NI RF Signal Analyzers 19.6.0 Win64Eng NI仪器驱动程序NI-RFSA 19.6.0
NI-RFSA
Win64
19.6
文件大小: 3990093824 字节 (3.72 GB)
修改日期: 2020-04-25 06:03
MD5: d46219403d7b8b75285e1f6fefef9cc1(官方正确)
SHA1: cb2b5ba7b9abc15b8e154d43ca6b4e71a4eb50bb
SHA256: 7ef517543f3c13fd6d8fb81093f614b9ecbb7865b5dce00deabe88f784cb3ad4
CRC32: d74f1409
RFSA19.6.0.txt
(594 Bytes, 下载次数: 0, 售价: 10 圆)
NI RF Signal Analyzers (NI-RFSA 19.6) ReadmeApril 2020 This file contains important information about NI-RFSA, including new features, supported hardware, a partial list of bugs fixed for NI-RFSA 19.6, and known issues.
Overview New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Accessing the API Finding Examples Accessing the Documentation Product Security and Critical Updates IVI Compliance Package Functionality Behavior Changes Known Issues Bug Fixes Automating the Installation of NI Products Using NI Software with Microsoft Windows 10 Using NI Software with Microsoft Windows 8.1 NI-RFSA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 in 2021 Legal Information OverviewThis software installation provides support for customers using vector signal analyzer or vector signal transceiver hardware, as specified in the Supported Hardware section. To program your device, use the NI-RFSA instrument driver or NI-RFSA Soft Front Panel (SFP).
The getting started guide for your device provides information about how to install, configure, test, and begin using your hardware. New FeaturesNI-RFSA 19.6 includes the following new features: - Support for checking module connections on the PXIe-5830/5831 with intermediate self-test in MAX or System Configuration API
- Support for reference level in configuration lists on the PXIe-5830/5831
- Support for clearing self calibrate range data on the PXIe-5820/5830/5831/5840/5841
NI-RFSA 19.2.1 includes support for configuring the pulse width of the user source signals NI-RFSA 19.2 includes support for the PXIe-5841 with PXIe-5655 NI-RFSA 19.1.6 includes improvements for the PXIe-5831 in the Semiconductor Test System NI-RFSA 19.1.5 includes support for the PXIe-5841 NI-RFSA 19.1 includes the following new features: - Support for the PXIe-5830/5831
- Support for LO sharing on the PXIe-5830/5831 to improve phase noise performance
NI-RFSA 19.0 includes support for LabVIEW 2019 NI-RFSA 18.2 includes the following new features: - Support for specifying digital gain on the PXIe-5820/5840
- Support for de-embedding measurements on the PXIe-5840
- Improvements to communication performance on the PXIe-5820/5840
- Support for specifying external calibration date for the PXIe-5644/5645/5646 and PXIe-5820/5840 in System Configuration API and MAX
NI-RFSA 18.1 includes the following new features: - Support for NI-TClk on the PXIe-5668
- Support for the PXIe-5840 with PXIe-5653 in the NI-RFSA SFP
- Added Fetch IQ (1D I16 Data Ref) for improved fetch and streaming performance
- Improvements to initiate performance on the PXIe-5820/5840
- Support for associating the PXIe-5840 with the PXIe-5653 LO source
- Support for controlling the RF OUT LO OUT terminal on the PXIe-5840
- Support for PXIe-5820/5840 self-calibration in System Configuration API
- Support for modifying temperature resolution for automatic thermal correction
- Support for modifying DMA buffer size to improve NI-RFSA fetch performance
- Support for clearing self calibrate range data on the PXIe-5644/5645/5646
NI-RFSA 18.0 includes the following new features: - Added support for LabVIEW 2018
- Added the NI-RFSA .NET Class Library and NI-RFSA .NET examples to the installer
NI-RFSA 17.1 includes the following new features: - Support for the PXIe-5820
- Support for RF list mode on the PXIe-5820/5840
- Support for System Configuration API and MAX for module temperature and self-calibration date and time
- NI-RFSA SFP debug with 64-bit support
- Support for sub-sample trigger and event resolution on the PFI line for the PXIe-5820/5840
Supported HardwareThe following table shows which hardware products are supported in the NI-RFSA instrument driver and the NI-RFSA SFP. The following hardware products are supported in all operating systems listed in the Supported Operating Systems section. Hardware Product | Hardware Model | NI-RFSA | NI-RFSA Soft Front Panel | RF Signal Downconverter | PXI-5600 | √ | — | PXIe-5601 | √ | — | PXIe-5603 | √ | — | PXIe-5605 | √ | — | PXIe-5606 | √ | — | Vector Signal Analyzer | PXI-5661 | √ | √ | PXIe-5663/5663E | √ | √ | PXIe-5665 | √ | √ | PXIe-5667 | √ | √ | PXIe-5668 | √ | √ | Vector Signal Transceiver | PXIe-5644 | √ | √ | PXIe-5645 | √ | √ | PXIe-5646 | √ | √ | PXIe-5820 | √ | — | PXIe-5830 | √ | — | PXIe-5831 | √ | — | PXIe-5840 | √ | √ | PXIe-5840 with PXIe-5653
RF Analog Signal Generator | √ | √ | PXIe-5841 | √ | √ | PXIe-5841 with PXIe-5655
RF Analog Signal Generator | √ | √ | RF Preselector Module | PXIe-5693 | √ | — | IF Conditioning Module | PXIe-5694 | √ | — | RF Amplifier | PXIe-5698 | √ | — |
MXI Express and MXI-4 are supported on Windows 10/8.1/7. Note You must install the same version of the NI-RFSA/NI-RFSG Runtime for PXIe-5644/5645/5646 and NI-RFSA/NI-RFSG Runtime for PXIe-5820/5830/5831/5840/5841 if you choose to install the runtimes independently. Note For best memory performance on the PXIe-5831, NI recommends using only 64-bit applications. System RequirementsNI-RFSA has the following requirements: - Processor—1 GHz or 64-bit (x64) processor
- 4 GB RAM*
- Windows 10/8.1/7, with all available critical updates and service packs
*Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Note Guest accounts are not supported under any OS. Supported Operating SystemsNI-RFSA 19.6 and NI-RFSA SFP 19.6 support the following operating systems: - Windows 10, 8.11, 7 SP12 (64-bit)
- Windows Server 2012 R21 (64-bit)
- Windows Server 2008 R2 SP12 (64-bit)
1NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates. 2 NI software is signed with a SHA-256 certificate. Windows 7 SP1 and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 and KB3125574 for more information about how to install these updates. Note In 2019 NI-RFSA dropped support for all 32-bit Windows operating systems. NI-RFSA will not install or run on an unsupported OS. Refer to NI-RFSA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support. Application Software SupportNI-RFSA supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSA. To add support for application software installed after installing NI-RFSA, modify your NI-RFSA installation or launch the NI-RFSA installer again. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by NI-RFSA | LabVIEW | 2016, 2017 SP1, 2018 SP1, or 2019 | LabVIEW Real-Time Module | 2016, 2017, 2018 SP1, or 2019 | LabWindows/CVI | 2010 to current | LabWindows/CVI Real-Time Module | 2010 to current |
Note When using NI-RFSA with LabVIEW Real-Time Module or LabWindows/CVI Real-Time Module, the PXIe-5644/5645/5646, PXIe-5668, and PXIe-5820/5830/5831/5840/5841 are not supported. Note Install any toolkits or add-on software you intend to use with the NI-RFSA instrument driver after NI-RFSA installation is complete. Refer to the getting started guide for your device for more information about software and hardware installation. Note MXI users must install the software included with the MXI hardware. Microsoft Visual Studio SupportIf you are using the NI-RFSA .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-RFSA .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. For more information on .NET development using NI .NET drivers, visit ni.com/info and enter Info Code NETAPIdriversupport. To install the NI-RFSA .NET Class Library, ensure that you select .NET Framework 4.5 Languages Support or .NET Framework 4.0 Languages Support in the NI-RFSA installer. Installation InstructionsNI installs NI-RFSA using NI Package Manager. If you do not already have NI software installed, NI-RFSA installs NI Package Manager to handle the installation of your NI software. Visit ni.com/info and enter the Info Code NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Accessing the APILabVIEWNI-RFSA VIs are available in LabVIEW from the Functions»Measurement I/O»NI-RFSA palette. To access the LabVIEW sample projects and templates from the New Project dialog, select Sample Projects in the left pane and navigate to the project that best matches your application requirements. LabWindows/CVINI-RFSA functions are available in LabWindows/CVI from the Instrument menu. To load the NI–RFSA function panel (.fp), select Instrument»Load, and navigate to IVI\Drivers\niRFSA\niRFSA.fp. .NET FrameworkYou can use the NI-RFSA .NET Class library by adding a reference to NationalInstruments.ModularInstruments.NIRfsa.Fx40 or NationalInstruments.ModularInstruments.NIRfsa.Fx45 and any dependent class libraries from within the Solution Explorer in Visual Studio. CYou can use the NI-RFSA C dynamically linked library by adding a reference to: Program Files (x86)\IVI Foundation\IVI\Bin\niRFSA.dll for 32-bit development or Program Files\IVI Foundation\IVI\Bin\niRFSA_64.dll for 64-bit development. NI-RFSA SFPTo launch the NI-RFSA SFP, navigate to the following location: Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Soft Front Panel Finding ExamplesSelect Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder and navigate to Hardware Input and Output»Modular Instruments»NI-RFSA. You can also select the Search tab to search all installed examples by keyword. You can access all the installed NI-RFSA examples at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Examples. Accessing the DocumentationDocumentation for NI-RFSA is located at Start»All Programs»National Instruments»NI-RFSA»NI-RFSA Documentation. The documentation set is composed of the following documents. Document | Format | Description | NI RF Vector Signal Analyzers Help | HTML/Windows Help | Contains primary help content for NI-RFSA products. The help is an HTML version of a traditional user manual that includes the following information:- An introduction to RF fundamentals
- Hardware device overviews
- The NI-RFSA Soft Front Panel Help
- A complete reference for all NI-RFSA VIs, properties, and functions, as well as the NI-RFSA .NET Class Library Help
| Getting Started Guide for your device | Printed and PDF | Contains software and hardware installation, MAX configuration, signal connection, and troubleshooting information for your device. | Specifications for your device | PDF | Lists technical specifications for your device. | Calibration Procedures for your device | PDF | Contains calibration instructions for your device. | NI RF Signal Analyzers Readme | HTML (this document) | Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices. | Introduction to NI-RFSA | HTML | Contains information about driver documentation, examples, connecting to your instrument, configuring instrument settings, and known issues. | NI-RFSA IVI Compliance Document | TXT | Contains information about IVI compliance. |
For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Note To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/reader. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments. IVI Compliance Package FunctionalityNI-RFSA no longer installs IVI Compliance Package (ICP). NI-RFSA supports IVI configuration and runtime, but no longer installs the following IVI components: - LabVIEW and CVI IVI class drivers for developing IVI interchangeable applications
- IVI Class Simulation drivers
- IVI-COM Adapters
To use these features, you must install ICP separately. ICP is included in the Software Platform Bundle media. A stand-alone web distribution is available from ni.com/downloads. Behavior ChangesThe following are behavior changes in NI-RFSA 18.2 from NI-RFSA 18.1: - Support was removed for the PXIe-5653 Test Panel in MAX.
- The NI-RFSA Express VIs are now obsolete and are no longer installed.
- The NI-RFSA RF Out LO Export Enabled property no longer requires the NI-RFSG LO Out Export Configure From RFSA property to be set to Enabled. NI-RFSA can change the export state of NI-RFSG without an open NI-RFSG session on the PXIe-5840. Ensure the NI-RFSG LO out export is generating a useful signal before using that signal for NI-RFSA operations.
Known IssuesYou can access the NI-RFSA and NI-RFSA SFP known issues lists online at the following locations. - NI-RFSA 19.6 Known Issues
- NI-RFSA Soft Front Panel 19.6 Known Issues
Bug FixesYou can access the NI-RFSA and NI-RFSA SFP bug fix lists online at the following locations. - NI-RFSA 19.6 Bug Fixes
- NI-RFSA Soft Front Panel 19.6 Bug Fixes
These lists describe a subset of issues fixed in the NI-RFSA instrument driver and NI-RFSA SFP. If you have a Bug ID, you can search these lists to validate that the issue has been fixed. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information about automating the installation of NI products, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to Customize and Automate Installation of a Single Installer.
- For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to Customize and Automate Installation of a Suited Installer.
- To determine what version of NI Installers your product contains, refer to Determine Type and Version of My National Instruments Installer.
Using NI Software with Microsoft Windows 10Microsoft Windows 10 is the latest version of the Windows operating system and features significant changes compared to previous versions. Windows 10 introduces several new capabilities and also combines features from both Windows 7 and Windows 8. For more information about NI support for Windows 10, visit ni.com/windows10. Using NI Software with Microsoft Windows 8.1When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8. NI-RFSA Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021NI-RFSA will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes: Product | Info Code | LabVIEW | lifecycle | LabWindows/CVI | cvi_lifecycle | Measurement Studio | mstudiolifecycle | TestStand | tslcp | DIAdem | ddlcp | SignalExpress | selcp | VeriStand | nivslifecycle |
Legal InformationCopyright © 2004–2020 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. 374797AA-01 |
