查看: 3115|回复: 0
[NI驱动程序] NI-SCOPE 3.7 Win32/64 Eng/Jpn NI示波器驱动程序SCOPE3.7
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-3-16 23:22:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SCOPE
    NI-SCOPE为使用NI示波器产品的客户提供支持。
    Win32/64Eng/Jpn
    3.7
    文件大小: 1518881452 字节 (1.41 GB)
    修改日期: 2011-01-12 01:37
    MD5: 2a78ef090450ae05987ca0bba5cfc7bd(官方正确)
    SHA1: ca816b2f8405dcb2c806d8b02ebbda37bd7d9000
    SHA256: 76297f1adc7b23e9da52b374f43c16f457b126504013675f3214ac0d2d3cb7e7
    CRC32: 1e02ec12
    SCOPE3.7.0.txt (592 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SCOPE ReadmeVersion 3.7
    September 2010
    Thank you for using NI-SCOPE. This file contains important information regarding NI-SCOPE and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Installing/Uninstalling/Modifying NI-SCOPE
    • Programming in NI-SCOPE
    • Bug Fixes
    • Known Issues
    New Features in NI-SCOPE 3.7
    • Added support in NI-TClk for the power edge trigger on the NI 5622.
    NI-SCOPE 3.6.2 adds support for LabVIEW 2010 (32-bit) and LabVIEW 2010 (64-bit).
    The following table shows which hardware products are supported under particular operating systems.
    Hardware ProductWindows XPWindows Vista
    32-Bit
    Windows Vista
    64-Bit
    Windows 7
    32-Bit
    Windows 7
    64-Bit
    NI PXI/PCI-5102
    Yes
    Yes
    No
    Yes
    No
    NI PCMCIA/USB/AT-5102*
    Yes
    No
    No
    No
    No
    NI PXI/PCI-5105
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PCI-5112
    Yes
    Yes
    No
    Yes
    No
    NI PXI/PCI-5114
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PXIe/PCI-5122
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PCI-5124
    Yes
    Yes
    Yes
    Yes
    Yes
    NI USB-5132/5133
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PCI-5142
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PCI-5152
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PCI-5153
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI/PCI-5154
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI-5620
    Yes
    Yes
    No
    Yes
    No
    NI PXI-5621
    Yes
    No
    No
    No
    No
    NI PXIe-5622
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PXI-5900
    Yes
    Yes
    Yes
    Yes
    Yes
    NI PCI-5911
    Yes
    No
    No
    No
    No
    NI PXI/PCI-5922
    Yes
    Yes
    Yes
    Yes
    Yes
    *NI PCMCIA/USB/AT-5102 are Legacy products.
    Note: MXI-4 is supported on Windows Vista/XP. MXI-3 is supported only on Windows XP.
    This section lists the minimum system and the recommended system for using NI-SCOPE.
    NI-SCOPE 3.7 and later supports the following operating systems:
    • Windows XP (32-bit)
    It is recommended that you have the most recent service pack for your operating system installed. Windows 2000 users must use NI-SCOPE 3.6 or earlier.
    NI-SCOPE 3.7 and later supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Minimum System Requirements
    • RAM—
      Windows XP: 128 MB
      Windows 7/Vista: 512 MB
    Recommended System
    • RAM—
      Windows XP: 256 MB
      Windows 7/Vista: 1 GB
    • A screen resolution of 1024 x 768
    • One of the following application development environments (ADEs):
      • LabVIEW 8.5.1, 8.6.1, 2009 (32-bit), 2009(64-bit), 2010 (32-bit), or 2010 (64-bit)
      • LabVIEW Real-Time Module 8.5.1 or later (If you are running your application on an RT target, at least 128 MB of memory is required)
        Note: Not all devices are supported by the LabVIEW Real-Time Module.
        NI 5105
        NI 5114
        NI 5122
        NI 5124
        NI 5142
        NI 5152
        NI 5153
        NI 5154
        NI 5622
        NI 5900
        NI 5922
    • LabWindows™/CVI™ 8.1.1 or later
    • LabWindows™/CVI™ Real-Time Module (If you are running your application on an RT target, at least 128 MB of memory is required)
    • Microsoft Visual Basic 6.0
    • National Instruments file folder location, :
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 7/Vista: Users\Public\Documents\National Instruments
      • Windows XP and Windows 7/Vista 32-bit: Program Files\IVI Foundation\IVI\
      • Windows 7/Vista 64-bit: Program Files (x86)\IVI Foundation\IVI\
        NOTES:$(IVIROOTDIR32) is configured as an environment variable on the target system.
        • Windows XP and Windows 7/Vista 32-bit: Program Files\IVI\
        • Windows 7/Vista 64-bit: Program Files (x86)\IVI\
      • Windows 7/Vista 64-bit: Program Files\IVI Foundation\IVI\
        NOTE:$(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows XP/2000
    NI-SCOPE\Drivers\niScope
    NI-SCOPE Function Panel\Drivers\niScope\niScope.fp
    NI-SCOPE Examples\niScope\Examples
    NI-SCOPE Header files\Include
    NI-SCOPE Import Library files (32-bit)\Lib
    NI-SCOPE Import Library files (64-bit)\Lib_x64
    NI-SCOPE DLL (32-bit)\Bin
    NI-SCOPE Firmware UpdatersProgram Files\NI-DAQ\fpgafiles
    Additional File Locations for Windows 7/Vista 64-bit
    ItemInstalled Location on Windows Vista 64-bit
    NI-SCOPE DLL (64-bit)\Bin
    NI-SCOPE Firmware UpdatersProgram Files (x86)\NI-DAQ\fpgafiles
    Most documentation is available at Start»All Programs»National Instruments»NI-SCOPE»Documentation. The documentation set is composed of the following documents:
    • NI High-Speed Digitizers Getting Started Guide
    • NI High-Speed Digitizers Help
    • Device Specifications
    • Calibration Procedures
    Note: Printed copies of device specifications are shipped with each device.
    Installing/Uninstalling/Modifying NI-SCOPEInstalling NI-SCOPE
    This section provides information on installing NI-SCOPE and NI-DAQ and upgrading from previous versions of NI-SCOPE.
    NI-SCOPE installs NI-DAQ if it is not already installed, or if an earlier version of NI-DAQ is installed. NI-DAQ support files will be installed if you have LabVIEW or LabWindows/CVI in your system. However, the only component that NI-SCOPE needs from NI-DAQ is the device driver.
    Upgrading from a Previous Version of NI-SCOPE
    Upgrading from NI-SCOPE 1.0 and 1.1—NI-SCOPE does not install over NI-SCOPE 1.0 or 1.1. You must uninstall these versions of NI-SCOPE before installing a later version of NI-SCOPE.
    Upgrading from NI-SCOPE 1.5 and later—NI-SCOPE automatically uninstalls any previous version that is greater or equal to 1.5. If you have modified any old examples, these will be overwritten by the new versions.
    • Click Change/Remove.
    • Select NI-SCOPE 3.7 from the dialog box that appears.
    For Windows Vista, complete the following steps:
    Do not attempt to uninstall by deleting files, which may be shared with other programs. The following additional software packages may have been installed as part of the NI-SCOPE installation. Exercise care when removing these packages because they may be used by other NI products:
    • IVI Compliance Package 4.2
    • NI-VISA 5.0
    • NI-DAQmx 9.1.5
    • Traditional NI-DAQ 7.4.4
    • Measurement & Automation Explorer 4.7
    • NI Hierarchical Waveform Storage 1.4.8
    • NI Spy 2.7.2
    NI-SCOPE provides an intuitive, full-featured interface for programming your hardware. NI-SCOPE is IVI-Scope compliant. For more information, refer to niScopeIVIComplianceDocument.txt.
    Software Examples
    NI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start» Programs»National Instruments»NI-SCOPE»Examples.
    NI-SCOPE Soft Front Panel
    The NI-SCOPE Soft Front Panel (SFP) is a software oscilloscope application for NI high-speed digitizers. It has the following features:
    • Familiar interactive user interface
    • Robust architecture
    • Scalar measurements
    • Save/load waveforms
    • Save/load configurations
    • Low CPU usage
    The NI-SCOPE SFP demonstrates some of the capabilities of NI high-speed digitizers and enables you to start using your new digitizer immediately without the need to know a programming language. The NI-SCOPE SFP is installed by default as a feature of the NI-SCOPE installation. To remove the NI-SCOPE SFP use the Add/Remove Programs option.
    The following list contains changes from earlier versions of NI-SCOPE to NI-SCOPE 3.7. If you have a Bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-SCOPE.
    Bug IDFixed Issue
    NI-SCOPE
    232263Fixed an issue where the NI-SCOPE Express VI does not maintain input impedance configuration. Changed the Express VI so it maintains the input impedance configuration.
    217159Fixed an issue where closing a Signal Express project containing an NI-SCOPE step returned an error.
    185276NI-SCOPE driver now returns an error if the session is invalid.
    250183Fixed an issue where the user's digital gain could not be applied properly even though it had not reached the +/-1.5 V allowed. Digital gain will now be coerced to the maximum that works for the current device and the current configuration. Users can read the Digital Gain property/attribute to find the coerced value.
    Known IssuesDynamic Mode in the LabVIEW FPGA Module
    Using dynamic FPGA interfaces (also known as dynamic mode) in the LabVIEW FPGA Module is not supported when using peer-to-peer streaming. Dynamic mode is enabled by default in the LabVIEW FPGA Module 2010. To disable Dynamic mode, complete the following steps:
    • Place the Open FPGA VI Reference function on the LabVIEW block diagram.
    • Right-click the function and select Configure Open FPGA VI Reference.
    • Remove the checkmark from the Dynamic mode listbox.
    Security Prompts
    When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    NI PXIe-5122 and NI PXIe-5622 Firmware Update for NI-SCOPE 3.7
    A firmware update for the NI PXIe-5122 is available with NI-SCOPE 3.7. This update enables peer-to-peer streaming functionality on these devices.
    To update firmware, run the Firmware Updater application from one of the following locations:
    • Windows XP and Windows 7/Vista 32-bit: C:\Program Files\National Instruments\NI-DAQ\fpgafiles\ni5122\NI PXIe-5122 Firmware Updater.exe.
    • Windows 7 64-bit/Vista 64-bit: Program Files (x86)\National Instruments\NI-DAQ\fpgafiles\ni5122\NI PXIe-5122 Firmware Updater.exe.
    This application will upgrade your firmware to the latest available that works with this driver. After the application has finished running, you will be required to power down your computer and PXIe chassis to complete the firmware update.
    For more information on installing firmware updates, refer to KnowledgeBase 4MJGCSAY at ni.com/support.
    NI-SCOPE P2P Example Projects Prompt for Save on Close
    NI-SCOPE Peer-to-Peer examples may require you to save them after opening the examples for the first time.
    Switching between Certain Trigger Slopes with NI-TClk Misses Triggers
    When synchronizing NI 5105 devices with NI-TClk and switching between negative digital trigger slope and immediate trigger, the immediate trigger will time out.
    Window/FFT Results Differ between NI-SCOPE and LabVIEW
    If you perform a Window/FFT in NI-SCOPE, the results are slightly different compared to similar functions in LabVIEW. This is because NI-SCOPE uses a slightly different definition of Windowing than LabVIEW uses.
    LabVIEW SignalExpress Does Not Allow Digital Triggering with TIS Enabled on Certain Devices
    In LabVIEW SignalExpress, you cannot trigger an NI 5154 device with a digital signal if Time Interleaved Sampling (TIS) mode is enabled.
    RAM Requirements for NI-SCOPE Soft Front Panel
    Your system must have at least 512 MB of RAM to launch the NI-SCOPE Soft Front Panel.
    NI 515x Devices and NI-TClk Synchronization
    When using an NI 515x device in TIS mode with NI-TClk synchronization and an external sample clock, the devices configured as the TClk slaves may fail to respond to reference triggers.
    Downgrading NI-SCOPE
    If you need to downgrade the current version of NI-SCOPE to NI-SCOPE 2.1.4 or earlier, you must uninstall the current versions of NI-SCOPE and NI-DAQmx before installing the older version of NI-SCOPE. After the older version of NI-SCOPE is installed, you can then reinstall NI-DAQmx.
    Function Reference Help
    If you click a topic link in the NI-SCOPE Function Reference Help section of the NI High-Speed Digitizers Help, you cannot use the Back button in the HTML Help window toolbar to return to the original topic.
    Using Help from LabVIEW
    When linking to a topic in the NI High-Speed Digitizers Help from the context help or opening the help file from a VI within LabVIEW, the NI High-Speed Digitizers Help launches and the relevant topic displays, but the location of the topic might not be highlighted in the table of contents.
    Windows Power Management
    NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate, when using NI-SCOPE. These modes terminate any NI-SCOPE operation in progress. In Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    LabVIEW Support for Traditional NI-DAQ
    Beginning with version 7.4.2, Traditional NI-DAQ (Legacy) will install support for the latest version of LabVIEW found on the system. If you require support for more than one version of LabVIEW, complete the following steps:
    • Install Traditional NI-DAQ (Legacy)(included in the NI-SCOPE installer).
    • Restart the system.
    • Copy the following folders from the latest version of LabVIEW to the folder of the older version of LabVIEW. [LVDIR] indicates the folder of the latest LabVIEW version.
      • [LVDIR]\vi.lib\daq
      • [LVDIR]\examples\daq
      • [LVDIR]\help\lvdaq.chm
      • [LVDIR]\menus\default\daq
    You should now be able to use Traditional NI-DAQ (Legacy) with both versions of LabVIEW.
    The Traditional NI-DAQ (Legacy) API is mass-compiled in LabVIEW 7.0. This will not affect the functionality of your VIs. However, LabVIEW will prompt you to save the Traditional NI-DAQ (Legacy) subVIs if your LabVIEW version is greater than 7.0. To avoid the prompts, mass-compile the folders referenced above. If you require Traditional NI-DAQ (Legacy) support for earlier versions of LabVIEW, you need an earlier version of Traditional NI-DAQ (Legacy).
    NI-SCOPE Soft Front Panel Keyboard Shortcuts
    Beginning with NI-SCOPE 3.1, the following shortcuts have changed in the NI-SCOPE Soft Front Panel:
    • Increment trigger coupling has changed from to .
    • Decrement trigger coupling has changed from to .
    • now toggles the cursors.
    NI-SCOPE Express Step in NI Signal Express 1.0
    The NI-SCOPE Express step that ships with NI-SCOPE was designed for use with NI SignalExpress 1.1 or later. The NI-SCOPE Express step is compatible with NI SignalExpress 1.0 with the exception that software start triggers are not supported.
    TClk Connector Alignment in NI-SCOPE 2.7 and Later
    If you are using NI-TClk to synchronize non-identical devices (for example, an NI PXI-5122 with an NI PXI-5124), you will notice a change in behavior in the skew associated with synchronization when you upgrade from NI-SCOPE 2.6.1 to a later version. The new behavior compensates for delay associated with the input path. This delay varies from device to device. Because the driver now handles this delay, synchronizing any SMC-based products should produce data that has a small constant skew over all sample rates.
    NI 5102
    Board revision 183612F-01 of the NI PCI-5102 and board revision 184603E-01 of the NI PXI-5102 must be used with NI-SCOPE 2.6.1 or later. Board revision 183442G-01 of the NI PCMCIA-5102 must be used with NI-SCOPE 2.8 or later. To verify the board revision number, remove the device from the computer or chassis and turn it to view the side. The revision number is labeled "ASSY" and is located near the serial number. If you have an earlier version NI-SCOPE installed, go to ni.com/idnet to download the latest version.
    NI 5112
    You can now read data as soon as it is acquired. However, on a single record acquisition, the fetch functions do not wait for the trigger holdoff to expire. If you configure a trigger holdoff on a single record acquisition, you must make sure the trigger holdoff period has expired before initiating another acquisition. Call niScope_AcquisitionStatus to find out when the entire acquisition, including trigger holdoff, has completed.
    NI 5122
    • To change the rate of the external clock within the same session, you need to first change the rate by setting the Sample Clock Timebase Rate attribute, then change the rate of your source, then call the function niScope_Commit. If you change the rate of the source before setting the attribute, you may get an error. Another option is to abort the acquisition after fetching the data but before changing the rate.
    • Board revision 190100B-01 of the NI PXI-5122 must be used with NI-SCOPE 2.7 or later. To verify the board revision number, remove the device from the computer or chassis and turn it to view the side. The revision number is labeled "ASSY" and is located near the serial number. If you have an earlier version of NI-SCOPE installed, go to ni.com/idnet to download the latest version.
    NI PXI/PCI-5142, NI PXIe-5622
    TClk synchronization is not fully supported for certain cases. When the DDC Enabled property or the NISCOPE_ATTR_DDC_ENABLED attribute is set to True, there are certain configurations for which shared triggers cannot be TClk synchronized. The following table explains which triggers can be TClk synchronized for different configurations. For all cases, it is assumed that the DDC is enabled. If the DDC is not enabled, there are no restrictions on TClk synchronization.
    Configuration
    51425622
    Start Trigger
    Reference Trigger
    (Digital)
    Reference Trigger
    (Analog Edge)
    Reference Trigger
    (Power Edge)
    Start Trigger
    Reference Trigger
    (Digital)
    Reference Trigger
    (Analog Edge)
    Reference Trigger
    (Power Edge)
    Fractional Resampling Off, Homogeneous Sample Rates
    Y
    Y
    Y
    N
    Y
    Y
    N/A
    Y
    Fractional Resampling Off, Heterogeneous Sample Rates
    Y
    Y
    Y
    N
    Y
    Y
    N/A
    N
    Fractional Resampling On, Single-Record, Homogeneous Sample Rates
    N/A
    N/A
    N/A
    N/A
    Y
    Y
    N/A
    Y
    Fractional Resampling On, Single-Record, Heterogeneous Sample Rates
    N/A
    N/A
    N/A
    N/A
    Y
    N
    N/A
    N
    Fractional Resampling On, Multi-Record, Homogeneous Sample Rates
    N/A
    N/A
    N/A
    N/A
    Y
    Y
    N/A
    Y
    Fractional Resampling On, Multi-Record, Heterogeneous Sample Rates
    N/A
    N/A
    N/A
    N/A
    Y
    N
    N/A
    N
    Note: Reference triggers that cannot be TClk synchronized (such as power edge reference triggers) can still be shared between devices by exporting them using the niScope Export Signal VI or the niScope_ExportSignal function.
    Link Library
    NI-SCOPE 2.1.4 and previous versions installed a duplicate version of the NI-SCOPE C link library called niscope_32.lib. This duplicate version has been obsoleted and now only niscope.lib is installed. Programs linking against the duplicate name need to be changed to link against niscope.lib.
    Visual Basic
    ViConstString, ViChar, and ViString are used as parameters for the NI-SCOPE functions. However, these types are invalid in Visual Basic. Visual Basic users should declare variables of type String.
    IVI
    The trigger type (NISCOPE_ATTR_TRIGGER_TYPE) for immediate triggering used to be returned as NISCOPE_VAL_EDGE (1). It is now returned as NISCOPE_VAL_IMMEDIATE_TRIGGER (6).
    © 1999–2010 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-12-12 19:17
