查看: 2961|回复: 0
[NI驱动程序] NI RF Signal Generators 17.0 Win32/64Eng NI RF信号发生器NI-RFSG17.0
    昨天 09:12
  • 签到天数: 3627 天
    发表于 2021-3-1 23:53:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    Win32/64Eng
    17.0
    文件大小: 3437920056 字节 (3.20 GB)
    修改日期: 2017-06-09 05:23
    MD5: db706ad516d97fd302515a4bc54180a6(官方正确)
    SHA1: b560c955f2e3cac393370e630737fe2bd049b7d4
    SHA256: 6529373c36ca495625d63e6a46da3ef6e78fbf6d9e71af8e5926f07f55dbe877
    CRC32: c17db278
    RFSA17.0.txt (557 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG 17.0 Readme
    May 2017
    This file contains important information about NI-RFSG, including new features, supported hardware, a partial list of bugs fixed for NI-RFSG 17.0, and known issues.
    Accessing VIs and Functions
    Uninstalling NI-RFSG
    This software installation provides support for customers using RF signal generator hardware, as specified in the Supported Hardware section. To program your RF signal generator, use the NI-RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using a RF signal generator.
    NI-RFSG 17.0 includes the following new features:
    • Support for LabVIEW 2017 (32- and 64-bit)
    • NI-RFSG Soft Front Panel 17.0
    NI-RFSG 16.0 includes the following new features:
    • Support for the PXIe-5840 vector signal transceiver (VST)
    • Improvements to the initiate performance on the PXIe-5644/5645/5646 devices
    • NI-RFSG Soft Front Panel 16.0, which includes the following new features:
      • Support for configuring I/Q impairments and external gain for PXIe-5644/5645/5646 devices
      • Support for the preceding new features listed for NI-RFSG
    NI-RFSG 15.0.3 includes the following new features:
    • Improvements to the external calibration procedure for the PXI/PXIe-5650/5651/5652 devices
    • NI-RFSG Soft Front Panel 15.0.3, which includes the following new features:
      • Improvements to the self-calibration procedure for the PXI-5670/5671 and PXIe-5672 devices
      • Support for reading and downloading a single precision waveform from a TDMS file in Arb Waveform generation mode
    NI-RFSG 15.0.2 includes the following new features:
    • Improvements to the self-calibration procedure for PXIe-5644/5645/5646 devices
    • Support for Windows 10 (32- and 64-bit)
    NI-RFSG 15.0 includes the following new features:
    • Support removed for LabVIEW 2011
    The following table shows which hardware products are supported in the NI-RFSG instrument driver and the NI-RFSG SFP. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware ProductNI-RFSGNI-RFSG SFP
    PXI-5610
    PXIe-5611
    PXIe-5644
    PXIe-5645
    PXIe-5646
    PXI/PXIe-5650
    PXI/PXIe-5651
    PXI/PXIe-5652
    PXIe-5653
    PXIe-5654
    PXIe-5654 with PXIe-5696
    PXI-5670
    PXI-5671
    PXIe-5672
    PXIe-5673/5673E
    PXIe-5840
    NI-RFSG has the following minimum requirements:
    • RAM—1 GB RAM* (32-bit) or 2 GB RAM (64-bit)
    NI-RFSG 17.0 and NI-RFSG Soft Front Panel 17.0 support the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 NI-RFSG dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI-RFSG 17.0 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI-RFSG 17.0 to an unsupported OS. Additionally, after installing NI-RFSG 17.0, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does My LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Note  NI-RFSG 17.0 does not support Windows Server non-R2 editions.
    NI-RFSG supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSG. To add support for ADEs installed after installing NI-RFSG, modify your NI-RFSG installation or launch the NI-RFSG installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    [tr][/tr][/table][table=98%]
    Application SoftwareVersions Supported by NI-RFSG
    LabVIEW2014 SP1, 2015 SP1, 2016, or 2017
    LabVIEW Real-Time Module2014 SP1, 2015 SP1, 2016, or 2017
    LabWindows/CVI2010 and later
    LabWindows/CVI Real-Time Module2010 and later
    Note When using NI-RFSG with LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module, the PXIe-5644/5645/5646/5654/5654 with PXIe-5696 devices are not supported.
        • (32-bit) Program Files\IVI\
    ItemInstalled Location
    NI-RFSG\Drivers\niRFSG
    NI-RFSG Function Panel\Drivers\niRFSG\niRFSG.fp
    NI-RFSG Examples\NI-RFSG\Examples
    NI-RFSG Header files\Include
    NI-RFSG Import Library files (32-bit)\Lib
    NI-RFSG DLL (32-bit)\Bin
    NI-RFSG SFP\Drivers\niRFSG
    NI-RFSG SFP Example Waveforms\NI-RFSG Soft Front Panel\examples\Waveforms
    Additional File Locations for 64-bit Operating Systems
    NI-RFSG Import Library files (64-bit)\Lib_x64
    NI-RFSG DLL (64-bit)\Bin
    Note  To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    • An introduction to RF Fundamentals
    • Hardware device overviews
    • A complete reference for all NI-RFSG programming VIs and functions
    Calibration Procedure for your devicePDFContains calibration instructions for your device.
    Note  To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    NI-RFSG functions are available in LabWindows/CVI from the Instrument menu. To load the NI-RFSG function panel (.fp), select Instrument»Load, and navigate to \Drivers\niRFSG\niRFSG.fp or \Drivers\niRFSG\niRFSG.fp.
    In LabVIEW and LabWindows/CVI, you can use the NI Example Finder to search or browse examples. Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. NI-RFSG examples are classified by keyword, so you can search for a particular device or measurement function. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI-RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI-RFSG or by directory structure at instr»niRFSG.
    • Click the Search tab to search all installed examples by keyword. For example, search for "RFSG" to locate all NI RF signal generator examples.
    You can also access all the installed NI-RFSG examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI-RFSG»Examples.
    Examples are also available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    As part of the NI-RFSG 17.0 installation, the following software is installed. To completely remove the NI-RFSG 17.0 installation from your system, you must also remove all of the following packages:
    • NI-RFSG Runtime 17.0 for DAQmx-Based Devices
    • NI-RFSG Runtime 17.0 for NI PXIe-5654
    • NI-RFSA/NI-RFSG Runtime 17.0 for NI PXIe-5644R/5645R/5646R
    • NI-RFSA/NI-RFSG Runtime 17.0 for NI PXIe-5840
    • NI VST Runtime 17.0 for NI PXIe-5644R/5645R/5646R
    • NI VST Runtime 17.0 for NI PXIe-5840
    • NI-FGEN Runtime 17.0
    • NI-DAQmx Runtime 17.0 with Configuration Support
    • NI-RIO Driver 17.0
    • NI-HWS 17.0
    • NI-VISA Runtime 17.0
    • NI I/O Trace 17.0
    • NI Measurement & Automation Explorer (MAX) 17.0
    • NI System Configuration Runtime 17.0
    • NI Hierarchical Waveform Storage 17.0
    Caution:Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent upon, a message warns you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    IVI Compliance Pacakge Functionality
    NI-RFSG no longer installs IVI Compliance Pacakge. NI-RFSG supports IVI configuration and runtime, but no longer supports the following features:
    • IVI-COM Adapters
    If you want to use the above features, you must install IVI Compliance Package separately, either from ni.com/downloads or from the NI Device Drivers 2017 DVD.
    NI-RFSG 15.0.3
    • Removed the reference level and resolution bandwidth outputs from niRFSG 5652 Configure Attenuator Calibration VI, which reflects changes to the NI PXIe-5650/5651/5652 Calibration Procedure (part number 373084F-01) and NI PXI-5650/5651/5652 Calibration Procedure (part number 375104F-01).
    NI-RFSG 14.5
    • When you delete a configuration list, NI-RFSG automatically resets the Active Configuration List property or NIRFSG_ATTR_ACTIVE_CONFIGURATION_LIST attribute to "" (empty string), which indicates no list is active, and the Active Configuration List Step property or NIRFSG_ATTR_ACTIVE_CONFIGURATION_LIST_STEP attribute to 0. Both properties or attributes immediately return an error if you try to set an invalid active list or active step.
    You can access the software and documentation known issues list online. Refer to the following locations at ni.com for an up-to-date list of known issues in NI-RFSG 17.0 and NI-RFSG SFP 17.0.
    • NI-RFSG Known Issues
    • NI-RFSG Soft Front Panel Known Issues
    Bug FixesNI-RFSG Instrument Driver
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSG instrument driver revisions. This table is not an exhaustive list of issues fixed in the current version of NI-RFSG.
    NI-RFSG 16.0
    560185Fixed an issue where the power level is incorrect until the amplification path is specified on the PXIe-5654 with PXIe-5696.
    570905Fixed an issue where after first commit, changes to the Waveform Repeat Count property or NIRFSG_ATTR_WAVEFORM_REPEAT_COUNT attribute and Waveform Repeat Count Is Finite property or NIRFSG_ATTR_WAVEFORM_REPEAT_COUNT_IS_FINITE attribute are ignored.
    NI-RFSG 15.0.3
    N/AFixed an issue where some PXI/PXIe-5650/5651/5652 devices fail calibration verification after calibration adjustment.
    562364Fixed an issue where incorrect power output occurred on the PXI-5670/5671 and PXIe-5672 for signals less than 2.5 MHz during Arb Waveform generation mode with digital equalization enabled.
    NI-RFSG 14.5
    489122Fixed an issue where the PXI/PXIe-5652 appears outside of the composite device in MAX.
    NI-RFSG 14.0.1
    492490Fixed an issue where LabVIEW Run-Time Engine 2013 SP1 does not install with NI-RFSG.
    NI-RFSG 14.0
    466905Fixed an issue where set frequency and power level execution time takes longer than expected on the PXIe-5644/5645/5646.
    The following items are the IDs and titles of a subset of issues fixed between NI-RFSG SFP revisions. This table is not an exhaustive list of issues fixed in the current version of the NI-RFSG SFP.
    NI-RFSG SFP 16.0
    Bug IDFixed Issue
    575506Fixed an issue where changing external gain was not available for the PXIe-5644/5645/5646.
    NI-RFSG SFP 15.0.3
    Bug IDFixed Issue
    549309Fixed an issue where incorrect power output occurred after self-calibration on the PXIe-5672.
    © 2004–2017 National Instruments. All rights reserved.
    374769H-01
    GMT+8, 2025-8-19 09:08
