查看: 3542|回复: 0
[NI驱动程序] NI-mmWave 15.1 Driver Win64Eng NI毫米波收发仪系统驱动软件15.1下载
  • 签到天数: 3717 天
    连续签到: 44 天
    发表于 2021-1-21 23:08:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-mmWave
    NI-mmWave用于支持毫米波收发仪系统,以简化软件开发和通信研究。
    NI-mmWave是一个NI仪器驱动,用于帮助用户使用毫米波收发仪系统创建LabVIEW FPGA应用程序,适用于实时无线毫米波通信研究。该驱动还可帮助用户根据研究目标和目的来优化代码。
    Win64Eng
    15.1
    文件大小: 3049293759 字节 (2.84 GB)
    修改日期: 2016-11-09 02:15
    MD5: f5ffd52e34b54875d3236ee54a8cb1df(官方正确)
    SHA1: 53bb0ba730e469b1ff6e5b4d6f65585982acca78
    SHA256: 241820355743872d41b4f07a88b723d2843cea0ad8bfb310260c9b2e63ef3e27
    CRC32: 5d8a69bf
    MMWave15.1.txt (561 Bytes, 下载次数: 0, 售价: 10 圆)
    NI mmWave 15.1 Readme
    September 2016
    Thank you for using NI mmWave. This file contains important information about NI mmWave and is organized into the following sections:
    Accessing VIs and Functions
    Finding Examples and Sample Projects
    Uninstalling/Modifying NI mmWave
    NI mmWave 15.1 includes the following new features:
    • Support for NI LabVIEW 2015 SP1
    • Support for the following devices:
      • PXIe-3610 Baseband Generator
      • PXIe-3620 IF-LO Module
      • PXIe-3630 Baseband Digitizer
      • 71-76 GHz TX mmWave Radio Head
      • 71-76 GHz RX mmWave Radio Head
    • Windows 8.11/7 SP12 (64-bit)
    • Windows Embedded Standard 7 SP12 (64-bit)
    Note  NI mmWave 15.1 and later does not support Windows Server non-R2 editions.
    Minimum Requirements
    • Processor—1 GHz or faster 64-bit (x64) processor
    • RAM—8 GB RAM
    • Windows 8.1/7, with all available critical updates and service packs
    Note  You should install ADEs, such as NI LabVIEW, before installing NI mmWave. To add support for ADEs installed after installing NI mmWave, modify your NI mmWave installation or launch the NI mmWave installer again.
    • NI LabVIEW 2015 SP1
      • (32-bit) Program Files\National Instruments
      • (64-bit) Program Files (x86)\National Instruments for 32-bit programs and Program Files\National Instruments for 64-bit programs
    ItemADEInstalled Location
    NI mmWave ExamplesNI LabVIEW 2015\LabVIEW 2015\examples\instr.lib\niMmWave\
    Documentation for NI mmWave is composed of the following documents.
    DocumentFormatDescriptionLocation
    Getting Started Guide for your devicePrinted and PDFContains software and hardware installation, signal connection, and information on how to get started with application development for your device.Available at ni.com/manuals
    Specifications for your devicePDFLists technical specifications for your device.Available at ni.com/manuals
    NI mmWave ReadmeHTML (this document)Contains information about supported hardware and operating systems, new features, fixed issues, and legal notices.Start»All Programs»National Instruments»NI mmWave»Documentation
    NI mmWave palette VIs are available from the Functions»Instrument I/O»Instrument Drivers»NI mmWave palette.
    NI mmWave includes several example applications for LabVIEW. You can access the installed NI mmWave examples from the Start menu at Start»All Programs»National Instruments»NI mmWave»Examples.
    Note  The NI Example Finder does not include NI mmWave examples.
    Note  Installed examples are not sample projects. You must copy the example to a new location before modifying any files. Otherwise, your changes may be overwritten.
    • Select NI PXIe-3610/3630 15.1 Driver, NI PXIe-3620 15.1 Driver, and NI PXIe-7902R Driver from the dialog box that appears.
    For Windows 8.1, complete the following steps:
    • Select Control Panel.
    • Click the Uninstall button.
    As part of the NI mmWave 15.1 installation, the following software is installed. To completely remove the NI mmWave 15.1 installation from your system, you must also remove all of the following packages:
    • NI Measurement & Automation Explorer 15.0
    • NI-VISA 15.5
    • NI-RIO 15.1
    You can access the software and documentation known issues list online. Refer to the NI mmWave 15.1 Known Issues at ni.com/info and enter the Info Code ex4aqa for an up-to-date list of known issues in NI mmWave 15.1.
    © 2016 National Instruments. All rights reserved.
    376463A-01
    GMT+8, 2025-11-19 09:00
