查看: 2666|回复: 0
[RTE运行引擎] NI RFmx 20.0 Runtime Win64Eng NI Wireless Test Standard Software运行版ni-rfmx-runtime-suite_20.0.0
    12 小时前
  • 签到天数: 3566 天
    连续签到: 11 天
    发表于 2021-2-26 22:55:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx
    WinEng
    20.0RTEX64
    文件大小: 781162496 字节 (744.97 MB)
    修改日期: 2020-06-09 15:31
    MD5: 995d12e469521f76a61babe4868926f4(官方正确)
    SHA1: f292e34bbcdc60111eded83bb99f06891c0074c5
    SHA256: 59ddd14b171154b6b926d1d0631dd3a620e0610bda01069bb92b44d37c030c5f
    CRC32: 123573b7
    RFmx20.0RTE64.txt (662 Bytes, 下载次数: 0, 售价: 5 元)
    RFmx Runtime (64-Bit) 20.0 Readme
    June 2020
    This file contains important information about the RFmx Runtime (64-Bit), including system requirements, and installation instructions.
    RFmx Runtime (64-Bit) Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021
    The following products are included in the RFmx Runtime (64-Bit) media. Refer to the readme of each product for information including installation, activation, new features, known issues, and bug fixes.
    Application Software
    • RFmx SpecAn Runtime (64-Bit)
    • RFmx Demod Runtime (64-Bit)
    • RFmx Noise Figure Runtime
    • RFmx Phase Noise Runtime
    • RFmx WLAN Runtime (64-Bit)
    • RFmx Bluetooth Runtime (64-Bit)
    • RFmx NR Runtime (64-Bit)
    • RFmx LTE Runtime (64-Bit)
    • RFmx WCDMA Runtime (64-Bit)
    • RFmx TD-SCDMA Runtime (64-Bit)
    • RFmx EV-DO Runtime (64-Bit)
    • RFmx CDMA2k Runtime (64-Bit)
    • RFmx GSM Runtime (64-Bit)
    Drivers
    • NI-RFSG Playback Library Runtime
    RFmx Runtime (64-Bit) has the following requirements:
    RFmx Runtime (64-Bit) 20.0 supports the following 64-bit operating systems:
    • Windows 10/8.1 1 /7 SP1 2
    • Windows Server 2012 R2 1
    Note   In 2019, RFmx Runtime (64-Bit) dropped support for all 32-bit Windows operating systems. RFmx Runtime (64-Bit) will not install or run on an unsupported OS. Refer to RFmx Runtime (64-Bit) Drops Support for Windows 7 (64-Bit) and Windows Server 2008 R2 in 2021 for information about future OS support.
    RFmx Test Software is available for download from NI Software Product Downloads.
    RFmx Runtime (64-Bit) will drop support for Windows 7 (64-bit) and Windows Server 2008 R2 starting in 2021. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2019–2020 National Instruments. All rights reserved.
    377999C-01
    GMT+8, 2025-6-13 20:48
