查看: 3205|回复: 0
[LV工具模块] LabVIEW NXG 5.1.0 Real-Time Module Win64多国语言 LV NXG 5.1.0实时模块RealTtime 8.4.0
    昨天 16:26
  • 签到天数: 3674 天
    发表于 2021-1-31 23:36:44 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    自LabVIEW NXG5.0版开始,提供NXG环境下的Real-time实时模块,64位,Windows环境。中文, 德语, 日语, 法语, 英文, 韩语多国语言版。
    使用LabVIEW Real-Time模块的三大理由:
    1. 将LabVIEW图形化编程扩展至独立的嵌入式系统
    2. 利用实时操作系统实现精确的定时和高可靠性
    3. 利用各类IP和实时硬件驱动
    百度网盘下载地址(限速,请开会员或使用破解限速工具)和NI官方下载地址(可能无效或无法下载完成):
    请注册登录视觉论坛会员,购买附件查看
    NXG RT5.1.0.txt (728 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW NXG 5.1 Real-Time Module Readme
    January 2021
    This file contains important information about the LabVIEW NXG Real-Time Module, including system requirements, new features, known issues, and bugs fixed for this release.
    LabVIEW NXG Real-Time Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    The LabVIEW NXG Real-Time Module has the following requirements:
    • LabVIEW NXG 5.1
    • At least 35 GB of free disk space
    • 8 GB RAM
    Refer to the LabVIEW NXG Readme for additional system requirements and supported operating systems for LabVIEW NXG.
    The LabVIEW NXG 5.1 Real-Time Module supports the following operating systems:
    • Windows 10 (version 2004)/8.1 Update 11/7 SP12 (64-bit)
    • Windows Server 2012 R2 Update1
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 and KB3125574for more information about how to install this security update.
    Note  Refer to LabVIEW NXG Real-Time Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    New Features and Behavior Changes
    This release of LabVIEW NXG Real-Time Module adds new functionality to the previous release. Refer to LabVIEW NXG 5.1 Real-Time Module New Features and Changes for a list of new features and behavior changes.
    Refer to LabVIEW NXG 5.1 Real-Time Module Supported Hardware and Drivers for a list of supported hardware.
    You can access the software and documentation known issues list online. Visit LabVIEW NXG 5.1 Real-Time Module Known Issues for an up-to-date list of known issues.
    Documentation Known Issues
    Online Node Reference Topics Don't Reflect Real-Time Compatibility—The Compatibility tab for nodes that run on a real-time Linux operating system do not reflect that compatibility. However, when you target a VI to a real-time controller in SystemDesigner, you only have access to nodes that can run on the real-time controller.
    You can access the software bug fixes list online. Visit LabVIEW NXG 5.1 Real-Time Module Bug Fixes for an up-to-date list of bug fixes.
    Search for items using the search bar in the upper right corner of the LabVIEW window.
    View context help in LabVIEW NXG by pressing and hovering over an object. Refer to the LabVIEW NXG Manual, accessible from Help»Online Manual, for more information about LabVIEW NXG.
    To learn the theory behind the code, use interactive lessons in the Learning tab that contain example code within the environment.
    LabVIEW NXG Real-Time Module will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    NI Software will drop support for Phar Lap ETS Real-Time Operating System starting in 2022. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, please visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, please visit ni.com/r/b7g5wi.
    © 2020-2021 National Instruments Corporation. All rights reserved.
    Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Xilinx® is a registered trademark of Xilinx, Inc. Other product and company names mentioned herein are trademarks or trade names of their respective companies.
    For patents covering the NI products/technology, refer to the appropriate location: the patents.txt file on your media or the National Instruments Patent Notice at ni.com/patents.
    378284B-01
    GMT+8, 2025-10-8 00:16
