查看: 3699|回复: 0
[NI驱动程序] NI-mmWave 18.1 Driver Win64Eng NI毫米波收发仪系统驱动软件18.1下载
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-21 23:18:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-mmWave
    NI-mmWave用于支持毫米波收发仪系统,以简化软件开发和通信研究。
    NI-mmWave是一个NI仪器驱动,用于帮助用户使用毫米波收发仪系统创建LabVIEW FPGA应用程序,适用于实时无线毫米波通信研究。该驱动还可帮助用户根据研究目标和目的来优化代码。
    Win64Eng
    18.1
    文件大小: 3789749832 字节 (3.53 GB)
    修改日期: 2018-11-02 00:48
    版本: 18.5.0.0
    MD5: 7a75e6a36acda6074f0ca51bf1254929(官方正确)
    SHA1: 356fa429a97e871cdf4f2684a9931b27c6d060b1
    SHA256: f2f8669e93b9e8b16aaf8d8c78a3965b2069db8bb6c3b43053bcc7a8b01e2d38
    CRC32: ee71b00e
    MMWave18.1.txt (575 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-mmWave 18.1 Readme
    October 2018
    This file contains important information about NI-mmWave, including installation instructions, new features, a partial list of bugs fixed for NI-mmWave 18.0, and known issues.
    Installed Software
    This software installation provides support for customers using the mmWave Transceiver System and mmWave Radio Heads, as specified in the Supported Hardware section. To program your mmWave Transceiver System with or without the mmWave Radio Heads, use the NI-mmWave instrument driver.
    The getting started guide for your device provides information about how to install, configure, test, and begin using the mmWave Transceiver System with or without radio heads.
    NI-mmWave 18.1 adds support for recent revisions of the PXIe-3610 Waveform Generator and PXIe-3630 Digitizer
    NI-mmWave 18.0 includes the following new features:
    • Support for LabVIEW 2018
    • Support for the following devices:
      • mmRH-3603 mmWave Radio Head
      • mmRH-3643 mmWave Radio Head
      • mmRH-3653 mmWave Radio Head
    • Support for recent revisions of the mmRH-3602/3642/3652 mmWave Radio Heads
    NI-mmWave 15.3.1 adds support for recent revisions of the mmRH-3602/3642/3652 radio heads
    NI-mmWave 15.3 includes the following new features:
      • mmRH-3602
      • mmRH-3642
      • mmRH-3652
    • Support for fast configuration of gain and mmWave port switches
    • Automatic detection of mmWave radio heads
    NI-mmWave 15.1 includes the following new features:
    • Support for NI LabVIEW 2015 SP1
      • mmWave Transceiver System
        • PXIe-3610 Waveform Generator
        • PXIe-3620 RF Upconverter and Downconverter Module
        • PXIe-3630 Digitizer
        • PXIe-7902 High-Speed Serial Instrument
      • mmRH-3647 mmWave Radio Head
      • mmRH-3657 mmWave Radio Head
    The following hardware products are supported in all operating systems listed in the Supported Operating Systems section. Refer to the Application Software Support section for information regarding supported application software versions.
      • PXIe-3610
      • PXIe-3620
      • PXIe-3630
      • PXIe-7902
    • mmRH-3602
    • mmRH-3603
    • mmRH-3642
    • mmRH-3643
    • mmRH-3647
    • mmRH-3652
    • mmRH-3653
    • mmRH-3657
    NI-mmWave has the following requirements:
    • PXIe-1085 Chassis with a PXIe-8135/8880 Controller
    • RAM—8 GB RAM
    NI-mmWave supports Windows 10/8.11/7 SP12 (64-bit).
    NI-mmWave supports the following application software versions, including service packs. You should install application software, such as LabVIEW, before installing NI-mmWave. To add support for application software installed after installing NI-mmWave, modify your NI-mmWave installation or launch the NI-mmWave installer again.
    Application SoftwareVersions Supported by NI-mmWave
    LabVIEW2015 SP1, 2018
    NI-mmWave palette VIs are available on the LabVIEW Functions palette at Functions»Instrument I/O»Instrument Drivers»NI mmWave.
    NI-mmWave includes a reference project and several example applications for LabVIEW. You can access the installed NI mmWave Reference Project and examples at \LabVIEW \examples\instr\niMmWave.
    Note  The NI Example Finder does not include NI-mmWave examples.
    Note  Installed examples are not sample projects. You must copy the example to a new location before modifying any files. Otherwise, your changes may be overwritten.
    The documentation set for NI-mmWave is composed of the following documents.
    DocumentFormatDescriptionLocation
    Getting Started Guide for your devicePrinted and PDFContains software and hardware installation, signal connection, and information on how to get started with application development for your device.Available at ni.com/manuals
    Specifications for your devicePDFLists technical specifications for your device.Available at ni.com/manuals
    NI-mmWave 18.1 ManualOnline helpContains information on how to use the reference project, as well as conceptual information about instrument driver features.Visit ni.com/info and enter the Info Code mmwavemanual
    NI-mmWave ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.Start»All Programs»National Instruments»NI-mmWave»Documentation
    Installed Software
    • is an alias for the following National Instruments file folder location: Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
    ItemADEInstalled Location
    NI-mmWave ExamplesNI LabVIEW 2015, 2018\LabVIEW \examples\instr\niMmWave\
    You must be an Administrator to install NI software on your computer. Install application software support before installing NI-mmWave.
    • Visit ni.com/info and enter the Info Code mmwavedriver to access the download page for the latest NI-mmWave software.
    • Download the NI-mmWave driver software.
    • Follow the instructions in the installation prompts.
      Note: Windows users may see access and security messages during installation. Accept the prompts to complete the installation.
    • When the installer completes, select Restart in the dialog box that prompts you to restart, shut down, or restart later.
    Note
    • If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/info and enter the Info Code exjq43 for more information and steps to resolve this issue.
    You can access the software and documentation known issues list online. Visit ni.com/info and enter the Info Code expvmm for an up-to-date list of known issues in NI-mmWave 18.1.
    The following items are the IDs and titles of a subset of issues fixed in NI-mmWave. This is not an exhaustive list of issues fixed in the current version of NI-mmWave. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    There are no changes in NI-mmWave 18.1 from NI-mmWave 18.0.
    The following items are changes in NI-mmWave 18.0 from NI-mmWave 15.3.1.
    698524Fixed multiple issues that caused confusion in the 10GbE example project.
    688776Fixed an issue that caused I/Q data to be incorrectly truncated when being sent across Aurora streams on the TX FPGA design in the NI-mmWave Reference Project.
    644996Fixed an issue that caused the NI-mmWave driver to report incorrect coerced frequencies when using the Set Frequency VI.
    The following items are changes in NI-mmWave 15.3.1 from NI-mmWave 15.3.
    600897Fixed an issue that caused an installation error to occur when upgrading NI Linux Real-Time Support for NI-mmWave devices.
    583667Fixed an issue that caused NI-mmWave to incorrectly report the coerced value for out-of-bounds frequencies when using external LO.
    582873Fixed an issue that caused the PXIe-3620 session to be invalid after aborting the session.
    580686Fixed an issue that caused NI MAX to expose unsupported features for the PXIe-7902 module.
    When you install NI software on Microsoft Windows 8.1, you will notice a few additional tiles in the Apps view, including shortcuts to NI application software products such as NI LabVIEW, NI MAX, and NI Launcher. For more information about NI support for Windows 8.1, visit ni.com/windows8.
    © 2016–2018 National Instruments. All rights reserved.
    376436E-01
    GMT+8, 2025-11-19 09:08
