查看: 2799|回复: 0
[NI驱动程序] NI RF Signal Generators 15.0 Win32/64Eng NI RF信号发生器NI-RFSG15.0
    昨天 09:12
  • 签到天数: 3627 天
    发表于 2021-3-1 23:47:10 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    Win32/64Eng
    15.0
    文件大小: 3030636120 字节 (2.82 GB)
    修改日期: 2015-08-03 22:12
    MD5: fcda2984e5d0c014cfbe3e4fda0264c0(官方正确)
    SHA1: b3ef8424892294a9f3b4bc92b5932543d422ca0b
    SHA256: d395402905387d6b1d0416b570d9ec79352edb89d307883c8741bc4fb42cc665
    CRC32: 9ea8279b
    RFSA15.0.txt (555 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG 15.0 Readme
    August 2015
    This file contains important information about NI-RFSG and is organized into the following sections:
    Accessing VIs and Functions
    Driver Version Naming Changes
    Uninstalling/Modifying NI–RFSG
    NI-RFSG Drops Support for Microsoft Windows XP and Windows Server 2003 in 2016
    NI RF Signal Generators Software
    This software installation provides support for customers using NI RF signal generator hardware, as specified in the Supported Hardware section. To program your NI RF signal generator, use the NI–RFSG instrument driver or NI-RFSG Soft Front Panel (SFP).
    The getting started guide for your device provides information about how to install, configure, test, and begin using an NI RF signal generator.
    NI–RFSG 15.0 includes the following new features:
    • Support removed for LabVIEW 2011
    NI–RFSG 14.5 includes the following new features:
    • Support for the NI PXIe-5654 RF signal generator
    • Support for the NI PXIe-5654 with NI PXIe-5696 amplitude extender (AE)
    • Support for LabVIEW 2014 SP1 (32- and 64-bit)
    • Support for I/Q impairments with vector signal transceiver (VST) devices
    • NI-RFSG Soft Front Panel 14.5, which includes the following new features:
      • Support for Arb Waveform generation mode with the NI 5644R/5645R/5646R and NI 5673E
      • Support for the preceding new features listed for NI-RFSG
    NI–RFSG 14.0 includes the following new features:
    • Support for LabVIEW 2014 (32- and 64-bit)
    • Support removed for LabVIEW 2010
    • NI-RFSG Soft Front Panel 14.0
    NI–RFSG 1.9.7 includes the following new features:
    • Support for the NI PXIe-5646R VST
    • Support for downloading a custom bitfile to a VST device
    • Support for 64-bit application software with VST devices
    • NI-RFSG Soft Front Panel 1.9.7, which includes support for the other new features in NI-RFSG 1.9.7
    NI–RFSG 1.9.6 adds support for the NI-RFSG Compensate for Filter Group Delay property for the NI PXIe-5672.
    NI–RFSG 1.9.5 includes the following new features:
    • Support for LabVIEW 2013 (32- and 64-bit)
    • Support removed for LabVIEW 2009
    • NI-RFSG Soft Front Panel 1.9.5, which includes the following new features:
      • Improved launch time
      • Quick save/recall of SFP configurations
      • Cursor data entry
      • Enhanced readability of saved configuration files
    NI–RFSG 1.9 includes the following new features:
    • Support for the NI PXIe-5644R/5645R vector signal transceivers
    • Includes the NI-RFSG Soft Front Panel (SFP) in the NI-RFSG installer
    • Improved the Measurement & Automation Explorer (MAX) test panel to use the NI-RFSG SFP
    • Improved representation of multiple-module devices in MAX
    The following table shows which hardware products are supported in the NI-RFSG instrument driver and the NI-RFSG SFP. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware ProductNI-RFSGNI-RFSG SFP
    NI PXI-5610
    NI PXIe-5611
    NI PXIe-5644R
    NI PXIe-5645R
    NI PXIe-5646R
    NI PXI/PXIe-5650
    NI PXI/PXIe-5651
    NI PXI/PXIe-5652
    NI PXIe-5653
    NI PXIe-5654
    NI PXI-5670
    NI PXI-5671
    NI PXIe-5672
    NI PXIe-5673/5673E
    Note  MXI Express and MXI-4 are supported on Windows 8.1/8.0/7/Vista/XP, but MXI-3 is supported on only Windows XP.
    NI-RFSG 15.0 and NI-RFSG Soft Front Panel 14.5 support the following operating systems:
    • Windows 8.1 (32-bit and 64-bit)
    • Windows 8.0 (32-bit and 64-bit)
    Note  NI-RFSG 15.0 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed.
    NI-RFSG 15.0 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    • LabWindows™/CVI™ Real-Time Module
    Note:When using NI-RFSG, the NI 5644R/5645R/5646R/5654/5654 with NI 5696 does not support the LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module.
    Minimum Runtime/Deployment System
    • RAM—
      • Windows XP Service Pack 3 (SP3): 512 MB (NI-RFSG), 1 GB (NI-RFSG SFP)
      • Windows 8.1/8.0/7/Vista: 1 GB
      Note:Depending on the amount of data generated or processed, a larger amount of RAM may be required.
    • Windows 8.1/8.0/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended Development System
    • RAM—
      • Windows XP SP3: 2 GB
      • Windows 8.1/8.0/7/Vista: 4 GB
    • If you are running your application on an RT target, 128 MB of memory or more is recommended.
    • Guest accounts are not supported under any OS.
    Application Development Environments
    Note:You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSG. To add support for ADEs installed after installing NI-RFSG, modify your NI-RFSG installation or launch the NI-RFSG installer again.
    NI Application SoftwareVersions Supported by NI-RFSG
    NI LabVIEW2012, 2013, 2014, or 2015
    NI LabVIEW Real-Time Module2012, 2013, 2014, or 2015
    NI LabWindows/CVI2010 or later
    NI LabWindows/CVI Real-Time Module2010 or later
    Note:Install any toolkits or add-on software you intend to use with the NI–RFSG instrument driver after NI–RFSG installation is complete. Refer to the getting started guide for your device for more information about software and hardware installation.
    Note:MXI users must install the software included with the MXI hardware.
      • Windows 8.1/8.0/7/Vista: Users\Public\Documents\National Instruments
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 8.1 (32-bit)/8.0 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 8.1 (32-bit)/8.0 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8.1 (32-bit)/8.0 (32-bit)/7 (32-bit)/Vista (32-bit)/XP
    NI-RFSG\Drivers\niRFSG
    NI-RFSG Function Panel\Drivers\niRFSG\niRFSG.fp
    NI-RFSG Examples\NI-RFSG\Examples
    NI-RFSG Header files\Include
    NI-RFSG Import Library files (32-bit)\Lib
    NI-RFSG DLL (32-bit)\Bin
    NI-RFSG SFP\Drivers\niRFSG
    NI-RFSG SFP Example Waveforms\NI-RFSG Soft Front Panel\examples\Waveforms
    Additional File Locations for Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8.1 (64-bit)/8.0 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-RFSG Import Library files (64-bit)\Lib_x64
    NI-RFSG DLL (64-bit)\Bin
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. The documentation set is composed of the following documents.
    DocumentFormatDescription
    • An introduction to RF Fundamentals
    • Hardware device overviews
    • A complete reference for all NI-RFSG programming VIs and functions
    Calibration Procedure for your devicePDFContains calibration instructions for your device.
    To use the .NET API, you must install the the .NET class libraries or the .NET Wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to the National Instruments .NET Driver Support document at ni.com/info and enter Info Code NETAPIdriversupport.
    Note  To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    NI–RFSG VIs are available in LabVIEW from the Functions»Measurement I/O»NI–RFSG palette.
    NI–RFSG functions are available in LabWindows/CVI from the Instrument menu. To load the NI–RFSG function panel (.fp), select Instrument»Load, and navigate to \Drivers\niRFSG\niRFSG.fp or \Drivers\niRFSG\niRFSG.fp.
    In LabVIEW, you can use the NI Example Finder to search or browse examples. NI–RFSG examples are classified by keyword, so you can search for a particular device or measurement function. In LabVIEW, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–RFSG or by directory structure at instr»niRFSG.
    • Click the Search tab to search all installed examples by keyword. For example, search for "RFSG" to locate all NI RF signal generator examples.
    You can also access all the installed NI–RFSG examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI–RFSG»Examples.
    Examples are also available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    NI-RFSG versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-RFSG 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-RFSG 1.9.8. The first version released under the new numbering scheme is NI-RFSG 14.0.
    • Click Change/Remove.
    • Select NI–RFSG 15.0 from the dialog box that appears.
    For Windows 8.1/8.0, complete the following steps:
    • Right-click the Start screen.
    • Click the Uninstall button.
    • Select NI-RFSG 15.0 from the dialog box that appears.
    As part of the NI–RFSG 15.0 installation, the following software is installed. To completely remove the NI–RFSG 15.0 installation from your system, you must also remove all of the following packages:
    • NI-RFSG Runtime 15.0
    • NI-RFSA/NI-RFSG Runtime 15.0 for NI VST
    • NI-DAQmx Runtime 15.0 with Configuration Support
    • NI-FGEN Runtime 15.0
    • NI-RIO 14.5.1
    • NI IVI Compliance Package 15.0
    • NI-VISA Runtime 15.0
    • NI Measurement & Automation Explorer (MAX) 15.0
    • NI I/O Trace 15.0
    • NI System Configuration Runtime 15.0
    • NI Hierarchical Waveform Storage 15.0
    Caution:Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent upon, a message warns you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    Note:Do not attempt to uninstall by manually deleting files.
    NI–RFSG 14.5
    • When you delete a configuration list, NI-RFSG automatically resets the Active Configuration List property or NIRFSG_ATTR_ACTIVE_CONFIGURATION_LIST attribute to "" (empty string), which indicates no list is active, and the Active Configuration List Step property or NIRFSG_ATTR_ACTIVE_CONFIGURATION_LIST_STEP attribute to 0. Both properties or attirbutes immediately return an error if you try to set an invalid active list or active step.
    NI–RFSG 1.9
    • The NI-RFSG Soft Front Panel (SFP) replaces the MAX test panel functionality for your device. In NI-RFSG 1.8.5 and earlier, you could use the MAX test panel with LabVIEW Real-Time targets. NI-RFSG SFP 1.9.5 does not support Real-Time applications.
    • The NI-RFSG SFP 1.9.5 does not support the NI PXI-5610 with an external arbitrary waveform generator (AWG) module. In NI-RFSG 1.8.5 and earlier, the MAX test panel supported the NI PXI-5610 with an external AWG module.
    You can access the software and documentation known issues list online. Refer to the following locations at ni.com for an up-to-date list of known issues in NI-RFSG 15.0 and the NI-RFSG SFP 14.5.
    • NI-RFSG Known Issues
    • NI-RFSG Soft Front Panel Known Issues
    Bug FixesNI-RFSG Instrument Driver
    The following items are the IDs and titles of a subset of issues fixed between NI–RFSG instrument driver revisions. This table is not an exhaustive list of issues fixed in the current version of NI–RFSG.
    NI–RFSG 14.5
    489122Fixed an issue where the NI 5652 appears outside of the composite device in MAX.
    NI–RFSG 14.0.1
    492490Fixed an issue where LabVIEW Run-Time Engine 2013 SP1 does not install with NI-RFSG.
    NI–RFSG 14.0
    466905Fixed an issue where set frequency and power level execution time takes longer than expected on the NI 5644R/5645R/5646R.
    NI–RFSG 1.9.5
    392343Fixed an issue where errors occur during IVI simulation of NI 5610- or NI 5611-based devices.
    NI–RFSG 1.9
    376578Fixed an issue where verification on the NI PXI/PXIe-5650/5651/5652 devices fails at low power levels after an external calibration.
    378637Fixed an issue where nominal frequencies are returned rather than coerced values during NI PXI/PXIe-5650/5651/5652 external calibration.
    325416Fixed an issue where the Reference Clock can not be exported to REF OUT2 connector of the NI 5673E.
    The following items are the IDs and titles of a subset of issues fixed between NI–RFSG SFP revisions. This table is not an exhaustive list of issues fixed in the current version of the NI–RFSG SFP.
    NI–RFSG SFP 1.9.5
    Bug IDFixed Issue
    345106Fixed an issue where the NI-RFSG SFP took more than 40 seconds to launch after the device selection.
    346602Fixed an issue where switching from Ref In to Clk In, when there was no signal on Clk In for the NI PXIe-5673, caused the device to enter an unknown state.
    345543Fixed an issue where the splash screen disappeared before the NI-RFSG SFP finished launching.
    332005Fixed an issue where a Windows command prompt window opened while closing the SFP.
    Using NI Launcher
    For convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary.
    Finding All Programs
    If you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8.0) or click the down arrow on the bottom left of the screen (Windows 8.1).
    NI-RFSG Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-RFSG will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-RFSG that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    LabWindows™/CVI™cvi_lifecycle
    © 2004–2015 National Instruments. All rights reserved.
    374769D-01
    GMT+8, 2025-8-19 09:12
