查看: 2703|回复: 0
[LV工具模块] NI Multisim Blue 13.0 Win32 Eng/Ger/Jpn NI电路设计软件13.0
  • 签到天数: 3562 天
    连续签到: 7 天
    发表于 2021-3-13 22:42:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Multisim Component Evaluator Mouser Electronics Edition电路设计软件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    文件大小: 813663064 字节 (775.97 MB)
    修改日期: 2014-09-28 12:29
    MD5: 41535d510e77dc647c30bf6ea42c9541
    SHA1: 238e45ef57aa0b078c45504b90f94c5377dbcb5e
    SHA256: 8dad1f37137c4d807aca6d53d05cdafb9ab9bc0bc4754ea05eb8a41044343f0e
    CRC32: 700f1170
    MultiSIM_BLUE13.0.txt (576 Bytes, 下载次数: 0, 售价: 10 元)
    Multisim Component Evaluator Mouser Electronics Edition 13.0.1 Readme for Windows
    September 2014
    This file contains important last-minute information about Multisim Component Evaluator.
    Refer to the Getting Started with NI Multisim Component Evaluator Mouser Electronics Edition manual for useful information including a tutorial. You can access this PDF from Start»All Programs»National Instruments»Multisim Component Evaluator 13.0»Mouser Electronics Edition»Documentation»Multisim Component Evaluator 13.0 Getting Started.
    Supported Platforms
    Supported Platforms
    Multisim Component Evaluator supports Windows Vista/XP 32-bit editions, Windows Vista 64-bit edition, Windows 7 32-bit and 64-bit editions, Windows 8 32-bit and 64-bit editions, Windows 8.1 32-bit and 64-bit editions, Windows Server 2003 R2 (32-bit) and Windows Server 2008 R2 (64-bit). Multisim Component Evaluator does not support Windows NT/Me/98/95/2000, Windows XP x64, or the Windows Server non-R2 editions.
    When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications to either the Start screen or the Taskbar on the desktop, as necessary:
    Finding All Programs
    NI Multisim Component Evaluator Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Multisim Component Evaluator will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Multisim Component Evaluator that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003.
    Known IssuesLabVIEW
    • LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. In the Vista OS, use the "Current language for non-Unicode programs:" setting in the Administrative tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    • You cannot install Multisim Component Evaluator on Windows Vista Starter edition.
    Multisim
    • Multisim leaks GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behaviour and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    Refer to the Multisim Help, accessible from the Help menu, for information about Multisim Component Evaluator.
    © 2007–2014 National Instruments. All rights reserved.
    374841A-01
    GMT+8, 2025-6-9 09:49
