查看: 2747|回复: 0
[NI驱动程序] NI RF Signal Generators 14.0 Win32/64Eng NI RF信号发生器NI-RFSG14.0
    昨天 09:12
  • 签到天数: 3627 天
    发表于 2021-3-1 23:43:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-RFSG
    Win32/64Eng
    14.0
    文件大小: 3103282559 字节 (2.89 GB)
    修改日期: 2014-08-28 00:36
    MD5: 74169e3a3826f8af940d620390201719(官方正确)
    SHA1: af8f41a25dd21c9635df1beb7e98e9218ef6661d
    SHA256: bfdb787b427fff95a502c96a0521b887f19d521bc4b118b04689ffb1917319a3
    CRC32: 6d26d637
    RFSA14.0.txt (557 Bytes, 下载次数: 1, 售价: 10 圆)
    NI-RFSG 14.0 Readme
    Thank you for using NI–RFSG. This file contains important information about NI-RFSG and is organized into the following sections:
    Accessing VIs and Functions
    Driver Version Naming Changes
    Uninstalling/Modifying NI–RFSG
    Behavior Changes and Upgrade Notes
    NI-RFSG Drops Support for Microsoft Windows XP and Windows Server 2003 in 2016
    NI RF Signal Generators Software
    The software installation provides support for customers using NI RF signal generator hardware, as specified in the Supported Hardware section. To program your NI RF signal generator, use the NI–RFSG instrument driver or NI-RFSG Soft Front Panel (SFP) application programming interfaces (APIs).
    The getting started guide for your device provides information about how to install, configure, test, and begin using an NI RF signal generator, as indicated in the Documentation section.
    NI–RFSG 14.0 includes the following new features:
    • Support for LabVIEW 2014 (32- and 64-bit)
    • Support removed for LabVIEW 2010
    • NI-RFSG Soft Front Panel 14.0
    NI–RFSG 1.9.7 includes the following new features:
    • Support for the NI PXIe-5646R vector signal transceiver (VST)
    • Support for downloading a custom bitfile to a VST device
    • Support for 64-bit application software with VST devices
    • NI-RFSG Soft Front Panel 1.9.7, which includes support for the other new features in NI-RFSG 1.9.7
    NI–RFSG 1.9.6 adds support for the NI-RFSG Compensate for Filter Group Delay property for the NI PXIe-5672
    NI–RFSG 1.9.5 includes the following new features:
    • Support for LabVIEW 2013 (32- and 64-bit)
    • Support removed for LabVIEW 2009
    • NI-RFSG Soft Front Panel 1.9.5, which includes the following new features:
      • Improved launch time
      • Quick save/recall of SFP configurations
      • Cursor data entry
      • Enhanced readability of saved configuration files
    NI–RFSG 1.9 includes the following new features:
    • Support for the NI PXIe-5644R/5645R vector signal transceivers
    • Includes the NI-RFSG Soft Front Panel (SFP) in the NI-RFSG installer
    • Improved the Measurement & Automation Explorer (MAX) test panel to use the NI-RFSG SFP
    • Improved representation of multiple-module devices in MAX
    NI–RFSG 1.8.5 includes the following new features:
    • Support for LabVIEW 2012 (32- and 64-bit)
    • Support for LabVIEW 2011 SP1 (32- and 64-bit)
    • Support removed for LabVIEW 8.6.1
    NI–RFSG 1.8 includes the following new features:
    • Support for streaming write timeout.
    • Improved I/Q rate reconfiguration time.
    • Support for NI-RFSG run-time custom installers built using National Instruments application development environments (ADEs). This installer contains instrument driver run-time components required to deploy applications using NI RF signal generators.
      Notes:
      • The run-time installer does not contain support for interactively configuring or testing hardware using MAX.
      • The run-time installer does not support upgrading from NI-RFSG 1.8.x or earlier, NI-FGEN 2.8.x or earlier, or NI-DAQmx 8.9.x or earlier. You must uninstall these products prior to installing the NI-RFSG Runtime installer.
    • Support for saving per-waveform properties and attributes
    • Support for NI PXI/PXIe-5650/5651/5652 external calibration
    • Support for NI PXI-5670/5671 and NI PXIe-5672 terminal names
    The following NI-RFSG devices are supported in all operating systems listed in the Supported Operating Systems section.
    Hardware ProductNI-RFSGNI-RFSG SFP
    NI PXI-5610
    NI PXIe-5611
    NI PXIe-5644R
    NI PXIe-5645R
    NI PXIe-5646R
    NI PXI/PXIe-5650
    NI PXI/PXIe-5651
    NI PXI/PXIe-5652
    NI PXIe-5653
    NI PXI-5670
    NI PXI-5671
    NI PXIe-5672
    NI PXIe-5673/5673E
    Note  MXI Express and MXI-4 are supported on Windows 8.1/8/7/Vista/XP, but MXI-3 is supported on only Windows XP.
    NI-RFSG 14.0 and NI-RFSG Soft Front Panel 14.0 support the following operating systems:
    • Windows 8.1 (32-bit and 64-bit)
    Note  NI-RFSG 14.0 and later does not support Windows Server non-R2 editions.
    It is recommended that you have the most recent service pack for your operating system installed.
    NI-RFSG 14.0 supports the following real-time operating environments:
    • LabVIEW Real-Time Module
    Note:When using NI-RFSG, the NI 5644R/5645R/5646R device does not support LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module.
    Minimum Runtime/Deployment System
    • RAM—
      • Windows 8.1/8/7/Vista: 1 GB
      • Windows XP Service Pack 3 (SP3): 512 MB (NI-RFSG), 1 GB (NI-RFSG SFP)
      Note:Depending on the amount of data generated or processed, a larger amount of RAM may be required.
    • Windows 8.1/8/7/Vista/XP SP3, with all available critical updates and service packs
    Recommended Development System
    • RAM—
      • Windows 8.1/8/7/Vista: 4 GB
      • Windows XP SP3: 2 GB
    • If you are running your application on an RT target, 128 MB of memory or more is recommended.
    • Guest accounts are not supported under any OS.
    Application Development Environments
    Note:You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSG. To add support for ADEs installed after installing NI-RFSG, modify your NI-RFSG installation or launch the NI-RFSG installer again.
    NI Application SoftwareVersions Supported by NI-RFSG
    NI LabVIEW2011, 2012, 2013, or 2014
    NI LabVIEW Real-Time Module2011, 2012, 2013, or 2014
    NI LabWindows/CVI2010 or later
    NI LabWindows/CVI Real-Time Module2010 or later
    Note:Install any toolkits or add-on software you intend to use with the NI–RFSG instrument driver after NI–RFSG installation is complete. Refer to the getting started guide for your device for more information about software and hardware installation.
    Note:MXI users must install the software included with the MXI hardware.
      • Windows 8.1/8/7/Vista: Users\Public\Documents\National Instruments
      • Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
      • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
      • Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
        • Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
        • Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
      • Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files\IVI Foundation\IVI\
        Note  $(IVIROOTDIR64) is configured as an environment variable on the target system.
    ItemInstalled Location on Windows 8.1 (32-bit)/8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP
    NI-RFSG\Drivers\niRFSG
    NI-RFSG Function Panel\Drivers\niRFSG\niRFSG.fp
    NI-RFSG Examples\NI-RFSG\Examples
    NI-RFSG Header files\Include
    NI-RFSG Import Library files (32-bit)\Lib
    NI-RFSG DLL (32-bit)\Bin
    NI-RFSG SFP\Drivers\niRFSG
    NI-RFSG SFP Example Waveforms\NI-RFSG Soft Front Panel\examples\Waveforms
    Additional File Locations for Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit)
    ItemInstalled Location on Windows 8.1 (64-bit)/8 (64-bit)/7 (64-bit)/Vista (64-bit)
    NI-RFSG Import Library files (64-bit)\Lib_x64
    NI-RFSG DLL (64-bit)\Bin
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. The documentation set is composed of the following documents:
    DocumentFormatDescription
    NI RF Signal Generators HelpHTML/Windows HelpThe primary document for NI-RFSG products. The help is an HTML version of a traditional user manual that includes:
    • An introduction to RF Fundamentals
    • Hardware device overviews
    • A complete reference for all NI-RFSG programming VIs and functions
    Calibration Procedure for your devicePDFContains calibration instructions for your device.
    Note  To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat.
    NI–RFSG VIs are available in LabVIEW from the Functions»Measurement I/O»NI–RFSG palette.
    NI–RFSG functions are available in LabWindows/CVI from the Instrument menu. To load the NI–RFSG function panel (.fp), select Instrument»Load, and navigate to \Drivers\niRFSG\niRFSG.fp or \Drivers\niRFSG\niRFSG.fp.
    LabVIEW users can use the NI Example Finder to search or browse examples. NI–RFSG examples are classified by keyword, so you can search for a particular device or measurement function. With LabVIEW running, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI–RFSG and Modulation Toolkit examples) and their descriptions:
    • Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–RFSG or by directory structure at instr»niRFSG.
    • Click the Search tab to search all installed examples by keyword. For example, search for "RFSG" to locate all NI RF signal generator examples.
    You can also access all the installed NI–RFSG examples for LabVIEW and LabWindows/CVI at Start»All Programs»National Instruments»NI–RFSG»Examples.
    Examples are also available online that demonstrate integrating NI RF signal generators with NI RF signal analyzers and NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information.
    NI-RFSG versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-RFSG 14.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-RFSG 1.9.8. The first version released under the new numbering scheme is NI-RFSG 14.0.
    • Click Change/Remove.
    • Select NI–RFSG 14.0 from the dialog box that appears.
    For Windows 8.1/8, complete the following steps:
    • Right-click the Start screen.
    • Click the Uninstall button.
    • Select NI-RFSG 14.0 from the dialog box that appears.
    As part of the NI–RFSG 14.0 installation, the following software is installed. To completely remove the NI–RFSG 14.0 installation from your system, you must also remove all of the following packages:
    • NI-RFSG Runtime 14.0
    • NI-RFSA 14.0/NI-RFSG 14.0 Runtime for NI VST
    • NI-DAQmx 9.6.1
    • NI-FGEN Runtime 14.0
    • NI-RIO 14.0
    • NI IVI Compliance Package 4.6
    • NI-VISA Runtime 14.0
    • NI Measurement & Automation Explorer (MAX) 14.0
    • NI I/O Trace 3.0.2
    • NI System Configuration Runtime 14.0
    • NI Hierarchical Waveform Storage 14.0
    Caution:Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent upon, a message warns you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    Note:Do not attempt to uninstall by manually deleting files.
    NI–RFSG 1.9
    • The NI-RFSG Soft Front Panel (SFP) replaces the MAX test panel functionality for your device. In NI-RFSG 1.8.5 and earlier, you could use the MAX test panel with LabVIEW Real-Time targets. NI-RFSG SFP 1.9.5 does not support Real-Time applications.
    • The NI-RFSG SFP 1.9.5 does not support the NI PXI-5610 with an external arbitrary waveform generator (AWG) module. In NI-RFSG 1.8.5 and earlier, the MAX test panel supported the NI PXI-5610 with an external AWG module.
    NI–RFSG 1.8
    • The rfsg_Complex Multitone II example generates correct power levels when using mirror-image.
    You can access the software and documentation known issues list online. Refer to the following locations at ni.com for an up-to-date list of known issues in NI-RFSG 14.0 and the NI-RFSG SFP 14.0.
    • NI-RFSG Known Issues
    • NI-RFSG Soft Front Panel Known Issues
    Bug FixesNI-RFSG Instrument Driver
    The following items are the IDs and titles of a subset of issues fixed between NI–RFSG instrument driver revisions. This table is not an exhaustive list of issues fixed in the current version of NI–RFSG.
    NI–RFSG 14.0
    466905Fixed an issue where set frequency and power level execution time takes longer than expected on the NI 5644R/5645R/5646R.
    NI–RFSG 1.9.5
    392343Fixed an issue where errors occur during IVI simulation of NI 5610- or NI 5611-based devices.
    NI–RFSG 1.9
    376578Fixed an issue where verification on the NI PXI/PXIe-5650/5651/5652 devices fails at low power levels after an external calibration.
    378637Fixed an issue where nominal frequencies are returned rather than coerced values during NI PXI/PXIe-5650/5651/5652 external calibration.
    325416Fixed an issue where the Reference Clock can not be exported to REF OUT2 connector of the NI 5673E.
    NI–RFSG 1.8
    313067Fixed an issue where peak envelope power erroneously returns a value of negative inifinity.
    308426Fixed an issue where the FPGA on the NI PXI/PXIe-5650/5651/5652 can fail to transition out of Configuration mode due to the slow rise time of the FPGA DONE signal.
    248280Fixed an issue where changing the value on the Modulation Waveform Type parameter or NIRFSG_ATTR_MODULATION_WAVEFORM_TYPE attribute sometimes shows no modulation.
    216961Fixed an issue where the niRFSG Self Calibration VI crashes when running the NI PXI-5671 on an RT target.
    117342Fixed an issue where generating scripts using scripting on the NI PXI-5670/5671 takes an increasingly long time.
    The following items are the IDs and titles of a subset of issues fixed between NI–RFSG SFP revisions. This table is not an exhaustive list of issues fixed in the current version of the NI–RFSG SFP.
    NI–RFSG SFP 1.9.5
    Bug IDFixed Issue
    345106Fixed an issue where the NI-RFSG SFP took more than 40 seconds to launch after the device selection.
    346602Fixed an issue where switching from Ref In to Clk In, when there was no signal on Clk In for the NI PXIe-5673, caused the device to enter an unknown state.
    345543Fixed an issue where the splash screen disappeared before the NI-RFSG SFP finished launching.
    332005Fixed an issue where a Windows command prompt window opened while closing the SFP.
    Using NI Launcher
    Finding All Programs
    NI-RFSG Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI-RFSG will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI-RFSG that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2004–2014 National Instruments. All rights reserved.
    374769A-01
    GMT+8, 2025-8-19 09:10
