查看: 4168|回复: 0
[NI软件套件] LabVIEW Communications System Design Suite 4.0.0 Win64多国语言 LabVIEW NXG通信系统设计套件7.1.0
    昨天 21:26
  • 签到天数: 3790 天
    连续签到: 41 天
    发表于 2021-3-8 23:09:02 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW通信系统设计套件
    LabVIEW通信系统设计套件将LabVIEW NXG与专为帮助您快速开发无线通信系统原型而设计的工具结合起来。
    LabVIEW通信系统设计套件可帮助您在同一环境中为不同的硬件终端(如通用处理器、NI Linux实时操作系统和FPGA)设计、开发和部署无线通信系统。无线设计和原型验证团队可以借助统一的图形化编程方法,缩短使用空口(OTA)信号验证无线算法的时间,并能够直接调用使用The MathWorks, Inc. MATLAB软件创建的代码并导入自定义VHDL代码。MATLAB软件并导入自定义VHDL代码。
    Win64中文, 德语, 日语, 法语, 英文, 韩语
    4.0.0完整版/专业版
    文件大小: 19995893760 字节 (18.62 GB)
    修改日期: 2019-10-31 08:48
    MD5: b91d07426695958dd20b2a54777c8428(官方正确)
    SHA1: 602bb5ac42982bce100a0099e1d6cfcefe6fd6f5
    SHA256: 02e24b222cafb130b1a17ff7a1e3bf009bf92d8eab3e31754bf93e83e890c2a4
    CRC32: 35563513
    LVNXG通信系统设计套件4.0.0.txt (743 Bytes, 下载次数: 2, 售价: 30 圆)
    LabVIEW Communications System Design Suite 4.0 Readme
    November 2019
    This file contains important information about the LabVIEW Communications System Design Suite, including system requirements, known issues, and a partial list of bugs fixed for LabVIEW Communications System Design Suite 4.0.
    Real-Time Hardware Compatibility
    Patch Details
    LabVIEW Communications System Design Suite 4.0 Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 (32- and 64-Bit), and All 32-Bit Operating Systems in 2021
    LabVIEW Communications has the following minimum system requirements:
    • 64-bit version of Windows 10/8.11/7 SP12/Server 2012
    • 45 GB disk space
    • 8 GB RAM
    • .NET Framework 4.6.2
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    Note  Refer to LabVIEW Communications System Design Suite 4.0 Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 (32- and 64-Bit), and All 32-Bit Operating Systems in 2021 for information about future OS support.
    The RT controller you purchase with LabVIEW Communications 4.0 comes with a compatible version of NI Linux Real-Time.
    To use an RT controller that you did not receive with LabVIEW Communications 4.0, update the real-time controller to a compatible version of NI Linux Real-Time. Refer to the NI website for a guide to updating your real-time controller for use with LabVIEW Communications 4.0.
    You can access an up-to-date list of known issues for a particular release of the LabVIEW Communications System Design Suite on the NI website.
    Documentation Known Issues
    Online Node Reference Topics Don't Reflect Real-Time Compatibility—The Compatibility tab for nodes that run on a real-time Linux operating system do not reflect that compatibility. However, when you target a VI to a real-time controller in SystemDesigner, you only have access to nodes that can run on the real-time controller.
    Patch Details
    You can access a list of issues fixed for a particular release of LabVIEW Communications on the NI website.
    LabVIEW Communications System Design Suite Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    LabVIEW Communications System Design Suite will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2014-2019 National Instruments. All rights reserved.
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Xilinx® is a registered trademark of Xilinx, Inc. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    For patents covering the NI products/technology, refer to the appropriate location: the patents.txt file on your media or the National Instruments Patent Notice at ni.com/patents.
    376333F-01
    GMT+8, 2026-2-2 01:36
