查看: 3021|回复: 0
[NI驱动程序] NI-SCOPE 3.1 Linux32/64Eng NI示波器驱动程序SCOPE3.1
  • 签到天数: 3740 天
    连续签到: 67 天
    发表于 2021-3-16 22:58:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-SCOPE
    NI-SCOPE为使用NI示波器产品的客户提供支持。
    Linux32/64Eng
    3.1
    文件大小: 55277568 字节 (52.72 MB)
    修改日期: 2010-04-29 20:36
    MD5: 166475dfa4292d0098aa49ff4c4ca04a(官方正确)
    SHA1: facb0b2c2f031b4c7c0f7fc0c06e389f7a81aea5
    SHA256: 5f1da2fefa23ba83426dfee374a2c90323210f89ebf5525b12e547b6eac46137
    CRC32: a14bf8c7
    SCOPE3.1Linux.txt (612 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-SCOPE for Linux/x86 32-bit, Version 3.1.
    Copyright (c) 2010 National Instruments Corporation.
    All Rights Reserved.
    National Instruments, NI, ni.com, and LabVIEW are trademarks of National
    Instruments Corporation. Refer to the Terms of Use section on ni.com/legal
    for more information about National Instruments trademarks.
    Linux(r) is the registered trademark of Linus Torvalds in the U.S. and other
    countries. Other product and company names mentioned herein are trademarks
    or trade names of their respective companies. For patents covering
    National Instruments products, refer to the appropriate location:
    Help>>Patents in your software, the patents.txt file on your CD,
    or ni.com/patents.
    Thank you for using NI-SCOPE for Linux. This file contains important information
    about NI-SCOPE and is organized into the following sections:
    Differences from the Windows Driver
    Installing NI-SCOPE for Linux
    Uninstalling NI-SCOPE for Linux
    Device Configuration
    NI-SCOPE Known Issues
    Support in NI-SCOPE 3.1 for Linux
    Examples and Other Documentation
    Not Supported under Linux
    The following NI-SCOPE driver features supported on NI-SCOPE for Windows are not
    supported under Linux:
    * The NI Measurements & Automation Explorer (MAX) application is not supported
      for Linux system and device configuration. Refer to the "Device Configuration"
      section for information about configuring your device in Linux. The following
      commonly used functions and features supported through MAX are not supported:
      - Device self-test
      - Device subsystem routing table
      - Querying of digital/analog power up states
      - Creating a simulated device
    * PCMCIA data acquisition products
    * NI-SCOPE Express VI
    * NI-SCOPE Soft Front Panel
    * MXI-3 is not supported. If you need PC control of a PXI system, use MXI-4.
    * NI-SPY
    * NI Hierarchical Waveform Storage (NI-HWS)
    * External calibration functions are not supported. Refer to your hardware
      documentation for information about external calibration, and refer to
      ni.com/calibration. If your NI digitizer requires external calibration,
      either perform the calibration on a Windows system or hire
      National Instruments or an independent calibration laboratory to perform
      the calibration.
    The installation process compiles a small amount of code to customize
    the software to your installation. Before running the installer, you must have
    the following compiler facilities installed from your Linux distribution CD
    or other Linux distribution medium:
    * The GCC compiler and C++ support
    * The make utility
    * The kernel source files that exactly correspond to the kernel version you
      are running.
      SUSE LINUX Professional users should ensure that the kernel sources
      have been configured before attempting installation. Refer to the
      "Installation Issues" section for directions on how to do this.
    Use the software-install facility of your Linux distribution to verify that the
    above-listed packages are present. You can then begin installation. If you are
    using LabVIEW, you must install LabVIEW before NI-SCOPE for the correct support
    files to be installed. You must have root privileges to install.
    Complete the following steps to install NI-SCOPE for Linux:
    1. Copy the "INSTALL" and the .tar.gz files to any directory.
       (Both files must be located in the same directory.)
    2. As root, run "./INSTALL".
    3. Follow the instructions of the installer.
    4. Power down your system, if needed.
       Note: Power down the system or reboot before using NI-SCOPE if prompted to
       do so by the installer. Also, power down the system if you want to install
       new hardware.
    5. Install any new NI hardware.
    6. Power on your system.
    7. Run "nilsdev" to verify installation. Refer to the "Device Configuration"
       section for more information.
    Installation Issues
    If you upgrade or change your kernel, you must rebuild part of your NI
    drivers after the new kernel is installed. To rebuild the software,
    use the updateNIDrivers utility, found in /usr/local/bin, and complete
    the following steps:
    1. Install the new kernel.
    2. Ensure the new kernel's sources and symbols are installed and
       configured.
    3. Restart and load the new kernel.
    4. As root, run "/usr/local/bin/updateNIDrivers". By default, the
       updateNIDrivers utility rebuilds the driver for the currently
       running kernel using the kernel sources and copies it to the
       appropriate location.
    5. When prompted, restart again. After restarting, the NI drivers are
       running and ready for use with the new kernel.
    6. To verify the version of the currently running kernel, run
       "uname -r" at the command prompt. Be sure to have sources for
       your kernel properly installed and configured on your system before
       running the utility.
    For more options, run "/usr/local/bin/updateNIDrivers --help".
    To compile the drivers for a different kernel than you are currently
    running, pass the kernel version as an argument to the utility, as
    shown in the following example:
    updateNIDrivers
    The kernel version format varies between distributions. Check the
    contents of /lib/modules or refer to your distribution documentation
    for more information. For the changes to take place, you must restart
    your computer after the utility completes.
    During installation on SUSE LINUX Professional, you may see the following
    error message: "Kernel source does not appear to be configured for the
    running kernel. Configuration of kernel source is required to continue
    installation." This message can occur even if you have installed the
    correct kernel sources, if the sources require configuration. This problem
    has been seen on SUSE LINUX Professional. However, it is possible that
    other distributions will require similar steps to resolve this problem.
    On SUSE LINUX Professional complete the following steps:
    1. Ensure you have installed the kernel-source and, if applicable, kernel-syms
       packages corresponding to the version of the currently running kernel. The
       version of the currently running kernel can be determined by issuing the
       command "uname -r".
    2. Change the directory to the /usr/src/linux- directory, where
        corresponds to the currently running kernel version.
    3. Run "make cloneconfig" as root to configure the sources for the
    4. Run "make modules_prepare" as root to prepare the headers for
       compilation.
    5. THIS STEP IS STRICTLY OPTIONAL. Completing this step removes the
       warning:
       "WARNING: Symbol version dump /usr/src/linux/Module.symvers is missing;
                 modules will have CONFIG_MODVERSIONS disabled."
       Run "make modules" as root to compile all modules and generate
       Module.symvers. This step may take 30 minutes or more to complete.
    6. Run the INSTALL script for the NI-SCOPE software for Linux from this
       directory.
    To uninstall NI-SCOPE, complete the following steps:
    1. Copy the "UNINSTALL" and the .tar.gz files to any directory.
    2. As root, run "./UNINSTALL".
    3. Follow the instructions of the uninstaller.
    The uninstaller does not remove certain LabVIEW and NI-VISA packages that might
    still be in use by LabVIEW and NI-VISA themselves or other National Instruments
    products. Leave these packages on the system if you are still using any National
    Instruments products. If you wish to remove all National Instruments products
    from the system you can remove these packages manually.
    This command removes the LabVIEW runtime engine package installed by NI-SCOPE:
    rpm -e labview80-rte labview-aal
    This command removes NI-VISA:
    /usr/local/vxipnp/linux/NIvisa/UNINSTALL
    After removing NI-VISA, you can run the NI-SCOPE UNINSTALL script again to remove
    additional packages.
    Any time a digitizer is added or removed, run the following command-line utility
    (which does not require root permissions): "nilsdev".
    If /usr/local/bin is not in your path, run the command using the full path:
    "/usr/local/bin/nilsdev".
    This command displays all detected NI-SCOPE devices. Make a note of the device
    names (Dev1, for example). Use the device names when running examples or
    writing your own programs. Refer to the "NI-DAQmx 8.0 for Linux Configuration
    Guide" for additional configuration instructions.  That document is installed at
    /usr/local/natinst/nidaqmx/docs/ConfigurationGuide.html. The directions for using
    nilsdev, nidaqmxconfig, DAQmxTestPanels, and nipxiconfig in DAQmx also apply
    to NI-SCOPE.
    This section covers issues specific to NI-SCOPE.
    * On the NI 5122 digitizer, to change the rate of the external clock with the same
      session, you need to first change the rate by setting the Sample Clock Timebase
      Rate attribute, then change the rate of your source, then call the function
      niScope_Commit. If you change the rate of the source before setting the attribute,
      you may get an error. Another option is to abort the acquisition after fetching
      the data but before changing the rate.
    * LabVIEW and NI-SCOPE may not work properly with the Exec-Shield security
      feature as implemented by some Linux distributions. So far this problem
      has been seen only on Red Hat distributions. Running on Red Hat with
      Exec-Shield enabled, you may receive a segmentation fault when running
      LabVIEW, or in C/C++ when running the self-calibration function
      (niScope_CalSelfCalibrate) on an NI 5922 digitizer.
      If you encounter this problem, turn off the Exec-Shield security feature
      before running LabVIEW or your NI-SCOPE program. For instance, on Red Hat
      Enterprise Linux WS 3 you can disable Exec-Shield with a line in
      /etc/sysctl.conf:
        kernel.exec-shield=0
      Alternatively, you can temporarily disable Exec-Shield from a root command
      prompt:
        echo 0 > /proc/sys/kernel/exec-shield
    * In C or C++, use care if your NI-SCOPE application links to the Linux pthread
      library. Incorrect linking can lead to segmentation faults when the NI-SCOPE
      library loads. It is recommended to link your application with gcc's -pthread
      flag instead of linking directly with, for instance, -lpthread. If, after
      replacing -lpthread links, you still get a segmentation fault when loading
      NI-SCOPE, it might be necessary to explicitly link in the dl library (-ldl) as
      the first library in your link list.
    Minimum System Requirements
    * Processor: Pentium 200 MHz or equivalent
    * RAM: 64 MB
    * XWindows must be running
    Recommended System
    * RAM: 64 MB
    Operating System Support
    NI-SCOPE 3.1 for Linux software for the Intel x86 32-bit architecture is
    supported on the following Linux distributions:
    * Mandrakelinux 10.1 Official
    * Mandriva Linux 2006
    * SUSE LINUX Professional 9.3
    * SUSE LINUX 10.0
    * Red Hat Enterprise Linux WS 3
    For more information about supported Linux versions and distributions supported
    by National Instruments, refer to ni.com/linux.
    NI-SCOPE for Linux supports two application development environments (ADEs):
    * LabVIEW 8.0 (installing the 8.0.1 update is recommended)
    * C and C++ through the use of the gcc compiler
    NI-SCOPE for Linux does not support other ADEs, such as
    the LabVIEW Real-Time Module, LabWindows/CVI, and Measurement Studio.
    Also, some features available through LabVIEW for Windows are not
    available on Linux. Refer to the "Differences from the Windows Driver"
    section for a list of LabVIEW features unavailable on Linux.
    Device Support
    The following digitizers are supported:
    * NI PXI-5114
    * NI PXI/PCI-5122
    * NI PXI/PCI-5124
    * NI PXI/PCI-5922
    * NI PXI-5152
    The NI 5102, NI 5112, NI 5620, NI 5621, and NI 5911 digitizers are not
    supported.
    This release includes examples showing the use of NI-SCOPE in C and LabVIEW.
    C examples are located in /usr/local/natinst/niscope/examples. Make files
    are provided that link to the necessary libraries. When writing your own
    programs, link in the niScope_32 library as shown in the example make files.
    When using NI-TClk, also link in the niTClk library.
    The LabVIEW examples are located in the LabVIEW examples/instr/niScope
    directory.
    You can also find the LabVIEW examples with LabVIEW's Example Finder. However,
    some of the NI-SCOPE examples shown do not apply to Linux and report a "could
    not be found" message when selected. Also note that the Example Finder may not
    run unless you have done a full LabVIEW installation, including the Example
    Finder and LabVIEW VI Examples options.
    Be sure to run the device configuration utility as described in the "Device
    Configuration" section before running examples.
    Additional documentation is in an .html format, which can be opened, viewed,
    and printed in any Linux-based HTML browser. The help is installed in the
    following location: /usr/local/natinst/niscope/doc/index.html. Refer to the
    "Device Configuration" section for the location of the documentation
    about device configuration.
    If you are synchronizing multiple devices with NI-TCLK, also use a web
    browser to view the NI-TCLK Help at /usr/local/natinst/nitclk/doc/index.html.
    GMT+8, 2025-12-12 19:15
