NI PXI MultiComputing 14.0 Driver Win32Eng NI-PXImc远程控制模块驱动程序14.0
NI-PXImc
NI-PXImc为使用NI PXI MultiComputing远程控制模块的客户提供支持。
NI-PXImc是一个NI仪器驱动程序,可让两个或更多智能系统利用非透明(NT)桥接技术,通过PCI Express进行数据交换。NI-PXImc驱动程序抽象了PXI MultiComputing (PXImc)接口的底层细节,并提供了一种简单有效的API来进行数据传输。
Win32Eng
14.0
文件大小: 387752736 字节 (369.79 MB)
修改日期: 2015-01-03 02:05
MD5: f806959866be4b87042d6a679c72e1ff(官方正确)
SHA1: 7950c2e3dea2f98d805ad08a1f6555d017f08720
SHA256: 514122af68b533b644fc42d2a9ff67d210ca7208157abf70e11d8cf39feea607
CRC32: 1de0a47d
PXImc16.0.txt
(548 Bytes, 下载次数: 0, 售价: 10 圆)
NI-PXImc™ ReadmeVersion 14.0 August 2014 This file contains information about the NI-PXImc software for Microsoft Windows and LabVIEW Real-Time (RT). Information in this file is organized in the following sections: Overview System Requirements Installation Instructions Product Security and Critical Updates NI-PXImc General Considerations Driver Version Naming Changes Accessing the Help Finding Examples Automating the Installation of NI Products How to Use NI Software with Microsoft Windows 8.x Legal Information OverviewThe NI-PXImc software enables you to create customized applications for your PXImc hardware (NI PXIe-8383mc and NI PXIe-8830mc) either in LabVIEW or C/C++. System RequirementsSupported Operating SystemsYou can install and run this version of the NI-PXImc software on the following operating systems: - Microsoft Windows 8.1 (32- and 64-bit)
- Microsoft Windows 7 (32- and 64-bit).
Note: National Instruments recommends Windows 8.1/7 (64-bit) for best performance. - NI LabVIEW Real-Time (ETS)
Note: The only operating system supported on the NI PXIe-8830mc Processor Module is NI LabVIEW Real-Time 2013 SP1 or NI LabVIEW Real-Time 2014.
Note: National Instruments recommends 3 GB or more RAM for Windows 8.1/7 (32-bit) and LabVIEW Real-Time (ETS), and a minimum 8 GB RAM for Windows 8.1/7 (64-bit). Refer to System RAM for more information. NI Application Software SupportThe following table lists the NI application software versions, including service packs, supported by NI-PXImc. If you are not using NI application software, refer to Microsoft Visual Studio Support. | NI Application Software | Versions Supported by NI-PXImc | | NI LabVIEW | 2012 SP1 (32- or 64-bit), 2013 SP1 (32- or 64-bit), 2014 (32- or 64-bit) | | NI LabVIEW Real-Time Module | NI PXIe-8383mc module: 2012 SP1, 2013 SP1, 2014
Note: The Real-Time Module is compatible with 32-bit LabVIEW only. Therefore, you must have 32-bit LabVIEW installed even if you use a 64-bit OS. | NI PXIe-8830mc module: 2013 SP1, 2014
| | NI LabWindows™/CVI™ | 2012 and later | Supported HardwareThe NI-PXImc software currently supports the following hardware products: - NI PXIe-8383mc PXImc Adapter Module
- NI PXIe-8830mc PXImc Processor Module
The NI PXIe-8383mc PXImc adapter modules and the NI PXIe-8830mc PXImc processor modules utilize a x8 PCI Express 2.0 interface for transferring data. National Instruments recommends using the NI PXImc modules with a PXI-Express chassis and controller combination that provide high PCI Express bandwidth. If you are using the NI PXIe-8383mc or NI PXIe-8830mc module in a chassis with an NI embedded controller, then you must update the BIOS software on that embedded controller to the latest released BIOS software prior to connecting the hardware. For more information, refer to KnowledgeBase 2GIGKD0Z, Determining and Upgrading PXI and VXI Embedded Controller BIOS Versions. Bandwidth experienced when using NI-PXImc may be affected by bandwidth capabilities of the controller or the chassis. If you experience lower than expected bandwidth when using NI-PXImc, check that your controller and chassis are capable of supporting the desired bandwidth, and that your PXImc adapter module is inserted into an appropriate chassis slot to obtain the best performance. Consult your chassis and controller documentation for specific information relevant to your hardware configuration. Note: National Instruments recommends an NI high performance PXIe embedded controller be used both as the system controller and as the controller connected to the front panel of the PXImc module. Refer to NI-PXImc General Considerations for more information. Installation InstructionsThe following sections include important information about installing the NI-PXImc software. You can run the NI-PXImc installer on the following operating systems: - Windows 8.1/7 (32-bit and 64-bit)
Before installing the NI-PXImc software, log on as Administrator or as a user with Administrator privileges. The NI-PXImc software setup program must have Administrator privileges because the program modifies the configuration registry of your system. Tip For optimal performance, update your operating system to the latest service pack and apply all security patches. Downloading燦I-PXImc from the WebComplete the following steps to install the NI-PXImc software from a web download: - Download the NIPXImc140.exe file, and then run it.
- Follow the onscreen instructions.
Note Users may see access and security messages during installation. Accept the prompts to complete the installation. - When the installation is complete, a dialog box appears that asks if you want to restart, shut down, or restart later. Select Restart.
Installing from the CDComplete the following steps to install the NI-PXImc software from the installation media: - Insert the NI-PXImc software media. If you have autorun enabled,autorun.exe runs automatically. Otherwise, navigate to the CD using Windows Explorer and launch the autorun.exe file from your NI-PXImc software media.
Installing the Software on a Real-Time TargetComplete the following steps to install the NI-PXImc software on a real-time target in Measurement & Automation Explorer (MAX): - Expand Remote Systems in the configuration tree and expand your real-time target.
- Select the Software category. Click the Add/Remove Software icon on the toolbar to launch the LabVIEW Real-Time Software Wizard.
- Select NI-PXImc in the feature list and click Next.
- Follow the remaining installation instructions until installation is complete.
NI-PXImc General ConsiderationsUpgrading from NI-PXImc 1.0NI-PXImc 14.0 is not compatible with NI-PXImc 1.0. You must upgrade all systems, including the host machine and any PXImc hardware modules, to version 14.0 of the software. NI Embedded Controller BIOS VersionsFor proper operation with NI-PXImc, all NI Embedded Controllers must be running the latest BIOS. For more information, refer to KnowledgeBase 2GIGKD0Z, Determining and Upgrading PXI and VXI Embedded Controller BIOS Versions. Recommended NI Embedded ControllersNational Instruments recommends an NI high performance PXIe embedded controller be used both as the system controller and as the controller connected to the front panel of the PXImc module. If you are connecting the PXImc module to an NI PXIe embedded controller, you must update the BIOS software on that embedded controller to the latest released BIOS software prior to connecting the hardware. Refer to NI Embedded Controller BIOS Versions for information about updating the BIOS. Bandwidth experienced when using NI-PXImc may be affected by bandwidth limitations in the controller or on the chassis backplane. If you experience lower than expected bandwidth when using NI-PXImc, check that your controller and chassis are capable of supporting the desired bandwidth, and that your PXImc card is inserted into an appropriate chassis slot to obtain the best performance. Consult your chassis and controller documentation for specific information relevant to your hardware configuration. System RAMNational Instruments recommends a minimum 3 GB RAM for Windows 8.1/7 (32-bit) and LabVIEW Real-Time (ETS), and a minimum of 8 GB RAM for Windows 8.1/7 (64-bit). To maximize the available PXImc buffer, National Instruments recommends either Windows 8.1/7 (64-bit) or LabVIEW Real-Time (ETS). Note The available PXImc buffer will likely be reduced if the above recommendations are not followed. Refer to Setting an Appropriate Buffer Size in the NI-PXImc Help for more information about buffer size. User Mode and Factory Mode Settings for the NI PXIe-8383mc ModuleNational Instruments recommends setting the hardware Mode DIP switch (Switch 4) to User Mode for optimal performance. Refer to the NI PXImc Devices Getting Started Guide, available in the NI PXIe-8383mc kit and on ni.com/manuals, for information about the DIP switch functionality and location. Refer to the Hardware Configuration section in the NI-PXImc Help for more information about the differences between the two modes. NI PXIe-8383mc Power SequenceThe PXIe chassis that contains the NI PXIe-8383mc module must be powered on before the system connected to the front panel connector is powered on. Furthermore, the PXIe chassis that contains the NI PXIe-8383mc module must be continuously powered while the system connected to the front panel connector is powered on. If it is necessary to turn off the chassis containing the PXIe-8383mc, the system connected to the front panel must be powered off first. Refer to the NI PXImc Devices Getting Started Guide, available in the NI PXIe-8383mc kit and on ni.com/manuals, for more information about power sequence. Using Third-Party Controllers with the NI PXIe-8383mc ModuleMany third-party PXI Express controllers, both PXIe embedded controllers and desktop PCs, have been observed to have BIOS issues that prevent the enumeration of some PXIe modules. If you have boot or device enumeration issues, set the hardware Mode DIP switch (Switch 4) on your PXImc modules to Factory mode and try again. Refer to the NI PXImc Devices Getting Started Guide, available in the NI PXIe-8383mc kit and on ni.com/manuals, for information about the DIP switch functionality and location. If you continue to have issues, either contact your controller vendor for a BIOS fix or upgrade your controller to a National Instruments high performance PXIe embedded controller. Module Count for the NI PXIe-8383mc ModuleWhen configuring the NI PXIe-8383mc module in "User" mode, NI recommends no more than six modules be connected to a single system running 64-bit Windows 8.1 or Windows 7, and no more than four modules be connected to a system running 32-bit Windows 8.1 or Windows 7, either directly in the system or connected through the PXImc module front panel connector. If you are using the NI PXIe-8383mc or NI PXIe-8830mc in a system with LabVIEW Real-Time (ETS) OS, NI recommends no more than four modules to a single system, either directly in the system or connected through the front panel connector. If your system needs more than the recommended number of modules, either change Switch 4 to the "FACT" position for all modules or contact National Instruments support. Module Count for the NI PXIe-8830mc ModuleNI recommends no more than six NI PXIe-8830mc modules be placed in a single system with the embedded controller running Windows 8.1/7(64-bit), and no more than four modules be placed in a system running Windows 8.1/7 (32-bit) on the host/embedded controller. If you are using the NI PXIe-8830mc in a system with the embedded controller running LabVIEW Real-Time (ETS) OS, NI recommends no more than four NI PXI-8830mc modules be in the system. If your system needs more than the recommended number of modules contact National Instruments support. Driver Version Naming ChangesNI-PXImc versions are now aligned with the versions of major NI application software products. This alignment gives you information about the year the driver was released and the most recent software version the driver was designed to work with. Driver versions now start with a two-digit year indicator: <;ProductName>. For example, NI-PXImc 14.0.0 is the version released with LabVIEW 2014. The last version released under the old numbering scheme is NI-PXImc 1.0. The first version released under the new numbering scheme is NI-PXImc 14.0.0. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments. Accessing the HelpRefer to the NI-PXImc Help, accessible by selecting Help»NI-PXImc Help from the pull-down menu in LabVIEW, for information about using the NI-PXImc software. Finding ExamplesLabVIEW examples for the NI-PXImc software are in the labview\examples\NI-PXImc folder. You can modify an example VI to fit an application or copy and paste from one or more examples into a VI you create. Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. However, starting with the August 2012 releases (products using NI Installers version 3.1 or later), you may need to perform additional steps before or during a silent installation of NI software. If the NI product you are installing uses Microsoft .NET 4.0, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.0 separately before you install NI software. For more information, refer to the following KnowledgeBase articles: - For more information on silent installations of individual NI products, refer to KB 4CJDP38M, Automating the Installation of a Single Installer.
- For more information on silent installations of suited NI products, such as NI Developer Suite, refer to KB 4GGGDQH0, Automating the Installation of a Suited Installer.
How to Use NI Software with Microsoft Windows 8.xWhen you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (NI MAX), and NI Launcher. Using NI LauncherNI Launcher helps you find and launch installed NI products. It provides you with a method of finding NI products similar to the Start menu in previous versions of Microsoft Windows. To use NI Launcher, click the NI Launcher tile in the Apps view. NI Launcher launches the desktop and opens a menu containing a list of NI products. Click any NI product to launch it. | Note NI MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch NI MAX either from the Apps view or from within NI Launcher. | Pinning Frequently Used ApplicationsFor convenience, you can pin your most-used NI applications, such as MAX, to either the Start screen or the Taskbar on the desktop, as necessary: | Current Application | Icon Location | Pin to Action | | Windows 8.x Desktop | Desktop Taskbar | Right-click application and select Pin to Taskbar | | Windows 8.x Desktop | Start screen | Right-click application and select Pin to Start | | Windows 8.x Start screen | Desktop Taskbar | Right-click application and select Pin to taskbar from the menu bar on the bottom of the screen | Finding All ProgramsIf you want to find a particular application or related files, such as documentation files, from the Start screen, you can access all installed files from the Apps view. To get to the Apps view, right-click anywhere on the Start screen and select All apps (Windows 8) or click the down arrow on the bottom left of the screen (Windows 8.1). For more information about NI support for Windows 8.x, visit ni.com/windows8. Legal InformationCopyright © 2013–2014 National Instruments. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. National Instruments respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on National Instruments trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents
For patents covering the National Instruments products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents. |
