查看: 2973|回复: 0
[Patch补丁] NI Circuit Design Suite 14.0.1 Patch Win32Eng/Ger NI电路设计套件14.0.1补丁
    14 小时前
  • 签到天数: 3629 天
    连续签到: 3 天
    发表于 2021-3-13 00:34:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Circuit Design Suite(CDS)电路设计套件
    电路设计套件结合了Multisim和Ultiboard软件,为电路设计、仿真、验证和布局提供了一套完整的工具。
    电路设计套件为您提供了直观且经济高效的设计电路工具。您可以执行交互式SPICE仿真并无缝转换到PCB布局和布线软件。该套件专为教学、科研和设计而开发,提供了先进的仿真功能,可以让您清楚地了解电路在各种场景下的性能。
    14.0.1Patch
    文件大小: 30257376 字节 (28.86 MB)
    修改日期: 2019-06-25 02:41
    MD5: b84b35696f2ff3d67f8e148d26edb676
    SHA1: d8aa223c6c9e6babf8ad7e8c5e44596782179f16
    SHA256: 02b646c9d44de5cee4e6bb781e6ada5169de05d4a5f4d4f5ea97532b03718bad
    CRC32: 9232b382
    CDS14.0.1Patch.txt (618 Bytes, 下载次数: 0, 售价: 1 圆)
    NI Circuit Design Suite 14.0.1 Readme for Windows
    February 2016
    This file contains important last-minute information about Circuit Design Suite 14.0.1 for Windows, including installation and compatibility issues.
    Refer to Getting Started with NI Circuit Design Suite for information about getting started with Circuit Design Suite. You can access this PDF from Start»All Programs»National Instruments»Circuit Design Suite 14.0»Documentation»Circuit Design Suite 14.0 Getting Started.
    You can also access this from the Multisim or Ultiboard Help menu.
    Supported Platforms
    Installing Circuit Design Suite 14.0.1
    New Components
    Supported Platforms
    To run Circuit Design Suite 14.0.1, your operating system (OS) must be one of:
    • Windows 10/8.1/8/7/Vista (32-bit and 64-bit).
    • Windows XP SP3 (32-bit).
    • Windows Server 2008 R2 (64-bit).
    • Windows Server 2003 R2 (32-bit).
    Circuit Design Suite 14.0.1 does not support Windows NT/Me/98/95/2000, Windows XP x64, or the Windows Server non-R2 editions.
    Your system must also meet or exceed the following:
    • Pentium 4/M class microprocessor or equivalent.
    • 512 MB of memory (256 MB minimum).
    • 2 GB of free hard disk space.
    • 1024 x 768 screen resolution.
    • To develop custom LabVIEW-based instruments for use in Multisim, LabVIEW 2014 or 2015 is required.
    NI Circuit Design Suite Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Circuit Design Suite will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Circuit Design Suite that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about Circuit Design Suite's product life cycle, visit NI Multisim OS Support and System Requirements. The information on this page applies to Multisim and Ultiboard.
    Installing Circuit Design Suite 14.0.1Installing Multiple Versions
    Circuit Design Suite 14.0.1 updates Circuit Design Suite 14.0 side-by-side with Circuit Design Suite 13.x and prior.
    Archiving Circuit Design Suite databases
    National Instruments recommends that you regularly back up the files created within the Multisim and Ultiboard components of NI Circuit Design Suite. Additionally, you should back up internal files that store user-created data, such as databases. For more information about which files to backup and where to find them, refer to the Help.
    Uninstalling
    Uninstalling Circuit Design Suite will not remove user data. For more information about the locations of user database and configuration files, refer to the Archiving Data Help topic.
    Circuit Design Suite 14.0.1 Updates and Notifications
    You can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during an automatic installation of NI software.
    • For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, How Do I Automate the Installation of a Suited Installer?.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications to either the Start screen or the Taskbar on the desktop, as necessary:
    Windows 8.1 DesktopDesktop TaskbarRight-click application and select Pin to Taskbar
    Windows 8.1 DesktopStart screenRight-click application and select Pin to Start
    Windows 8.1 Start screenDesktop TaskbarRight-click application and select Pin to taskbar from the menu bar on the bottom of the screen
    Finding All Programs
    For more information about NI support for Windows 8.1, visit ni.com/windows8.
    Known IssuesLabVIEW
    LabVIEW functionality (LabVIEW instruments and grapher interpolation) will not work if the installation path uses characters that are not native to the "Language for non-Unicode programs" setting, available by selecting Start»Control Panel»Regional and Language Options and selecting the Advanced tab. In the Vista OS, use the "Current language for non-Unicode programs:" setting in the Administrative tab. LabVIEW functionality works for Unicode characters that are native to this setting.
    Windows Vista
    You cannot install Circuit Design Suite 14.0.1 on Windows Vista Starter edition.
    Multisim and Ultiboard leak GDI resource handles when used over extended periods of time, eventually leading to unpredictable user interface behavior and crashes. This is an issue with MFC applications running on Windows XP SP2 and Windows Server 2003. For more information and workarounds, refer to KB 4JREGSXL:Multisim or Ultiboard Leaking GDI Resource Handles.
    Multisim Help and Ultiboard Help display in very small windows on high resolution monitors (e.g., 3200 x 1800). To enlarge the windows, click in a help topic, hold down the Ctrl key and spin the mouse wheel. For notebook computers with precision touchpads, hold down the Ctrl key and use pinch-in and pinch-out gestures to zoom to the desired level.
    The following is a subset of the issues fixed since the last release of Circuit Design Suite.
    Multisim ( 47 )
    Bug IDDescription
    552261Changing Windows scale to a high value will affect Labview instrument's front panels.
    558467Netlist sometimes fails on DC OP Point when UIC is specified.
    560790Nexys2 config files do not contain clock pin information.
    523358Basys3 config file should not reference a non-existent user constraint file.
    526709Schematic designs sometimes open with oversized drawn components.
    517117Simple purely linear circuit does not converge.
    553522Poor recovery from divide by zero in expressions.
    550584The Logic Converter instrument is unable to build some circuits from expressions in Windows 10.
    553490Malconfigured pulse source causes an internal error during simulation.
    435230The Spice Parser have different behavior for a node that is located as a node and in an expression.
    283552Search for Components only searches for Component RefDes.
    534878Convergence error when building a circuit using the 555 Timer Wizard using its default values.
    534639Automatically calculating TMAX is failing for simple circuits.
    542863Current Probe variable sometimes is not showing up on Grapher.
    534833Circuit simulates even though there is no ground present in the schematic.
    525445Probes do not show up in output variable lists when they are connected to advanced level transistors.
    478804Symbol pin name "NC" does not get rename automatically when creating a multi-section part.
    498811When a net is named with the word 'open' it will not show in the analysis output tab.
    533014OECL import has incorrect fill behavior.
    534762Upon transferring to Ultiboard sometimes some net connections are not preserved.
    509585Upon using a large tdm or tdms file and selecting the Reload file option for a TDM source component, Multisim will take a long time to load the data.
    518678Upon re-sizing the edit model dialog, the model data area will overwrite the model header box.
    525451Changes to the Routing Layers in Net Properties PCB tab does not get applied.
    515521Selecting the Simplified Version option will add redundant menus in Breadboard view.
    402113Component wizard allows you to proceed with no package pins mapped.
    371670Wire routing for certain pin types behaves incorrectly.
    483318Disabled values in dynamic dialog are editable after the dialog is reopened.
    535399When running LabVIEW-Multisim co-simulation, Multisim may crash if the Multisim design file is copied to a new location and the VI is updated to reference that new location.
    508357Component Refdes can incorrectly be edited from its Value tab.
    517171When merging two single pin sources there is no conflict dialog for other existing sources on page or multi-page design.
    532809Word generator single-stepping has incorrect behavior.
    518526Nested ternary expressions are not handled well by the SPICE parser.
    525293Multisim will truncate silently a model name that is greater than 49 characters.
    513013Edit model dialog not showing instance parameters when default parameters are specified in the template.
    528549Deleting multi-pages then backward annotating from a ewnet file may lead to a crash in Multisim.
    526512Circuit Parameters data sometimes is lost when design is opened.
    524758VSWITCH device should support the hysteresis parameters.
    506434User field titles are not immediately updated in Database Manager, Components tab.
    524983Model mapping is being affected when there is NC for pin name in the model.
    524605Advanced Pin Mapping maps pins incorrectly when sorting a Multi section component pin table.
    520020Cannot Search specifically for Buses anymore.
    523846In a 32-bit OS, refreshing a PLD device status with 64-bit Xilinx tool can crash the application.
    523348Multisim runs out of memory when running ac sweep from a very small frequency, which can lead to a crash.
    517340Complete Replace Components operation on any page other than the one the selected component is on will lead to a crash.
    520916The revision field within Title Block is limited to only 3 characters.
    523178Component properties are not updated properly when hidden pins are added/renamed.
    517887Device specific parameters value does not allow to enter a decimal point.
    Ultiboard ( 16 )
    Bug IDDescription
    553185Off-centered holes on pads revert back to the center after saving.
    547814Exporting Gerber and NC Drill in imperial unit does not match the drill target and hole locations.
    535013Exporting Gerber 274X will generate file with missing D code 10.
    488146Gate Swap does not work for custom component when its footprint is on the User DB.
    496161Ultiboard reference Identifier label is set back to the default position after updating the part.
    480717Default settings for PCB copper layers are not always respected by the layers in the design toolbox.
    537054Square holes are reported as design rule violations on export but not on DRC check.
    537067Picture properties not working consistently when importing bitmaps and using keep aspect ratio.
    539855Placing images in footprint edit mode should not create true-colour images.
    511935Cannot place picture from right-click menu in net bridge edit or custom pad shape edit modes.
    515037Using the Follow-me router to complete a route may sometimes hang Ultiboard.
    469108Unable to place a SMT part under another SMT part on the opposite side due to a corrupted hidden attribute.
    508292When Custom Hole and Standard Hole shapes are selected, then opening their shared Properties can lead to a crash.
    513232When Keep-In area has the Part Height option set and placing a part from the CAD family can lead to a crash.
    511757Cannot Export design reports in HTML format type.
    519656German Ultiboard displays Drill Symbols table header text with '?' in some of the words.
    New Components
    Refer to the Database section of the Multisim 14.x Features and Improvements topic of Multisim Help for a list of new components.
    Legal InformationCopyright
    © 2006-2016 National Instruments Corporation. All rights reserved.
    375231B-01
    GMT+8, 2025-8-20 23:29
