查看: 2859|回复: 0
[LV工具模块] LabVIEW 2020 f1 FPGA Module Win32Eng LabVIEW2020f1FPGA模块LVFPGA2020f1 32位英文版
    昨天 15:45
  • 签到天数: 3536 天
    连续签到: 6 天
    发表于 2021-1-30 23:18:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    百度网盘下载地址(限速,请开会员或使用破解限速工具)和NI官方下载地址(可能无效或无法下载完成):
    请注册登录视觉论坛会员,购买附件查看 FPGA20.0.1Win32Eng.txt (680 Bytes, 下载次数: 2, 售价: 10 元)
    LabVIEW 2020 FPGA Module Readme
    March 2020
    This file contains important information about the LabVIEW FPGA Module, including system requirements, installation instructions, upgrade and compatibility issues, known issues, and a partial list of bugs fixed for this release.
    FPGA Module System Requirements
    FPGA Module (64-Bit)
    FPGA Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    With the LabVIEW FPGA Module, you can create VIs that run on NI FPGA targets, such as reconfigurable I/O (RIO) devices. The FPGA Module helps you design complex systems by providing a highly-integrated development environment, a large ecosystem of IP libraries, a high-fidelity simulator, and debugging features. The FPGA Module also includes the FPGA Compile Farm Server. You can use the FPGA Compile Farm Server to offload compiles to dedicated computers.
    • LabVIEW 2020 Full or Professional Development Systems
    • 3 GB of additional disk space
    • Memory1:
      • At least 4 GB of RAM2 for Virtex-6 and later FPGA targets
      • Windows 10 (version 1909)/8.1 Update 13
      • Windows 7 SP14
      • Windows Server 2008 R2 SP14
      Note
      • In 2016 the FPGA Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2020 FPGA Module will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2020 FPGA Module to an unsupported OS. Additionally, after installing the LabVIEW 2020 FPGA Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, visit ni.com/r/OSSupport2016.
      • Refer to FPGA Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
      • On Windows 8.1, Windows Server 2016, and Windows Server 2008 R2 SP1, only the FPGA Interface functions are supported. FPGA development functionality is not fully supported as some of the features require the use of Xilinx compilation tools. These tools do not support Windows 8.1, Windows Server 2016, or Windows Server 2008 R2 SP1.
      • On 32-bit OSes, the FPGA Module does not support the following features on Xilinx Vivado targets:
        • Third-party simulation
        • Configure Component-Level IP wizard
        • Configuring or regenerating IP using the IP Integration Node or Xilinx IP functions
        • Simulating FPGA VIs that use the IP Integration Node or Xilinx IP functions
    • NI FPGA device
    • Device driver software—To program most devices with the LabVIEW FPGA Module, install the device driver software. Refer to the hardware documentation for requirements for a specific device.
    2 You must use a 64-bit OS to address 4 GB of RAM.
    3 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    4 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    You can use either a Windows or Linux computer as a compile worker. Refer to the Xilinx Compilation Tools Readme for information about the minimum system requirements.
    • 35 MB of disk space
    • 1 GB RAM
      • Windows 10 (version 1909)/8.1 Update 11
      • Windows 7 SP12
      Note  In 2016 the FPGA Compile Farm Server dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2020 FPGA Compile Farm Server will not install or run on an unsupported OS. Refer to FPGA Module Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021 for information about future OS support.
    • Web browser that supports Microsoft Silverlight for accessing compile job queues via the NI Web-based Configuration & Monitoring Service FPGA Compile Farm Console
    Note  If you are upgrading from a previous version of LabVIEW, you must install the LabVIEW 2020 FPGA Module before mass-compiling existing FPGA VIs. Otherwise, some FPGA-specific VIs might have mutation issues.
    NI installs the FPGA Module using NI Package Manager. If you do not already have NI software installed, the FPGA Module installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    To install LabVIEW and the FPGA Module using the LabVIEW Platform media, complete the following steps:
      • LabVIEW
      • FPGA Module
      • Xilinx Compilation Tools—Install these compilation tools on the development computer if you want to compile your LabVIEW FPGA VIs locally. You must install these tools on your development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, or use third-party simulation. Refer to your hardware documentation for information about the FPGA chip in your device and install the appropriate set of tools. Visit ni.com/info and enter the Info Code XilinxCompileTools for more information about the NI hardware supported by each Xilinx compilation tool.
        • Xilinx Compilation Tools for Windows—Install these compilation tools if you will compile your FPGA VIs on a Windows computer. The Xilinx compilation tools for Windows include Vivado 2019.1 and ISE 14.7.
        • Xilinx 10.1 Compilation Tools—Install the Xilinx 10.1 compilation tools if your FPGA device contains a Xilinx Virtex II chip. To download the Xilinx 10.1 compilation tools, refer to ni.com/info and enter the Info Code FPGATool101.
    • Linux—Refer to the FPGA Module Xilinx Compilation Tools for Linux Readme for information about setting up a remote compile worker.
    The FPGA Module (64-bit) provides access to more memory than the FPGA Module (32-bit) can provide. The FPGA Module (64-bit) is available in English only.
    The FPGA Module (64-bit) supports the following NI hardware devices:
    • PCIe-576x/577x/5785/798x
    • PXIe-5163R/5164R/517xR/5745/576x/577x/5785/659xR/7902R/791x/797xR/798x
    • USRP-RIO devices
    You cannot use an unsupported device with the FPGA Module (64-bit) or run example VIs that require an unsupported device in the FPGA Module (64-bit). Refer to the specific hardware documentation for more information about compatibility with the FPGA Module (64-bit).
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the FPGA Module.
    The following items are the IDs and titles of a subset of issues fixed in the FPGA Module. This is not an exhaustive list of issues fixed in the current version of the FPGA Module. If you have a Bug ID, you can search this list to validate that the issue has been fixed.
    ID
    Fixed Issue
    123762Opening more than 127 concurrent FPGA interface sessions causes a crash
    124013An FPGA session reference bound to a typedef and pointing to a bitfile can cause LabVIEW to crash if the typedef is modified
    184098The Desktop Execution Trace Toolkit reports reference leaks when executing a VI that opens and closes FPGA VI references in simulation mode
    223923LabVIEW FPGA encrypts an external IP source file even if the file is already encrypted
    229293When you use the C API, some debugging tools may report a dynamic memory leak
    896190Unintended increase in BlockRAM resource usage for the FFT Express VI when the VI runs in the "Single Channel, Multiple Samples" input mode
    If you upgrade from the LabVIEW 2019 FPGA Module or later to the LabVIEW 2020 FPGA Module, you might encounter the following compatibility issues:
    • Deprecating FPGA IP Builder—FPGA IP Builder is deprecated in the LabVIEW 2020 FPGA Module.
    • Vivado Version Upgrade—The Vivado compilation tool version is upgraded from 2017.2 to 2019.1 with the following changes and compatibility issues:
      • The Xilinx IP palette adds the following functions:
        • Audio Formatter
        • I2S Receiver
        • I2S Transmitter
        • LDPC Encoder/Decoder
        • Polar Encoder/Decoder
        • Soft-Decision FEC—This IP is available on only Zynq UltrascalePlus RFSoc targets.
        • SPDIF/AES3
        • UHD-SDI Audio—This IP is not available on Artix 7 targets.
      • The following functions are no longer available on the Xilinx IP palette:
        • Video Frame Buffer Write
        • Video Frame Buffer Read
        • Video Mixer
      • If you open a VI saved in a previous version of LabVIEW that contains an IP Integration Node or Xilinx IP node, complete the following steps to regenerate or reconfigure files.
        IP Integration Node
        Xilinx IP Node
        • Regenerate support files for the IP by selecting Tools»FPGA Module»Regenerate IP Integration Node Support Files from LabVIEW and following the on-screen instructions.
          Note  If LabVIEW fails to update all support files, re-add the IP Integration Node to the VI and generate the support files for the IP Integration Node.
        • If the IP Integration Node contains Xilinx Vivado IP configuration (.xci) files, continue with the following steps:
          • Regenerate the Xilinx Vivado IP configuration (.xci) files in the latest Xilinx compilation tools for Vivado.
          • Re-add the configuration files to the IP Integration Node.
          • Re-add the IP Integration Node to the VI.
          • Generate the support files for the IP Integration Node.
        • Regenerate support files for the Xilinx IP node by selecting Tools»FPGA Module»Regenerate IP Integration Node Support Files from LabVIEW and following the on-screen instructions.
        • Verify the behavior of the Xilinx IP node.
        • Reconfigure the Xilinx IP node if its behavior has changed.
    If you upgrade from the LabVIEW 2018 FPGA Module or earlier to the LabVIEW 2020 FPGA Module, refer to previous versions of the LabVIEW FPGA Module readme or LabVIEW FPGA Module Release and Upgrade Notes, available on ni.com/manuals, for additional changes in previous versions of the FPGA Module.
    Note  The LabVIEW FPGA Module Release and Upgrade Notes document was deprecated from the 2016 release.
    Upgrading the FPGA Module requires you to upgrade to a new version of the Xilinx compilation tools. This upgrade can change the timing or resource utilization characteristics of FPGA VIs you developed in previous versions or cause these VIs to fail to compile. NI recommends that you test all FPGA designs after upgrading.
    The FPGA Module will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    © 2003–2020 National Instruments. All rights reserved.
    Third-Party Copyright Notices
    \National Instruments\LabVIEW \FPGA\Legal\
    374737L-01
    GMT+8, 2025-5-12 03:00
