查看: 3188|回复: 0
[NI驱动程序] NI-SCOPE 3.5.2 Win32/64 Eng/Jpn NI示波器驱动程序SCOPE3.5.2
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-3-16 23:19:31 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SCOPE
    NI-SCOPE为使用NI示波器产品的客户提供支持。
    Win32/64Eng/Jpn
    3.5.2
    文件大小: 134776 字节 (131.62 KB)
    修改日期: 2010-04-25 08:11
    版本: 1.0.0.152
    MD5: 08b0fc418eb208daeeb76ad61cd92971(官方正确)
    SHA1: 4fd1730cc97278dc84a9e4b38c8dc621b945dcb0
    SHA256: 943822d451e2887161fd4a79b6599d590ceb0a83b7fee03d13ea943ade5a98b3
    CRC32: ffc5854f
    文件名: NI-HSDIO\dcd-aug09-1.exe
    文件大小: 234713088 字节 (223.84 MB)
    修改日期: 2020-12-14 02:10
    MD5: 7d39c504fc89f368057e1303f12d4ce8
    SHA1: c2a7144bc42c0ec9714dc3867293b5f4202edcfd
    SHA256: 572b56afed4d1a6de821674d7df8b25cc48420c5d4ab5387dae919acd4d4f0c9
    CRC32: f5eba52a
    SCOPE3.5.2.txt (2.11 KB, 下载次数: 4, 售价: 10 圆)
    NI-SCOPE ReadmeVersion 3.5.2
    June 2009
    Thank you for using the NI-SCOPE instrument driver for Windows Vista/XP/2000. This file contains important information about NI-SCOPE, and is organized into the following sections:
    • New Features
    • Supported Hardware
    • System Requirements
    • Installing/Uninstalling/Modifying NI-SCOPE
    • Programming in NI-SCOPE
    • Bug Fixes
    • Known Issues
    New Features in NI-SCOPE 3.5.2New Software Support
    • Support for LabVIEW 2009 (32-bit)
    • Support removed for LabVIEW 7.1.1
    New Features in NI-SCOPE 3.5.1New Hardware Support
    • NI PXI-5900 differential amplifier accessory
      Note: To attach the NI 5900 to a digitizer session, the digitizer must support DC coupling and 1 MΩ input impedance.
    • NI USB-5132/5133 32 MB per channel memory option
    • New VIs/functions:
      LabVIEW VIsC/C+ Functions
      niScope Cal Adjust Accessory Gain and OffsetniScope_CalAdjustAccessoryGainAndOffset
      niScope Cal Set Accessory SourceniScope_CalSetAccessorySource
    • New properties/attributes:
      [table=]
      [tr][td]LabVIEW Properties[/td][td]C/C++ Attributes[/td][/tr]
      [tr][td]Accessory Gain[/td][td]NISCOPE_ATTR_SIGNAL_COND_GAIN[/td][/tr]
      [tr][td]Accessory Offset[/td][td]NISCOPE_ATTR_SIGNAL_COND_OFFSET[/td][/tr]
      [/table]
    The following table shows which hardware products are supported under particular operating systems.
    Hardware ProductWindows XP/2000Windows Vista
    32-Bit
    Windows Vista
    64-Bit
    NI PXI/PCI-5102
    Yes
    Yes
    No
    NI PCMCIA/USB/AT-5102*
    Yes
    No
    No
    NI PXI/PCI-5105
    Yes
    Yes
    Yes
    NI PXI/PCI-5112
    Yes
    Yes
    No
    NI PXI/PCI-5114
    Yes
    Yes
    Yes
    NI PXI/PXIe/PCI-5122
    Yes
    Yes
    Yes
    NI PXI/PCI-5124
    Yes
    Yes
    Yes
    NI USB-5132/5133
    Yes
    Yes
    Yes
    NI PXI/PCI-5142
    Yes
    Yes
    Yes
    NI PXI/PCI-5152
    Yes
    Yes
    Yes
    NI PXI/PCI-5153
    Yes
    Yes
    Yes
    NI PXI/PCI-5154
    Yes
    Yes
    Yes
    NI PXI-5620
    Yes
    Yes
    No
    NI PXI-5621
    Yes
    No
    No
    NI PXIe-5622
    Yes
    Yes
    Yes
    NI PXI-5900
    Yes
    Yes
    Yes
    NI PCI-5911
    Yes
    No
    No
    NI PXI/PCI-5922
    Yes
    Yes
    Yes
    *NI PCMCIA/USB/AT-5102 are Legacy products.
    Note: MXI-4 is supported on Windows Vista/XP/2000. MXI-3 is supported only on Windows XP/2000.
    This section lists the minimum system and the recommended system for using NI-SCOPE.
    Minimum System Requirements
    • RAM—
      Windows 2000/XP: 128 MB
      Windows Vista: 512 MB
    • Windows Vista/XP/2000, with all available critical updates and service packs
    Recommended System
    • RAM—
      Windows 2000/XP: 256 MB
      Windows Vista: 1 GB
    • A screen resolution of 1024 x 768
    • One of the following application development environments (ADEs):
      • LabVIEW 8.2.1, 8.5.1, 8.6, or LabVIEW 2009 (32-bit)
      • LabVIEW Real-Time Module 8.2.1 or later (If you are running your application on an RT target, at least 128 MB of memory is required)
        Note: Not all devices are supported by the LabVIEW Real-Time Module.
        NI 5105
        NI 5114
        NI 5122
        NI 5124
        NI 5142
        NI 5152
        NI 5153
        NI 5154
        NI 5622
        NI 5900
        NI 5922
      • LabWindows™/CVI™ 7.1 or later
      • LabWindows™/CVI™ Real-Time Module 8.0 or later (If you are running your application on an RT target, at least 128 MB of memory is required)
      • Microsoft Visual Basic 6.0
    The following table shows the file names and default installation locations for each operating system.
    Note   (NIIVIPath) is configured as an environment variable on the target system. The file folder could be in one of the following four locations:
    If you did a clean install of IVI, your files may be in the following locations:
    • Windows 2000/XP/Vista 32-bit: Program Files\IVI Foundation\IVI\
    • Windows Vista 64-bit: Program Files (x86)\IVI Foundation\IVI\
    If you upgraded an installation of IVI, your files may be installed in the following locations:
    • Windows 2000/XP/Vista 32-bit: Program Files\IVI\
    • Windows Vista 64-bit: Program Files (x86)\IVI\
    FilesInstallation Location on Windows XP/2000
    and Windows Vista 32-Bit
    Windows Vista 64-Bit
    NI-SCOPE\Drivers\niScope\Drivers\niScope
    LabVIEW supportProgram Files\National Instruments\\instr.lib\niScopeProgram Files (x86)\National Instruments\\instr.lib\niScope
    LabVIEW ExamplesProgram Files\National Instruments\\examples\instr\niScopeProgram Files (x86)\National Instruments\\examples\instr\niScope
    CVI support\Drivers\niScope\Drivers\niScope
    CVI ExamplesProgram Files\National Instruments\\samples\niScopeProgram Files (x86)\National Instruments\\samples\niScope
    C Examples\Drivers\niScope\Examples\c\Drivers\niScope\Examples\c
    VB Examples\Drivers\niScope\Examples\VB\Drivers\niScope\Examples\VB
    NI-SCOPE Soft Front Panel 2.9\Drivers\niScope\Drivers\niScope
    NI-DAQmx 8.9.5 and
    NI-DAQ Traditional 7.4.4
    Program Files\National Instruments\NI-DAQProgram Files (x86)\National Instruments\NI-DAQ
    IVI Compliance Package 4.0Program Files\National Instruments\IVIProgram Files (x86)\National Instruments\IVI
    NI-VISA 4.5Program Files\National Instruments\SharedProgram Files (x86)\National Instruments\Shared
    NI Spy 2.7Program Files\National Instruments\NI SpyProgram Files (x86)\National Instruments\NI Spy
    Measurement & Automation Explorer 4.6Program Files\National Instruments\MAXProgram Files (x86)\National Instruments\MAX
    NI Hierarchical Waveform Storage 1.4.7Program Files\National Instruments\NI-HWSProgram Files (x86)\National Instruments\NI-HWS
    Documentation Files\Drivers\niScope\Documentation\Drivers\niScope\Documentation
    Most documentation is available at Start»All Programs»National Instruments»NI-SCOPE»Documentation. The documentation set is composed of the following documents:
    • NI High-Speed Digitizers Help
    • NI High-Speed Digitizers Getting Started Guide
    • NI 5102 Specifications
    • NI PXI/PCI-5105 Specifications
    • NI PXI/PCI-5112 Specifications
    • NI PXI/PCI-5114 Specifications
    • NI PXI/PXIe/PCI-5122 Specifications
    • NI PXI/PCI-5124 Specifications
    • NI USB-5132/5133 Specifications
    • NI PXI/PCI-5142 Specifications
    • NI PXI/PCI-5152 Specifications
    • NI 5153/5154 Specifications
    • NI PXI-5620 Specifications
    • NI PXI-5621 Specifications
    • NI PXIe-5622 Specifications
    • NI PXI-5900 Specifications
    • NI PCI-5911 Specifications
    • NI PXI/PCI-5922 Specifications
    • NI 5102 Calibration Procedure
    • NI 5105 Calibration Procedure
    • NI 5112 Calibration Procedure
    • NI 5114 Calibration Procedure
    • NI 5122/5124/5142 Calibration Procedure
    • NI USB-5132/5133 Calibration Procedure
    • NI 5152/5153/5154 Calibration Procedure
    • NI 5622 Calibration Procedure
    • NI 5900 Calibration Procedure
    • NI 5911 Calibration Procedure
    • NI 5922 Calibration Procedure
    Note: Printed copies of device specifications are shipped with each device.
    Installing/Uninstalling/Modifying NI-SCOPEInstalling NI-SCOPE
    This section provides information on installing NI-SCOPE and NI-DAQ and upgrading from previous versions of NI-SCOPE.
    NI-SCOPE installs NI-DAQ if it is not already installed, or if an earlier version of NI-DAQ is installed. NI-DAQ support files will be installed if you have LabVIEW or LabWindows/CVI in your system. However, the only component that NI-SCOPE needs from NI-DAQ is the device driver.
    Upgrading from a Previous Version of NI-SCOPE
    Upgrading from NI-SCOPE 1.0 and 1.1—NI-SCOPE does not install over NI-SCOPE 1.0 or 1.1. You must uninstall these versions of NI-SCOPE before installing a later version of NI-SCOPE.
    Upgrading from NI-SCOPE 1.5 and later—NI-SCOPE automatically uninstalls any previous version that is greater or equal to 1.5. If you have modified any old examples, these will be overwritten by the new versions.
    For Windows XP/2000, complete the following steps:
    • Click Change/Remove.
    • Select NI-SCOPE 3.5.2 from the dialog box that appears.
    For Windows Vista, complete the following steps:
    Do not attempt to uninstall by deleting files, which may be shared with other programs. The following additional software packages may have been installed as part of the NI-SCOPE installation. Exercise care when removing these packages because they may be used by other NI products:
    • IVI Compliance Package
    • NI-VISA
    • NI-DAQ and NI-DAQmx
    • Measurement & Automation Explorer
    • NI Hierarchical Waveform Storage
    NI-SCOPE provides an intuitive, full-featured interface for programming your hardware. NI-SCOPE is IVI-Scope compliant. For more information, refer to \Drivers\niScope\Documentation\niScopeIVIComplianceDocument.txt.
    Software Examples
    NI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start» Programs»National Instruments»NI-SCOPE»Examples.
    The NI-SCOPE Soft Front Panel (SFP) is a software oscilloscope application for NI high-speed digitizers. It has the following features:
    • Familiar interactive user interface
    • Robust architecture
    • Scalar measurements
    • Save/load waveforms
    • Save/load configurations
    • Low CPU usage
    The NI-SCOPE SFP demonstrates some of the capabilities of NI high-speed digitizers and enables you to start using your new digitizer immediately without the need to know a programming language. The NI-SCOPE SFP is installed by default as a feature of the NI-SCOPE installation. To remove the NI-SCOPE SFP use the Add/Remove Programs option.
    The following item is a change from earlier versions of NI-SCOPE to NI-SCOPE 3.5.2. If you have a Bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI-SCOPE.
    Bug IDFixed Issue
    NI-SCOPE
    162200Fixed an issue with the NI 5102 where, when closing a session, you would receive an invalid attribute error message.
    135430Fixed an issue where edge triggering on NI PXIe-5622 did not work properly below 2 mV. Trigger level can now be set below 2 mV.
    132626Fixed an external calibration error that occurred on some Windows XP German Edition machines.
    131709Fixed an issue with multi-record fetch for large number of records on multiple channels.
    123308Fixed an issue with inconsistent triggering when changing the trigger edge on the NI USB-5132/5133. You can now repeatedly change the trigger edge of a trigger on NI USB-5132/5133.
    143916Fixed an issue with the NI PXIe-5622 where, under some circumstances, the IQ power trigger does not work properly with the Ref Trigger Min Quiet Time property or the NISCOPE_ATTR_REF_TRIGGER_MINIMUM_QUIET_TIME attribute. Users must install the firmware update described above.
    Known IssuesNI 515x Devices and NI-TClk Sycnhronization
    When using an NI 515x device in TIS mode with NI-TClk synchronization and an external sample clock, the devices configured as the TClk slaves may fail to respond to reference triggers.
    Downgrading from NI-SCOPE 3.5.1
    If you need to downgrade from NI-SCOPE 3.5.1 to NI-SCOPE 2.1.4 or earlier, you must uninstall NI-SCOPE 3.5.1 and NI-DAQmx 8.8.0 before installing the older version of NI-SCOPE. After the older version of NI-SCOPE is installed, you can then reinstall NI-DAQmx 8.8.0.
    USB Device Stops Responding
    If you observe that a USB device stops responding when you insert or remove another USB device in the system, see Knowledge Base 4D4BO9AY at ni.com/support.
    NI PXIe-5622 Firmware Update
    A firmware update for the NI PXIe-5622 is available with NI-SCOPE 3.5.1 or later. The firmware updater is installed in the following locations:
    • Windows 2000/XP/Vista 32-bit: C:\Program Files\National Instruments\NI-DAQ\fpgafiles\ni5622\NI PXIe-5622 Firmware Updater.exe.
    • Windows Vista 64-bit: Program Files (x86)\National Instruments\NI-DAQ\fpgafiles\ni5622\NI PXIe-5622 Firmware Updater.exe.
    NI PXIe-5122 Firmware Update
    A firmware update for the NI PXIe-5122 is available with NI-SCOPE 3.5 or later. Under some circumstances, "Error -50500: A synchronization object was not acquired within the time limit. The operation could not be completed as specified." may occur while fetching data from the digitizer using the previous firmware. This is resolved by updating the NI PXIe-5122 firmware by running NI PXIe-5122 Firmware Updater.exe, the updater utility which installs with NI-SCOPE 3.5 into the following location:
    • Windows 2000/XP/Vista 32-bit: Program Files\National Instruments\NI-DAQ\fpgafiles\ni5122\
    • Windows Vista 64-bit: Program Files (x86)\National Instruments\NI-DAQ\fpgafiles\ni5122\
    For more details regarding the firmware update, refer to Knowledge Base 4MJGCSAY at ni.com/support.
    Function Reference Help
    If you click a topic link in the NI-SCOPE Function Reference Help section of the NI High-Speed Digitizers Help, you cannot use the Back button in the HTML Help window toolbar to return to the original topic.
    Using Help from LabVIEW
    When linking to a topic in the NI High-Speed Digitizers Help from the context help or opening the help file from a VI within LabVIEW, the NI High-Speed Digitizers Help launches and the relevant topic displays, but the location of the topic might not be highlighted in the table of contents.
    LabWindows/CVI
    The hyperlinks in the function panel context help in LabWindows/CVI versions 7.1 and 7.1.1 do not work unless you have downloaded the most recent version of the launchhelp.js file. Instructions for downloading and installing the file can be found in the KnowledgeBase (KB) entry Why Do I Get "Object Expected" Error When Opening Links in Function Panel Help? You can access this KB by visiting ni.com/info and entering rdnkbe in the Info Code field.
    Windows Power Management
    NI recommends that you disable Windows power management modes, such as sleep, standby, and hibernate, when using NI-SCOPE. These modes terminate any NI-SCOPE operation in progress. In Windows Vista or on a laptop computer, the default power management settings are likely to enable sleep mode.
    Security Prompts
    When you run setup.exe to install the software from the CD, you are prompted to choose whether you want to always trust software from National Instruments. If you do not select this option, your installation may be interrupted by one or more Microsoft Windows security dialog boxes. However, if you run setup from the command line, you will not receive this prompt, and the installer will automatically install NI's Software Publisher Certificate to your Windows Trusted Publisher Store. If you do not want to make this change to your Windows Trusted Publisher Store, do not choose this installation method.
    LabVIEW Support for Traditional NI-DAQ 7.4.2
    Starting with version 7.4.2, Traditional NI-DAQ (Legacy) will install support for the latest version of LabVIEW found on the system. If you require support for more than one version of LabVIEW, complete the following steps:
    • Install Traditional NI-DAQ (Legacy) 7.4.2 (included in the NI-SCOPE installer).
    • Restart the system.
    • Copy the following folders from the latest version of LabVIEW to the folder of the older version of LabVIEW. [LVDIR] indicates the folder of the latest LabVIEW version.
      • [LVDIR]\vi.lib\daq
      • [LVDIR]\examples\daq
      • [LVDIR]\help\lvdaq.chm
      • [LVDIR]\menus\default\daq
    You should now be able to use Traditional NI-DAQ (Legacy) with both versions of LabVIEW.
    The Traditional NI-DAQ (Legacy) API is mass-compiled in LabVIEW 7.0. This will not affect the functionality of your VIs. However, LabVIEW will prompt you to save the Traditional NI-DAQ (Legacy) subVIs if your LabVIEW version is greater than 7.0. To avoid the prompts, mass-compile the folders referenced above. If you require Traditional NI-DAQ (Legacy) support for earlier versions of LabVIEW, you need an earlier version of Traditional NI-DAQ (Legacy).
    NI-SCOPE Soft Front Panel Keyboard Shortcuts
    Beginning with NI-SCOPE 3.1, the following shortcuts have changed in the NI-SCOPE Soft Front Panel:
    • Increment trigger coupling has changed from to .
    • Decrement trigger coupling has changed from to .
    • now toggles the cursors.
    NI-SCOPE Express Step in NI Signal Express 1.0
    The NI-SCOPE Express step that ships with NI-SCOPE was designed for use with NI SignalExpress 1.1 or later. The NI-SCOPE Express step is compatible with NI SignalExpress 1.0 with the exception that software start triggers are not supported.
    TClk Connector Alignment in NI-SCOPE 2.7 and Later
    If you are using NI-TClk to synchronize non-identical devices (for example, an NI PXI-5122 with an NI PXI-5124), you will notice a change in behavior in the skew associated with synchronization when you upgrade from NI-SCOPE 2.6.1 to a later version. The new behavior compensates for delay associated with the input path. This delay varies from device to device. Because the driver now handles this delay, synchronizing any SMC-based products should produce data that has a small constant skew over all sample rates.
    NI 5102
    Board revision 183612F-01 of the NI PCI-5102 and board revision 184603E-01 of the NI PXI-5102 must be used with NI-SCOPE 2.6.1 or later. Board revision 183442G-01 of the NI PCMCIA-5102 must be used with NI-SCOPE 2.8 or later. To verify the board revision number, remove the device from the computer or chassis and turn it to view the side. The revision number is labeled "ASSY" and is located near the serial number. If you have an earlier version NI-SCOPE installed, go to ni.com/idnet to download the latest version.
    NI 5112
    You can now read data as soon as it is acquired. However, on a single record acquisition, the fetch functions do not wait for the trigger holdoff to expire. If you configure a trigger holdoff on a single record acquisition, you must make sure the trigger holdoff period has expired before initiating another acquisition. Call niScope_AcquisitionStatus to find out when the entire acquisition, including trigger holdoff, has completed.
    NI 5122
    • To change the rate of the external clock within the same session, you need to first change the rate by setting the Sample Clock Timebase Rate attribute, then change the rate of your source, then call the function niScope_Commit. If you change the rate of the source before setting the attribute, you may get an error. Another option is to abort the acquisition after fetching the data but before changing the rate.
    • Board revision 190100B-01 of the NI PXI-5122 must be used with NI-SCOPE 2.7 or later. To verify the board revision number, remove the device from the computer or chassis and turn it to view the side. The revision number is labeled "ASSY" and is located near the serial number. If you have an earlier version of NI-SCOPE installed, go to ni.com/idnet to download the latest version.
    NI PXI/PCI-5142, NI PXIe-5622
    TClk synchronization is not fully supported for certain cases. When the DDC Enabled property or the NISCOPE_ATTR_DDC_ENABLED attribute is set to True, there are certain configurations for which shared triggers cannot be TClk synchronized. The following table explains which triggers can be TClk synchronized for different configurations. For all cases, it is assumed that the DDC is enabled. If the DDC is not enabled, there are no restrictions on TClk synchronization.
    [table=]
    [tr][td=1,2]
    Configuration
    [/td][td=4,1]5142[/td][td=4,1]5622[/td][/tr]
    [tr][td]
    Start Trigger
    [/td][td]
    Reference Trigger
    (Digital)
    [/td][td]
    Reference Trigger
    (Analog Edge)
    [/td][td]
    Reference Trigger
    (Power Edge)
    [/td][td]
    Start Trigger
    [/td][td]
    Reference Trigger
    (Digital)
    [/td][td]
    Reference Trigger
    (Analog Edge)
    [/td][td]
    Reference Trigger
    (Power Edge)
    [/td][/tr]
    [tr][td]Fractional Resampling Off, All Cases[/td][td]
    Y
    [/td][td]
    Y
    [/td][td]
    Y
    [/td][td]
    N
    [/td][td]
    Y
    [/td][td]
    Y
    [/td][td]
    N/A
    [/td][td]
    N
    [/td][/tr]
    [tr][td]Fractional Resampling On, Single-Record, Homogeneous Sample Rates[/td][td]
    N/A
    [/td][td]
    N/A
    [/td][td]
    N/A
    [/td][td]
    N/A
    [/td][td]
    Y
    [/td][td]
    Y
    [/td][td]
    N/A
    [/td][td]
    N
    [/td][/tr]
    [tr][td]Fractional Resampling On, Single-Record, Heterogeneous Sample Rates[/td][td]
    N/A
    [/td][td]
    N/A
    [/td][td]
    N/A
    [/td][td]
    N/A
    [/td][td]
    Y
    [/td][td]
    N
    [/td][td]
    N/A
    [/td][td]
    N
    [/td][/tr]
    [tr][td]Fractional Resampling On, Multi-Record, Homogeneous Sample Rates[/td][td]
    N/A
    [/td][td]
    N/A
    [/td][td]
    N/A
    [/td][td]
    N/A
    [/td][td]
    Y
    [/td][td]
    Y
    [/td][td]
    N/A
    [/td][td]
    N
    [/td][/tr]
    [tr][td]Fractional Resampling On, Multi-Record, Heterogeneous Sample Rates[/td][td]
    N/A
    [/td][td]
    N/A
    [/td][td]
    N/A
    [/td][td]
    N/A
    [/td][td]
    Y
    [/td][td]
    N
    [/td][td]
    N/A
    [/td][td]
    N
    [/td][/tr]
    [/table]
    Note: Reference triggers that cannot be TClk synchronized (such as power edge reference triggers) can still be shared between devices by exporting them using the niScope Export Signal VI or the niScope_ExportSignal function.
    NI 5911
    When you synchronize multiple NI 5911 digitizers in master-slave mode, the sample rate must be 100 MHz, 50 MHz, or 25 MHz/n, where n is any positive integer. The master-slave operation may also cause trigger jitter.
    Link Library
    NI-SCOPE 2.1.4 and previous versions installed a duplicate version of the NI-SCOPE C link library called niscope_32.lib. This duplicate version has been obsoleted and now only niscope.lib is installed. Programs linking against the duplicate name need to be changed to link against niscope.lib.
    Visual Basic
    ViConstString, ViChar, and ViString are used as parameters for the NI-SCOPE functions. However, these types are invalid in Visual Basic. Visual Basic users should declare variables of type String.
    IVI
    The trigger type (NISCOPE_ATTR_TRIGGER_TYPE) for immediate triggering used to be returned as NISCOPE_VAL_EDGE (1). It is now returned as NISCOPE_VAL_IMMEDIATE_TRIGGER (6).
    © 1999–2009 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2025-12-12 19:15
