPE 14.0 adds support for LabVIEW 2014.
    NI-SCOPE 4.1.3 adds a bug fix for VIs in LabVIEW 2013.
    NI-SCOPE 4.1.1 adds a critical bug fix for an issue affecting NI PXIe-5185/5186 digitizers.
    NI-SCOPE 4.1 includes the following new features:
    • Support for the NI PXIe-5160, 2.5 GS/s high-speed digitizer
    • NI-P2P support for the NI PXIe-5160 and the NI PXIe-5162
    NI-SCOPE 4.0.5 adds support for LabVIEW 2013.
    NI-SCOPE 4.0 adds support for the NI PXIe-5162, 5 GS/s high-speed digitizer.
    NI-SCOPE 3.9.7 redesigns the NI-SCOPE Soft Front Panel.
    NI-SCOPE 3.9.6 adds 1MOhm support for the NI PXIe-5185/5186, 12.5 GS/s high-speed digitizers (new model)
    NI-SCOPE 3.9.4 adds support for LabVIEW 2012.
    NI-SCOPE 3.8.9 adds support for NI-RFSA 2.5.2.
    NI-SCOPE 3.8.8 adds a critical bug fix for the NI PXI-5900 digitizer.
    NI-SCOPE 3.8.7 adds critical bug fixes for NI PXIe-5185/5186 digitizers.
    NI-SCOPE 3.8.6 adds support for NI-RFSA 2.5.
    NI-SCOPE 3.8.5 includes the following new features:
    • Support for LabVIEW 2011
    • Addition of the following NI-TClk functions/VIs and attributes/properties:
      LabVIEW VIC/C++ Function
      niTClk Setup For Sync Pulse Sender SynchronizeniTClk_SetupForSyncPulseSenderSynchronize
      niTClk Synchronize to Sync Pulse SenderniTClk_SynchronizeToSyncPulseSender
      niTClk Finish Sync Pulse Sender SynchronizeniTClk_FinishSyncPulseSenderSynchronize
      Labview PropertyC/C++ Attribute
      NI-TClk SyncPulseSender:External Pulse SourceNITCLK_ATTR_SYNC_PULSE_SENDER_SYNC_PULSE_SOURCE
    NI-SCOPE 3.8 includes the following new features:
    • Support for the NI PXIe-5185/5186, 12.5 GS/s high-speed digitizers
    • Support for including NI-SCOPE run-time in custom installers built using National Instrument Application Development Environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using National Instruments high-speed digitizers.
      Notes:
      • The run-time installer does not contain support for interactively configuring or testing hardware using Measurement & Automation Explorer (MAX), NI SignalExpress, or the NI-SCOPE Soft Front Panel.
      • The run-time installer does not support upgrading from NI-SCOPE 3.6.x or earlier and NI-DAQmx 8.9.x or earlier.
      • The run-time installer does not support the NI 5102, NI 5112, NI 5620, or NI 5621.
    The following table shows which hardware products are supported under particular operating systems.
    Hardware ProductSupported Under Windows XP1Supported Under Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)1Supported Under Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI PXI/PCI-5102
    Yes
    Yes
    No
    NI PCMCIA/USB/AT-51021
    Yes
    No
    No
    NI PXI/PCI-5105
    Yes
    Yes
    Yes
    NI PXI/PCI-5112
    Yes
    Yes
    No
    NI PXI/PCI-5114
    Yes
    Yes
    Yes
    NI PXI/PXIe/PCI-5122
    Yes
    Yes
    Yes
    NI PXI/PCI-5124
    Yes
    Yes
    Yes
    NI USB-5132/5133
    Yes
    Yes
    Yes
    NI PXI/PCI-5142
    Yes
    Yes
    Yes
    NI PXI/PCI-5152
    Yes
    Yes
    Yes
    NI PXI/PCI-5153
    Yes
    Yes
    Yes
    NI PXI/PCI-5154
    Yes
    Yes
    Yes
    NI PXIe-5160/5162
    Yes
    Yes
    Yes
    NI PXIe-5185/5186
    Yes
    Yes
    Yes
    NI PXI-5620
    Yes
    Yes
    No
    NI PXI-5621
    Yes
    No
    No
    NI PXIe-5622
    Yes
    Yes
    Yes
    NI PXI-5900
    Yes
    Yes
    Yes
    NI PCI-59112
    Yes
    No
    No
    NI PXI/PCI-5922
    Yes
    Yes
    Yes
    1MXI Express and MXI-4 are supported on Windows 8.1/8/7/Vista/XP, but MXI-3 is supported only on Windows XP.
    2NI PCMCIA/USB/AT-5102 and NI PCI-5911 are Legacy products.
    Device-specific information about these modules is included in the NI High-Speed Digitizers Help.
    NI-SCOPE 14.0 and later support the following operating systems:
    • Windows 8.1 (32-bit and 64-bit)
    NI recommends that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-SCOPE 3.6 or earlier.
    NI-SCOPE 14.0 and later support the following real-time operating environments:
    • LabVIEW Real-Time Module
    • LabWindows™/CVI™ Real-Time Module
    Minimum System Requirements
    • RAM—
      • Windows XP Service Pack 3 (SP3): 128 MB
      • Windows Vista: 512 MB
      • Windows 8.1/8/7: 1 GB
    • Windows 8.1/8/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended System
    • RAM—
      • Windows XP SP3: 256 MB
      • Windows 8.1/8/7/Vista: 1 GB
    • A screen resolution of 1024 x 768
    Note  You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-SCOPE. To add support for ADEs installed after installing NI-SCOPE, modify your NI-SCOPE installation or launch the NI-SCOPE installer again.
    • 2011 SP1 (32- and 64-bit), 2012 SP1 (32- and 64-bit), 2013 (32- and 64-bit), 2014 (32- and 64-bit)
    • LabVIEW Real-Time Module 2011 SP1, 2012 SP1, 2013, or 2014
      Note: Not all devices are supported by the LabVIEW Real-Time Module.
      NI 5105
      NI 5114
      NI 5122
      NI 5124
      NI 5142
      NI 5152
      NI 5153
      NI 5154
      NI 5160
      NI 5162
      NI 5185
      NI 5186
      NI 5622
      NI 5900
      NI 5922
    • LabWindows/CVI 2009 or later
    • LabWindows/CVI Real-Time Module 2010 or later
    • If you are running your application on an RT target, 128 MB of memory or more is required.
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 8.1/8/7/Vista: Users\Public\Documents\National Instruments
      • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8.1/8/7/Vista/XP
    NI-SCOPE\Drivers\niScope
    NI-SCOPE Function Panel\Drivers\niScope\niScope.fp
    NI-SCOPE Examples\niScope\Examples
    NI-SCOPE Header files\Include
    NI-SCOPE Import Library files (32-bit)\Lib
    NI-SCOPE Import Library files (64-bit)\Lib_x64
    NI-SCOPE DLL (32-bit)\Bin
    NI-SCOPE Firmware UpdatersProgram Files\NI-DAQ\fpgafiles
    Additional File Locations for Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-SCOPE DLL (64-bit)\Bin
    NI-SCOPE Firmware UpdatersProgram Files (x86)\NI-DAQ\fpgafiles
    Select Start»All Programs»National Instruments»NI-SCOPE»SCOPE Soft Front Panel to launch the NI-SCOPE Soft Front Panel.
    Documentation for NI-SCOPE is located at Start»All Programs»National Instruments»NI-SCOPE»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    NI High-Speed Digitizers HelpHTML/Windows HelpContains primary help content for NI high-speed digitizer products. The help is an HTML version of a traditional user manual that includes the following information:
    • An introduction to high-speed digitizers and NI-SCOPE
    • Hardware device information
    • A complete reference for all NI-SCOPE programming functions and VIs
    Specifications for your devicePrinted and PDFLists technical specifications for your device.
    NI-SCOPE ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.
    Note  To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    NI–SCOPE palette VIs are available from the Functions»Measurement I/O»NI–SCOPE palette.
    NI–SCOPE functions are available in LabWindows/CVI from the Instrument menu. To load the NI–SCOPE function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niSCOPE\niSCOPE.fp.
    You can also access all the installed NI–SCOPE examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI–SCOPE»Examples.
    NI-SCOPE versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-SCOPE 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-SCOPE 4.1.3. The first version released under the new numbering scheme is NI-SCOPE 14.0.
    Installing/Uninstalling/Modifying NI-SCOPEInstalling NI-SCOPE
    This section provides information on installing NI-SCOPE and NI-DAQ and upgrading from previous versions of NI-SCOPE.
    NI-SCOPE installs NI-DAQ if it is not already installed, or if an earlier version of NI-DAQ is installed. NI-DAQ support files will be installed if you have LabVIEW or LabWindows/CVI in your system. However, the only component that NI-SCOPE needs from NI-DAQ is the device driver.
    Upgrading from a Previous Version of NI-SCOPE
    Upgrading from NI-SCOPE 1.0 and 1.1—NI-SCOPE does not install over NI-SCOPE 1.0 or 1.1. You must uninstall these versions of NI-SCOPE before installing a later version of NI-SCOPE.
    Upgrading from NI-SCOPE 1.5 and later—NI-SCOPE automatically uninstalls any previous version that is greater or equal to 1.5. If you have modified any old examples, these will be overwritten by the new versions.
    • Click Change/Remove.
    • Select NI-SCOPE 14.0 from the dialog box that appears.
    • Select Driver Runtime.
    • Click Remove to uninstall the product(s); click Modify to change the components that are installed.
    For Windows 8.1/8, complete the following steps:
    • Click the Uninstall button.
    As part of the NI–SCOPE installation, the following software is installed. To completely remove the NI-SCOPE installation from your system, you must also remove all of the following packages:
    • NI IVI Compliance Package 4.4
    • NI-DAQmx 9.1.7
    • Traditional NI-DAQ 7.4.4
    • NI Measurement & Automation Explorer 14.0
    • NI Hierarchical Waveform Storage 14.0
    • NI Spy 2.7.2
    NI-SCOPE provides an intuitive, full-featured interface for programming your hardware. NI-SCOPE is IVI-Scope compliant. For more information, refer to niScopeIVIComplianceDocument.txt.
    Software Examples
    NI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start» Programs»National Instruments»NI-SCOPE»Examples.
    The NI-SCOPE Soft Front Panel (SFP) is a software oscilloscope application for NI high-speed digitizers. It has the following features:
    • Familiar interactive user interface
    • Robust architecture
    • Scalar measurements
    • Save/load waveforms
    • Save/load configurations
    • Low CPU usage
    The NI-SCOPE SFP demonstrates some of the capabilities of NI high-speed digitizers and enables you to start using your new digitizer immediately without the need to know a programming language. The NI-SCOPE SFP is installed by default as a feature of the NI-SCOPE installation. To remove the NI-SCOPE SFP use the Add/Remove Programs option.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in NI-SCOPE 14.0.
    The following list contains changes from earlier versions of NI-SCOPE to NI-SCOPE 14.0. If you have a Bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-SCOPE.
    439447Fixed an issue where NI-SCOPE VIs installed into LabVIEW 2013 were not mass compiled.
    425102Fixed an issue in the NI-SCOPE driver software that affects the NI PXIe-5185/5186 that may cause data corruption when performing a multi-record acquisition. For more information about this issue, visit ni.com/kb and enter 6DQG890S.
    257093Fixed an issue where setting the Vertical Coupling attribute to Ground on a PXI-5922 would return the following error: "Internal Software Error occured in Scopes software. Please contact National Instruments Support."
    381159Fixed an issue where calling niScope_Abort on a NI PXIe-5162 digitizer while an acquisition is in progress would cause the aborted record to be lost.
    380799Fixed an issue where using the PXIe-5162 with Distributed TClk would result in up to but less than 6.4ns of TClk skew between sync pulse senders, with the skew varying each time the sync pulse senders are synchronized.
    405834Fixed an issue where the PXI-5900 would not initialize, producing IVI error 1074135028.
    368402Fixed an issue where enabling 3, 5, 6, or 7 channels on the NI 5105 would cause a subsequent Fetch to return fewer samples than requested.
    257481Fixed an issue where the Preferred Packet Size and Maximum Bandwidth properties had no effect for the NI PXIe-5185 and NI PXIe-5186.
    328318Fixed an issue that caused NI-SCOPE 3.7 to not support Visual Basic 6.
    341670Fixed an issue where the NI-SCOPE Soft Front Panel does not launch under certain conditions.
    336845Fixed an issue where TClk synchronization is not consistent between multiple sessions when using NI PXIe-5185 or NI PXIe-5186.
    327321Fixed an issue where NI PXI-5105 returns incorrect data at low sample rates (<20 kS/s) if the channel list size is not a power of 2.
    315548Fixed an issue that caused the first channel in the channel list to return incorrect data when using the niScope EX Fetch Forever VI with multiple channels. You can find this example VI at Start» Programs»National Instruments»NI-SCOPE»Examples.
    When you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    National Instruments NI-SCOPE will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-SCOPE that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 1999–2014 National Instruments. All rights reserved.
    GMT+8, 2025-12-12 19:15
