查看: 4156|回复: 0
[NI软件套件] LabVIEW Communications System Design Suite 3.0.1 Win64多国语言 LabVIEW NXG通信系统设计套件6.2.0
    昨天 21:26
  • 签到天数: 3790 天
    连续签到: 41 天
    发表于 2021-3-8 23:04:17 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW通信系统设计套件
    LabVIEW通信系统设计套件将LabVIEW NXG与专为帮助您快速开发无线通信系统原型而设计的工具结合起来。
    LabVIEW通信系统设计套件可帮助您在同一环境中为不同的硬件终端(如通用处理器、NI Linux实时操作系统和FPGA)设计、开发和部署无线通信系统。无线设计和原型验证团队可以借助统一的图形化编程方法,缩短使用空口(OTA)信号验证无线算法的时间,并能够直接调用使用The MathWorks, Inc. MATLAB软件创建的代码并导入自定义VHDL代码。MATLAB软件并导入自定义VHDL代码。
    Win64中文, 德语, 日语, 法语, 英文, 韩语
    3.0.1
    文件大小: 11530855957 字节 (10.74 GB)
    修改日期: 2018-11-19 14:12
    MD5: 470f9d7b40d42ec52e44d4ca0eb30e45(官方正确)
    SHA1: 0cb980b50253e3562685cfc15b9fda54239e3a98
    SHA256: 5d82d0013a0a59b046d3e61d46c9e1813e7eebb75d85fdecaabe6efa404dea3e
    CRC32: 514f1199
    LVNXG通信系统设计套件3.0.1.txt (730 Bytes, 下载次数: 2, 售价: 30 圆)
    LabVIEW Communications System Design Suite 3.0 Readme
    November 2018
    This file contains important information about the LabVIEW Communications System Design Suite, including system requirements, known issues, and a partial list of bugs fixed for LabVIEW Communications System Design Suite 3.0.
    Real-Time Hardware Compatibility
    LabVIEW Communications System Design Suite is a design environment closely integrated with NI software-defined radio hardware for prototyping communications systems.
    To use code that you created with LabVIEW 2009 or later with LabVIEW Communications System Design Suite 3.0, use the NI Code Conversion Utility for LabVIEW Communications System Design Suite 3.0 to convert VIs, projects, and libraries into files that are compatible with the LabVIEW Communications System Design Suite.
    If you are using LabVIEW Communications System Design Suite 2.0, refer to the NI website for a guide to migrating code to the LabVIEW Communications System Design Suite 3.0.
    LabVIEW Communications 3.0 has the following requirements:
    • At least 45 GB of disk space
    • 8 GB RAM
    • .NET Framework 4.6.2
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    LabVIEW Communications System Design Suite 3.0 supports the following systems:
    • Windows 10 (version 1803)/8.11/7 SP12(64-bit)
    • Windows Server 2012 R2 Update1
    Note  On Windows 8.1/Server 2012 R2/Server 2008 R2 SP1, some features, such as local compile, Optimized FPGA VIs, simulation of FPGA code that includes Xilinx IP or HDL code, are not supported because these features require the Xilinx compilation tools which do not support these OSes. Using these features on these OSes may result in unpredictable results.
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    The RT controller you purchase with LabVIEW Communications System Design Suite 3.0 comes with a compatible version of NI Linux Real-Time.
    To use an RT controller that you did not receive with LabVIEW Communications System Design 3.0, update the real-time controller to a compatible version of NI Linux Real-Time. Refer to the NI website for a guide to updating your real-time controller for use with LabVIEW Communications System Design Suite 3.0.
    You can access the software known issues list online. Refer to the NI website for an up-to-date list of known issues in the LabVIEW Communications System Design Suite.
    Documentation Known Issues
    Online Node Reference Topics Don't Reflect Real-Time Compatibility—The Compatibility tab for nodes that run on a real-time Linux operating system do not reflect that compatibility. However, when you target a VI to a real-time controller in SystemDesigner, you only have access to nodes that can run on the real-time controller.
    You can Access the software bug fixes list online. Refer to the NI website for an up-to-date list of bug fixes in the LabVIEW Communications System Design Suite.
    Search for items using the search bar in the upper right corner of the LabVIEW Communications System Design Suite window.
    View context help in LabVIEW Communications System Design Suite by pressing and hovering over an object. Refer to the LabVIEW Communications System Design Suite Manual, accessible from Help»Online Manual, for more information about LabVIEW Communications System Design Suite.
    To learn the theory behind the code, use interactive lessons in the Learning tab that contain example code within the environment.
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, Customize and Automate the Installation of a Suited Installer.
    © 2014-2019 National Instruments. All rights reserved.
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Xilinx® is a registered trademark of Xilinx, Inc. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    For patents covering the NI products/technology, refer to the appropriate location: the patents.txt file on your media or the National Instruments Patent Notice at ni.com/patents.
    376333D-01
    GMT+8, 2026-2-2 01:37
