查看: 3341|回复: 0
[NI软件套件] LabVIEW Communications System Design Suite 5.0.0 Win64多国语言 LabVIEW NXG通信系统设计套件8.1.0
    昨天 21:26
  • 签到天数: 3790 天
    连续签到: 41 天
    发表于 2021-3-8 23:11:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW通信系统设计套件
    LabVIEW通信系统设计套件将LabVIEW NXG与专为帮助您快速开发无线通信系统原型而设计的工具结合起来。
    LabVIEW通信系统设计套件可帮助您在同一环境中为不同的硬件终端(如通用处理器、NI Linux实时操作系统和FPGA)设计、开发和部署无线通信系统。无线设计和原型验证团队可以借助统一的图形化编程方法,缩短使用空口(OTA)信号验证无线算法的时间,并能够直接调用使用The MathWorks, Inc. MATLAB软件创建的代码并导入自定义VHDL代码。MATLAB软件并导入自定义VHDL代码。
    Win64中文, 德语, 日语, 法语, 英文, 韩语
    5.0.0
    文件大小: 21031847936 字节 (19.59 GB)
    修改日期: 2020-05-19 04:57
    MD5: 37a20bd34a4649282f4eebb3d1a3a87a(重复一致)
    SHA1: 75a1a18a696d6be39fadb08d4929fbc00ce6c782
    SHA256: 349cd43d951b6c0236b01eba1793f0f671808ba9a92d6f8b61ddb9f88655a25d
    CRC32: bb753b44
    LVNXG通信系统设计套件5.0.0.txt (730 Bytes, 下载次数: 0, 售价: 30 圆)
    LabVIEW Communications System Design Suite 5.0 Readme
    May 2020
    This file contains important information about the LabVIEW Communications System Design Suite, including installation instructions, new features, a partial list of bugs fixed for LabVIEW Communications System Design Suite 5.0, and known issues.
    LabVIEW Communications System Design Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 (32- and 64-Bit), and All 32-Bit Operating Systems in 2021
    LabVIEW Communications System Design Suite combines LabVIEW NXG with tools that are specifically created to help you rapidly prototype wireless communications systems. LabVIEW Communications System Design Suite helps you design, develop, and deploy wireless communications systems to multiple hardware targets, such as general-purpose processors, NI Linux Real-Time operating systems, and FPGAs all in the same environment.
    LabVIEW Communications System Design Suite 5.0 has the following requirements:
    • 64-bit version of Windows 10/8.11/7 SP12/Server 2012
    • 10 GB disk space (20 GB or higher recommended)
    • To improve performance, installing LabVIEW NXG on a solid state drive (SSD) is recommended
    • 2 GB RAM (8 GB or higher recommended)
    • .NET Framework 4.6.2
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    LabVIEW Communications System Design Suite supports the following operating systems:
    • Windows 10 (version 1909)/8.1 Update 11/7 SP12
    • Windows Server 2012 R2 Update1
    Note  On Windows 8.1/Server 2012 R2/Server 2008 R2 SP1, some features, such as local compile, Optimized FPGA VIs, simulation of FPGA code that includes Xilinx IP or HDL code, are not supported because these features require the Xilinx compilation tools which do not support these OSes. Using these features on these OSes may result in unpredictable results.
    Note  Refer to LabVIEW Communications System Design Suite 5.0 Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 (32- and 64-Bit), and All 32-Bit Operating Systems in 2021 for information about future OS support.
    NI installs LabVIEW Communications System Design Suite using NI Package Manager. If you do not already have NI software installed, LabVIEW Communications System Design Suite installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate LabVIEW Communications System Design Suite. For more information on LabVIEW Communications System Design Suite activation, refer to National Instruments Software Activation.
    You can access the software and documentation known issues list online. Visit LabVIEW Communications System Design Suite Known Issues for an up-to-date list of known issues.
    You can access the issues fixed online. Visit LabVIEW Communications System Design Suite Bug Fixes for an up-to-date list of issues fixed.
    Search for items using the search bar in the upper right corner of the LabVIEW Communications System Design Suite window.
    View context help in LabVIEW Communications System Design Suite by pressing and hovering over an object. Refer to the LabVIEW Communications System Design Suite Manual, accessible from Help»Online Manual, for more information about LabVIEW Communications System Design Suite.
    To learn the theory behind the code, use interactive lessons in the Learning tab that contain example code within the environment.
    LabVIEW Communications System Design Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    LabVIEW Communications System Design Suite will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2014-2020 National Instruments. All rights reserved.
    376333G-01
    GMT+8, 2026-2-2 01:37
