查看: 2951|回复: 0
[NI驱动程序] NI RF Signal Generators 19.1.6 Win64Eng NI RF信号发生器NI-RFSG19.1.6
    昨天 09:12
  • 签到天数: 3627 天
    发表于 2021-3-2 00:10:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    Win64Eng
    19.1.6
    文件大小: 4931717120 字节 (4.59 GB)
    修改日期: 2019-12-07 05:06
    MD5: 3773ff3b4e502a6323b2af461f331817(官方正确)
    SHA1: 6fd40f152ddcdc56fd35f2f2dc1e5f3548fe0b50
    SHA256: f57d6b9699bc6c285f25af82e53d9ca74506bc46311e21625ae0b990853b6a1c
    CRC32: cb6c95b6
    RFSA19.1.6.txt (597 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG 19.1.6 Readme
    October 2019
    This file contains important information about NI-RFSG, including new features, supported hardware, a partial list of bugs fixed for NI-RFSG 19.1.6, and known issues.
    NI-RFSG Drops Support for Windows 7 (64-Bit) and Windows Server 2008 in 2021
    This software installation provides support for customers using RF signal generator or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware.
    NI-RFSG 19.1.6 includes improvements for the PXIe-5831 in the Semiconductor Test System
    NI-RFSG 19.1.5 includes support for the PXIe-5841
    NI-RFSG 19.1 includes the following new features:
    • Support for the PXIe-5830/5831
    • Support for LO sharing on the PXIe-5830/5831 to improve phase noise performance
    • Support for the PXIe-5830/5831 in the NI-RFSG SFP
    NI-RFSG 19.0 includes support for LabVIEW 2019
    NI-RFSG 18.2 includes the following new features:
    • Support for de-embedding measurements on the PXIe-5840
    • Improvements to communication performance on the PXIe-5820/5840
    • Support for automatic LO sharing for the PXIe-5840 in the NI-RFSG SFP
    • Support for specifying external calibration date for the PXIe-5644/5645/5646 and PXIe-5820/5840 in System Configuration API and MAX
    NI-RFSG 18.1 includes the following new features:
    • Improvements to initiate performance on the PXIe-5820/5840
    • Support for associating the PXIe-5840 with the PXIe-5653 LO source
    • Support for the PXIe-5840 with PXIe-5653 in the NI-RFSG SFP
    • Support for controlling the RF IN LO OUT terminal on the PXIe-5840
    • Support for PXIe-5820/5840 self-calibration in System Configuration API
    • Support for modifying temperature resolution for automatic thermal correction
    • Support for modifying DMA buffer size to improve NI-RFSG write arb waveform performance
    • Support for clearing self calibrate range data on the PXIe-5644/5645/5646
    • Improvements to NI-RFSG write arb waveform and streaming performance
    NI-RFSG 18.0 includes the following new features:
    • Added support for LabVIEW 2018
    • Added the NI-RFSG .NET Class Library and NI-RFSG .NET examples to the installer
    NI-RFSG 17.1 includes the following new features:
    • Support for the PXIe-5820
    • Support for RF list mode on the PXIe-5820/5840
    • Support for System Configuration API and MAX for module temperature and self-calibration date and time
    • Support for sub-sample trigger and marker resolution on the PFI line for the PXIe-5820/5840
    The following table shows which hardware products are supported in the NI-RFSG instrument driver and the NI-RFSG SFP. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware ProductHardware ModelNI-RFSGNI-RFSG SFP
    RF Signal UpconverterPXI-5610
    I/Q ModulatorPXIe-5611
    Vector Signal TransceiverPXIe-5644
    PXIe-5645
    PXIe-5646
    PXIe-5820
    PXIe-5830
    PXIe-5831
    PXIe-5840
    PXIe-5841
    RF Analog Signal GeneratorPXI/PXIe-5650
    PXI/PXIe-5651
    PXI/PXIe-5652
    PXIe-5653
    PXIe-5654
    PXIe-5654 with
    PXIe-5696 Amplitude Extender
    Vector Signal GeneratorPXI-5670
    PXI-5671
    PXIe-5672
    PXIe-5673/5673E
    MXI Express and MXI-4 are supported on Windows 10/8.1/7.
    Note  You must install the same version of the NI-RFSA/NI-RFSG Runtime for PXIe-5644/5645/5646 and NI-RFSA/NI-RFSG Runtime for PXIe-5820/5830/5831/5840/5841 if you choose to install the runtimes independently.
    Note  For best memory performance on the PXIe-5831, NI recommends using only 64-bit applications.
    • 4 GB RAM*
    Note  NI-RFSG 19.1.6 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 19.1.6.
    NI-RFSG 19.1.6 and NI-RFSG SFP 19.1.6 support the following operating systems:
    • Windows 10/8.11/7 SP12 (64-bit)
    Note  In 2019 NI-RFSG dropped support for all 32-bit Windows operating systems. NI-RFSG will not install or run on an unsupported OS. Refer to NI-RFSG Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    [tr][/tr][/table][table]
    Application SoftwareVersions Supported by NI-RFSG
    LabVIEW2016, 2017 SP1, 2018 SP1, or 2019
    LabVIEW Real-Time Module2016, 2017, 2018 SP1, or 2019
    LabWindows/CVI2010 to current
    LabWindows/CVI Real-Time Module2010 to current
    Note When using NI-RFSG with LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module, the PXIe-5644/5645/5646, PXIe-5654/5654 with PXIe-5696, and the PXIe-5820/5830/5831/5840/5841 are not supported.
    NI installs NI-RFSG using NI Package Manager. If you do not already have NI software installed, NI-RFSG installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    You can access all the installed NI-RFSA examples at Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Examples.
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    • Hardware device overviews
    Calibration Procedure for your devicePDFContains calibration instructions for your device.
    NI-RFSG no longer installs IVI Compliance Package (ICP). NI-RFSG supports IVI configuration and runtime, but no longer installs the following IVI components:
    • IVI-COM Adapters
    The following are behavior changes in NI-RFSG 19.1 from NI-RFSG 18.2:
    • NI-RFSG SFP (32-bit) is no longer installed with NI-RFSG.
    The following are behavior changes in NI-RFSG 18.2 from NI-RFSG 18.1:
    • NI Script Editor is no longer installed with NI-RFSG.
    • The NI-RFSG Express VIs are now obsolete and are no longer installed.
    • The NI-RFSG RF Out LO Export Enabled property no longer requires the NI-RFSA LO Out Export Configure From RFSA property to be set to Enabled. NI-RFSG can change the export state of NI-RFSA without an open NI-RFSA session on the PXIe-5840. Ensure the NI-RFSA LO out export is generating a useful signal before using that signal for NI-RFSG operations.
    You can access the software and documentation known issues list online. Refer to the following locations at ni.com for an up-to-date list of known issues in NI-RFSG 19.1.6 and NI-RFSG SFP 19.1.6.
    • NI-RFSG Known Issues
    • NI-RFSG Soft Front Panel Known Issues
    Bug FixesNI-RFSG Instrument Driver
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSG instrument driver revisions. This table is not an exhaustive list of issues fixed in the current version of NI-RFSG.
    NI-RFSG 19.1.5
    742917Fixed an issue in which a PXIe-5840 configured to use an external LO rounded the external frequency if set through the Upconverter Center Frequency property or Upconverter Frequency Offset property instead of the LO Frequency property.
    NI-RFSG 19.1
    733780Fixed an issue in which the PXIe-5820/5840 did not hold Reference Clock and LO export terminal reservations after calling Commit.
    NI-RFSG 18.2
    670356Fixed an issue in which NI-RFSG returned a power level error if the PXIe-5840 temperature drift exceeded 10 °C from the last self-calibration temperature.
    NI-RFSG 18.1
    598644Fixed an issue where writing a large waveform on the PXIe-5840 resulted in an error.
    604856Fixed an issue where error message text contained multiple unrelated warnings and errors.
    668974Fixed an issue where the PXIe-5840 amplitude accuracy degraded after calling Perform Thermal Correction.
    682389Fixed an issue where the PXIe-5820/5840 trigger alignment was imprecise when using the PXI trigger lines.
    685044Fixed an issue where calling Reset on the PXIe-5840 reset the LO source to Onboard, even if the LO source was specified in the driver setup string.
    697475Fixed an issue where setting the calibration due date or retrieving the last date of external calibration for the PXIe-5820/5840 was not possible.
    689717Fixed an issue in which the PXIe-5644/5645/5646 and PXIe-5820/5840 showed an incorrect calibration time in MAX when the system timezone was greater than UTC+0.
    NI-RFSG 17.1.2
    664698Fixed an issue where a timeout error occurred when TClk was used with the PXIe-5820/5840 using the WLAN Toolkit.
    NI-RFSG 17.1
    601860Fixed an issue where an error occurred when changing the device name of the PXIe-5840 in MAX.
    515837Fixed an issue where the PXIe-5654 device name persisted for other devices inserted into the same slot.
    640124Fixed an issue where the PXIe-5840 could show a slow phase drift below 400 MHz.
    541356Fixed an issue where attribute names did not show up correctly in I/O trace.
    479015Fixed an issue where the niRFSG Reset VI and the niRFSG_reset function did not re-enable the output for the PXIe-5645.
    573420Fixed an issue where the default value of the Impairment Enabled property and the NIRFSG_ATTR_IQ_IMPAIRMENT_ENABLED attribute for the PXIe-5644/5645/5646 was incorrect.
    637641Fixed an issue where the PXI-5671 would incorrectly error with markers on a quantum of two when the DUC (digital upconverter) was enabled.
    NI-RFSG SFP
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSG SFP revisions. This table is not an exhaustive list of issues fixed in the current version of the NI-RFSG SFP.
    NI-RFSG SFP 18.1
    Bug IDFixed Issue
    609550Fixed an issue where saving and recalling a sweep list frequency larger than 2.15 GHz resulted in coercion to a value of 231.
    NI-RFSG SFP 16.0
    Bug IDFixed Issue
    575506Fixed an issue where changing external gain was not available for the PXIe-5644/5645/5646.
    NI-RFSG will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    ProductInfo Code
    LabWindows/CVIcvi_lifecycle
    © 2004–2019 National Instruments. All rights reserved.
    374769U-01
    GMT+8, 2025-8-19 09:11
