NI RF Signal Analyzers 2.6 Win32/64Eng NI仪器驱动程序NI-RFSA 2.6
NI-RFSA
Win32/64
2.6
文件大小: 2584948748 字节 (2.41 GB)
修改日期: 2013-10-26 00:51
MD5: d7fe2018aae206bf63345e748fb23b64(官方正确)
SHA1: e5f4a4725a662c06c6922caee6a6a5ae20685a6d
SHA256: d81b0d6cbd92a7bac83ae3e7b99ec371078f5d9078de2736364745f826ee1863
CRC32: 090e31d2
RFSA2.6.txt
(549 Bytes, 下载次数: 0, 售价: 10 圆)
NI RF Signal Analyzers Readme Version 2.6
Thank you for using NI-RFSA. This file contains important information about NI-RFSA and is organized into the following sections: - NI RF Signal Analyzers Software: The NI-RFSA and ni5660 APIs
- New Features
- Supported Hardware
- System Requirements
- Installed File Names and Locations
- Updates and Notifications
- Uninstalling/Modifying NI RF Signal Analyzers Software
- Known Issues
- Bug Fixes
- Automating the Installation of NI Products
- How to Use NI Software with Microsoft Windows 8
- Important Information
This software installation provides support for customers using either an NI PXI-5660 (NI 5660), NI PXI-5661 (NI 5661), NI PXIe-5663/5663E (NI 5663/5663E), NI PXIe-5665 (NI 5665), or NI PXIe-5667 (NI 5667) RF vector signal analyzer. To program the NI 5661, NI 5663/5663E, NI 5665, or NI 5667 use the NI-RFSA API in all programming languages. To program the NI 5660, use the ni5660 API in LabVIEW and the NI-Tuner and NI-SCOPE APIs in other programming languages. The getting started guide for your device provides information about how to install, configure, test, and begin using an NI RF vector signal analyzer. The NI 5660 has a separate help file from the NI 5661, NI 5663/5663E, NI 5665, and the NI 5667. Each device also has a separate printed specifications document. New FeaturesNI-RFSA 2.6 adds support for NI 5667 3.6 GHz and 7 GHz devices NI-RFSA 2.5.5 adds support for LabVIEW 2012 (32-bit) and LabVIEW 2012 (64-bit) NI-RFSA 2.5.2 includes the following new features: - Support for the RF Input Isolation property and the NIRFSA_ATTR_RF_INPUT_ISOLATION attribute
- Support for the FFT Width property and the NIRFSA_ATTR_FFT_WIDTH attribute
- Support for the Reference Trigger OSP Delay Enabled property and the NIRFSA_ATTR_REF_TRIGGER_OSP_DELAY_ENABLED attribute
NI-RFSA 2.5 includes the following new features: - Support for NI 5665 14 GHz devices
- Support for the RF Attenuation Step Size property and the NIRFSA_ATTR_RF_ATTENUATION_STEP_SIZE attribute
- Support for the OSP Data Scaling Factor property and the NIRFSA_ATTR_OSP_DATA_SCALING_FACTOR attribute
- Support for the Spectrum OSP Sampling Ratio property and the NIRFSA_ATTR_SPECTRUM_OSP_SAMPLING_RATIO attribute
- Support for the Phase Noise acquisition mode in the NI-RFSA Soft Front Panel (SFP)
- Support for running multiple instances of the NI-RFSA Soft Front Panel (SFP)
NI-RFSA 2.4.5 adds support for LabVIEW 2011 (32-bit) and LabVIEW 2011 (64-bit) NI-RFSA 2.4.2 includes the following new features: - Fixed an issue in which NI-RFSA was falsely reporting temperature sensor errors for the NI PXIe-5603
- Fixed an issue in which NI PXIe-5603 devices calibrated with a later version of NI-RFSA do not initialize with NI-RFSA 2.4
NI-RFSA 2.4 includes the following new features: - Support for NI 5665 3.6 GHz devices
- Support for LabVIEW 2009 (64-bit) and LabVIEW 2010 (64-bit)
- Support for Windows 7 and Windows Vista 64-bit user mode
- Simulation support for NI 5663/5663E and NI 5665 devices
- Support for the I/Q power edge Reference trigger for NI-TClk
- Support for configuration list mode DMA
Supported HardwareThe following table shows which hardware products are supported under particular operating systems. Hardware Product | Supported Under Windows 8 (32-bit)/Windows 7 (32-bit)/Vista (32-bit)/XP 1 | Supported Under Windows 8 (64-bit)/Windows 7 (64-bit)/Vista (64-bit) | NI PXI-5600 | √ | √ | NI PXIe-5601 | √ | √ | NI PXIe-5603 | √ | √ | NI PXIe-5605 | √ | √ | NI PXI-5660 | √ | X | NI PXI-5661 | √ | √ | NI PXIe-5663 | √ | √ | NI PXIe-5663E | √ | √ | NI PXIe-5665 | √ | √ | NI PXIe-5667 | √ | √ | 1 MXI Express and MXI-4 are supported on Windows 8/7/Vista/XP, but MXI-3 is supported on only Windows XP.
NI–RFSA supports all National Instruments RF signal analyzer devices, except the NI 5660 on RT targets. System RequirementsSupported Operating Systems- Windows 8 (32-bit and 64-bit)
- Windows 7 (32-bit and 64-bit)
- Windows Vista (32-bit and 64-bit)
- Windows XP Service Pack 3 (32-bit)
- Windows Server 2003 R2 (32-bit)
- Windows Server 2008 R2 (64-bit)
It is recommended that you have the most recent service pack for your operating system installed. Supported Real-Time Operating Environments- LabVIEW Real-Time Module
- LabWindows/CVI Real-Time Module
Minimum System RequirementsYou may need an update for Windows 8. - Processor—Pentium III/Celeron 600 MHz or equivalent
- RAM—
- Windows XP Service Pack 3 (SP3): 128 MB
- Windows 8/7/Vista: 512 MB
- Microsoft Internet Explorer 5.5 or later
- A screen resolution of 800 x 600 with 256 colors
- Windows 8/7/Vista/XP SP3, with all available critical updates and service packs
Recommended System- Processor—Pentium 4 or equivalent
- RAM—
- Windows XP SP3: 256 MB
- Windows 8/7/Vista: 1 GB
- If you are running your application on an RT target, 64 MB of memory or more is recommended.
Application Development Environments (ADEs)Note: You should install ADEs, such as NI LabVIEW, NI LabWindows/CVI or Microsoft Visual Studio®, before installing NI-RFSA. To add support for ADEs installed after installing NI-RFSA, modify your NI-RFSA installation or launch the NI-RFSA installer again. - LabVIEW 2009 SP1 (32-bit), 2009 SP1 (64-bit), 2010 SP1 (32-bit), 2010 SP1 (64-bit), 2011 SP1 (32-bit), 2011 SP1 (64-bit), 2012 (32-bit), or 2012 (64-bit)
- LabVIEW Real-Time Module 2009 SP1, 2010 SP1, 2011 SP1 (not supported with NI 5660), or 2012
- LabWindows™/CVI™ 9.0.1 or later
- LabWindows/CVI Real-Time Module 2009 or later (not supported with NI 5660)
- If you are running your application on an RT target, 128 MB of memory or more is required.
Note: | The NI Spectral Measurements Toolkit must be installed for proper operation of NI RF vector signal analyzers. Install the Spectral Measurements Toolkit after installing NI-RFSA. Refer to the NI RF Vector Signal Analyzer Getting Started Guide for more information about software and hardware installation. |
Note: | MXI users must install the software included with the MXI hardware. | Installed File Names and Locations- is an alias for the following National Instruments file folder location:
- Windows XP: Documents and Settings\All Users\Shared Documents\National Instruments
- Windows 8/7/Vista: Users\Public\Documents\National Instruments
- Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI Foundation\IVI\
- Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI Foundation\IVI\
Note | $(IVIROOTDIR32) is configured as an environment variable on the target system. | | If you upgraded an installation of IVI, your files may be located in the following location:
- Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP: Program Files\IVI\
- Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit): Program Files (x86)\IVI\
- is an alias for the following VISA file folder location:
- Windows 8 (32-bit)/7/Vista (32-bit)/XP: Program Files\IVI\VISA
- Windows 8 (64-bit)/7/Vista (64-bit): Program Files (x86)\IVI\VISA
Note: If you upgraded an installation of VISA, your folder may be located at C:\VXIPNP. File LocationsFiles | Installed Location on Windows 8 (32-bit)/7 (32-bit)/Vista (32-bit)/XP | NI-RFSA | NI-RFSA | \Drivers\niRFSA | NI-RFSA Function Panel | \Drivers\niRFSA\nirfsa.fp | NI-RFSA Examples | \NI-RFSA\examples | NI-RFSA Header file | \Include | NI-RFSA Import Library files | \lib | NI-RFSA DLL (32-bit) | \Bin | ni5660 | NI-TUNER Function Panel | \WinNT\niTuner\niTuner.fp | ni5660 Header file | \WinNT\include | ni5660 Import Library files | \WinNT\lib | ni5660 DLL (32-bit) | \WinNT\Bin |
Additional File Locations for Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit)Item | Installed Location on Windows 8 (64-bit)/7 (64-bit)/Vista (64-bit) | NI-RFSA Function Panel | \Drivers\niRFSA\nirfsa.fp | NI-RFSA Header files | \Include | NI-RFSA Import Library files (64-bit) | \Lib_x64 | NI-RFSA DLL (64-bit) | \Bin |
VIs and FunctionsNI-RFSA palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»NI-RFSA palette. ni5660 palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»ni5660 palette. NI-RFSA functions are available in LabWindows/CVI from the Instruments menu. To load the NI-RFSA function panel (FP), select Instruments»Load, and navigate to \Drivers\niRFSA\niRFSA.fp or \Drivers\niRFSA\niRFSA.fp. The ni5660 API does not provide LabWindows/CVI support, but you can use the NI-SCOPE and NI-Tuner functions to create your application in this ADE. ExamplesWith LabVIEW running, select Help»Find Examples to launch the NI Example Finder. The NI Example Finder offers two ways to access all installed LabVIEW example VIs (including NI-RFSA, Spectral Measurements Toolkit (SMT) examples, and Modulation Toolkit (MT) examples) and their descriptions. - Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI-RFSA or by directory structure at instr»niRFSA or instr»ni5660.
- Click the Search tab to search all installed examples by keyword. For example, searching for "RFSA" can be used to locate all RF vector signal analyzer examples.
Note Modulation Toolkit examples that work with the NI-RFSA API are available by using the search feature of the NI Example Finder or at ni.com/examples. DocumentationThe following documents are installed with NI-RFSA and are available from Start»All Programs»National Instruments»NI-RFSA»Documentation: - NI RF Signal Analyzers Readme (this document)
- Getting started guide for your device—Printed and PDF format. Contains hardware and software installation, MAX configuration, and troubleshooting information.
- NI RF Vector Signal Analyzers Help—HTML help format. Intended for NI 5661, NI 5663/5663E, NI 5665, and NI 5667 users. Includes RF fundamentals, hardware device overviews, programming information, LabVIEW reference, and CVI function reference sections.
- NI PXI-5660 Help—HTML help format. Intended for NI 5660 users. Includes hardware device overview, programming information, and LabVIEW reference sections.
- Specifications for your device—Printed and PDF format. Lists specifications for your device.
- Calibration procedures for your device— Contains calibration instructions for NI vector signal analyzers. The latest procedures are available at ni.com/calibration
- Maintain Forced-Air Cooling Note to Users—Printed format. Contains important cooling information for NI vector signal analyzers.
- Read Me First: Safety and Electromagnetic Compatibiity—Printed format. Contains safety instructions and electromagnetic compatibility (EMC) information for the hardware it accompanies.
Note To view the specifications, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/acrobat. Updates and NotificationsNational Instruments releases critical software updates after product release using the NI Update Service. Visit ni.com/info and enter updates to view a list of all currently available updates. National Instruments provides notification of certain critical issues at install time. Visit ni.com/info and enter notifications to view a list of current product notifications. Uninstalling/Modifying the NI RF Signal Analyzers SoftwareNOTE: When you install the NI-RFSA 2.6 software, you can select NI-RFSA 2.6 and/or NI PXI-5660 Support. If you install both APIs and later want to uninstall or modify the installation, you will need to perform the following steps for each API. For Windows XP, complete the following steps: - Launch the Control Panel by selecting Start»Control Panel.
- Double-click Add or Remove Programs.
- Select National Instruments Software.
- Click Change/Remove.
- Select NI-RFSA 2.6 or NI PXI-5660 Support from the dialog box that appears.
- Click Remove to uninstall the product; click Modify to change the components that are installed.
For Windows 7/Vista, complete the following steps: - Launch the Control Panel by selecting Start»Control Panel.
- Double-click Programs and Features.
- Click the Uninstall/Change button.
For Windows 8, complete the following steps: - Right-click on the Start screen.
- Select All apps, and launch the Control Panel.
- Select Programs» Programs and Features.
- Click the Uninstall button.
As part of the NI-RFSA installation, the following software is installed. To completely remove the NI-RFSA installation from your system, you must also remove all of the following packages: - NI RFSA Run-Time 2.6
- NI-DAQmx 9.5
- NI-SCOPE 3.9.4
- NI IVI Compliance Package 4.4
- NI-VISA 5.0
- NI Measurement & Automation Explorer (MAX) 5.1
- NI-RFSG 1.8.5
- NI-FGEN 2.9.1
- NI I/O Trace 2.7.2
Caution: | Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent upon, a message warns you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly. |
Note: | Do not attempt to uninstall by manually deleting files. | Known IssuesYou can access the software and documentation known issues list online. Refer to the NI-RFSA known issues at ni.com for an up-to-date list of known issues in NI-RFSA 2.6. Bug FixesThe following items are changes from NI-RFSA 2.5.2 to NI-RFSA 2.6. ID | Fixed Issue | 378277 | Fixed an issue in which NI-RFSA does not correct for magnitude only equalization when performing in-band retuning in spectrum acquisition mode. | 358210 | Fixed an issue in which NI-RFSA has a type mismatch in Fetch calls between LabVIEW and CVI. | 312899 | Fixed an issue in which handle leaks can occur when using the Spectral Measurements Toolkit 2.6.1 or the Modulation Toolkit 4.3.1 and earlier with the NI PXI-5660 API. | 343973 | Fixed an issue in which specifying a non-zero external gain with input isolation enabled causes the driver to return incorrect amplitude parameters. |
The following items are changes from NI-RFSA 2.5 to NI-RFSA 2.5.2. ID | Fixed Issue | 313126 | Fixed an issue in which NI-RFSA Express VIs in LabVIEW 2010 (64-bit) does not code generate if a later version of LabVIEW (64-bit) is installed at the same time. | 311302 | Fixed an issue in which NI-RFSA cannot reconfigure an acquisition session from I/Q mode to spectrum mode for the NI PXIe-5663E using NI-RFSA 2.4 or later. | 324569 | Fixed an issue in which testing the device resources in MAX causes the chassis controller to crash and restart for the NI PXI-5600. | 330425 | Fixed an issue in which EVM and MER measurements are degraded when using RF list mode for NI-RFSA versions 2.3 and later. |
The following items are changes from NI-RFSA 2.4.2 to NI-RFSA 2.5. ID | Fixed Issue | 304436 | Fixed an issue in which calling the NI-RFSA Commit VI before setting the attenuation-related properties results in incorrect gain scaling coefficients on the NI PXIe-5663 and NI PXIe-5665. | 301761 | Fixed an issue in which calling the NI-RFSA Reset Device VI on the NI PXIe-5622 can cause a blue screen in some instances. | 297868 | Fixed an issue in which users may get an undefined warning with code 88000 while using the NI PXI-5600 and changing clocking configurations. | 296450 | Fixed an issue in which the NI PXIe-5622 digitizer may incorrectly report a warning that the PLL came unlocked or may experience initial accuracy issues. | 288143 | Fixed an issue in which the NI PXIe-5622 (25 MHz) digitizer in a real-time setup does not appear under the chassis in MAX. | 287752 | Fixed an issue in which execution times with multiple NI-RFSA sessions is slower than expected. | 285185 | Fixed an issue in which NI-RFSA, with NI-SCOPE, writes incorrect calibration values to the NI PXIe-5622 during external calibration. | 279084 | Fixed an issue in which calling the NI-DAQmx Reset VI after calling the NI-RFSA Commit VI may cause the NI PXI-5600 firmware to return an error. | 275798 | Fixed an issue in which the NI PXI-5600 may hang at cold temperatures at driver initialization or reset. |
The following items are changes from NI-RFSA 2.4 to NI-RFSA 2.4.2 ID | Fixed Issue | 305024 | Fixed an issue where NI-RFSA was falsely reporting temperature sensor errors for the NI PXIe-5603. | 305281 | Fixed an issue where NI PXIe-5603 devices calibrated with a later version of NI-RFSA do not initialize with NI-RFSA 2.4. |
The following items are changes from NI-RFSA 2.3.1 to NI-RFSA 2.4 ID | Fixed Issue | 245523 | LabVIEW 8.6 is now supported with NI-RFSA 2.4. | 208667 | Fixed an issue in which a MIMO configuration of multiple NI 5663 devices returned an incorrect gain scaling coefficient. | 216904 | Fixed an issue in which the I/Q rate was coerced incorrectly when fractional resampling was enabled on the NI 5663. | 191603 | Fixed an issue in which setting the I/Q power edge Reference trigger was unreliable for a 50 MHz span. | 199048 | Fixed an issue in which reopening a calibration session from the same process returns an incorrect error. | 141500 | Fixed an issue in which setting a non-zero value for minimum quiet time with no trigger configured returns an error. | 181248 | Fixed an issue in which the t0 during a fetch changed significantly with different sample rates. | 194848 | Fixed an issue in which an internal error was reported when getting the frequency response on a bypass path on the NI PXIe-5601. | 231741 | Fixed an issue in which the LabVIEW Meta Deployment Framework does not deploy NI-RFSA on 64-bit Windows versions when created on 32-bit Windows version. |
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information, refer to the following KnowledgeBase articles: - For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information about silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
How to Use NI Software with Microsoft Windows 8When you install National Instruments software on Microsoft Windows 8, you will notice a few additional tiles on the Start page, including shortcuts to NI application software products such as NI LabVIEW, and Measurement & Automation Explorer (MAX). Note Unlike previous versions of Microsoft Windows, MAX does not appear as a desktop shortcut. You can launch MAX from the Start page. | Pinning Frequently Used ApplicationsFor convenience, you can pin your most-used NI applications, such as MAX, to either the Start page or the Taskbar on the desktop, as necessary. Current Application | Icon Location | Pin to Action | Windows 8 Desktop | Desktop Taskbar | Right-click application and select Pin to Taskbar | Windows 8 Desktop | Start page | Right-click application and select Pin to Start | Windows 8 Start page | Desktop Taskbar | Right-click application and select Pin to taskbar from the menu bar on the bottom of the screen | Finding All ProgramsIf you want to find a particular application or related files, such as documentation files, from the Start page, you can access all installed files by right-clicking anywhere on the Start page and selecting All apps. A list of all installed software and related files appears, in alphabetical order by creator or type. Important InformationCopyright © 2004—2012 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations: - Notices are located in the \_Legal Information and directories.
- EULAs are located in the \Shared\MDF\EULAs directory.
- Review \_Legal Information.txt for information about including legal information in installers built with NI products.
Trademarks CVI, LabVIEW, National Instruments, NI, ni.com, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks. The mark LabWindows is used under a license from Microsoft Corporation. Windows is a registered trademark of Microsoft Corporation in the United States and other countries. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. |
